need some help, truck will not start.
ok, i have had my truck down for about two years doing a stock floor body drop. i have only been able to work on it a little at a time. but i started putting it all back together and it doesn't want to start, the fuel pump will not engage and it will not try to turn over.
i have removed the abs, the airbag system, and installed a hydro boost could any of these things cause it. if you have any ideas i would greatly appreciate them. |
Re: need some help, truck will not start.
I know for a fact it wont run without the airbag control unit installed. hope that helps.
if the fuel pump is not running did you reground the wiring harness for the rear section of the from by the bumper there is two grounds on each side of the stock frame....pretty sure if one or both is disconnected the fuel pump wont run ....
Location: Arlington, Tx/at the Nfamus shop User is: OffLine |
whats the air bag control module? I cut all my shit out. nothing inside the cab left from the abs, just a few plugs. and my truck runs |
the 2 rear grounds are on each side of the tail light harness if i am correct. i have both of them on but i will double check it to be sure and before i gave up last night i tried putting the airbag module back on but it still didn't try to start, i will try to redo that today and see what happens also.
seems like i recall seeing someone on here say the abs system would keep your truck from starting, did you do anything to the abs but pull it out and install a prop valve redd? |
just pulled the abs and left the plugs unplugged... also all my air bag crap is out or cut out.
99 s10.. base modle. no power windows, no tilt, blah blah blah....
Hell of the air bag sensors on the front core support I pulled most of the wires out and just cut them and wraped them with electrical tape.. Heres a question. When you try and start it dose the security light flash? or stay on. I know the factory has some build in anti theft deal, forgot what its called. But when I replaced my tumbler and got new keys made I had to 'relearn the key' before it would start. |
body droppin'
all my airbag and abs stuff is out of my truck and it runs just fine. It's a 2000. I would check all your grounds on the main harness.
when i try to start it the brake light comes on when the key is turned to the start position, but my 2001 blazer does that also but it starts when i turn the key.
registered offender
jump it strait at the starter to see if it will even spin over
registered offender
hope its not locked up
FooldU
sorry to hijack, but what did everyone do with the box under the middle of the seats/console? the wiring for it runs underneath the driver side carpet under a black channel? and does everyone just unplug their airbags, specifically the steering wheel?
!! TALK NOW !!
like they said.. check the grounds. sounds like a grounding issue
nothing you've installed/ removed will hinder it starting, just throw codes which is not a problem ( as far as starting) you may have the grounds in the back of the frame rail, but make sure it is plugged together.. there is a plug by the gas tank location that you can disconnect the rear harness.. |
snausages
sounds like something under the hood isnt plugged in right.
wiring wise |
mine is sitting in a box with the rest of the air bag crap.. I just left the wiring therefor now. |
lets get hammered
passlock??
!! TALK NOW !!
i don't think so.. passlock doesn't give it fuel or something like that (i forget).. he isn't getting anything
Those crazy ass dogs!!!
update on the issue, i need a new shifter cable. i have it in park now and it will crank, but the fuel pump still will not kick on. i i checked the 4 relays under the hood, the grounds, tried another fuel pump i had for a 2001 blazer and still no luck. a guy at work said that it could be an inertia switch but i don't even know if an s10 has one or where it would be. but i am a little closer cause it will crank. thanks again for all the help, any more info would be greatly appreciated.
Disturbed Image Trucks
![]() Age: 27
Location: Boston, MA / Southington, CT User is: OffLine |
i noticed on my truck it wouldnt kick the fuel pump becuase i didnt have the heater/hvac harness plugged in and the fuel pump relay wires run through that harness.
BUILT BY A POORMAN
I had the same problem.after i bodydrop my truck. come to find out it was my wiring harness. a wire came on done.Go over your harness. check all your grounds.try to prime your fuel pump.good luck
#24 |
#25 |
There is no such thing as an intertia switch on any GM vehicle. It was used by Ford because they wanted to wire their fuel pumps like any other system. GM instead flipped the circuit around so in case of an accident, the fuel pump wouldnt ground and keep the pump running.
#26 |
well i guess that owe all of you guys a big apology i went back out today and checked everything over one last time and when it still would not work i tried the other pump again and it started... now i need to pull the pump out of my parts truck and put it in my project truck... thanks again for all the help you guys have given me.
#27 |
!! TALK NOW !!
well glad you got it going..
| Sponsored Links | |
Advertisement | |
