#201 |
Re: My project s-10
to be honest i did really like the look of this truck. but know i really like this truck looks great and i like the table. what size is the table and did you use 2x6, or 2x8. and how big is your garage so nice and clean.
#202 |
Re: My project s-10
the garage is 26 wide by 28 deep and has a 9 ft ceiling ![]() |
#203 |
Re: My project s-10
wow now that is a garage
#204 |
Re: My project s-10
#205 |
Re: My project s-10
will just a little update: i got my steel order on Friday and that should be here on Wednesday. so i can start getting it all cut and ready to be welded up when i get the 230v out to the shop.
#206 |
Re: My project s-10
Great... Can't wait to see some progress
#207 |
Re: My project s-10
will just a small update:
got all the body mounts cut and ready to go. i will be welding in a piece to hold the bolt from pulling the bushing out. just and to go and buy a new hole saw first. ![]() ![]() also got the blue prints for the frame done and printed out: ![]() now i'm just waiting on steel and spring ![]() |
#208 |
Re: My project s-10
blueprints and everything, this build is going to turn out real good man
#209 |
Re: My project s-10
yeah well let hope that it all goes to plan but we all know that never seem to happen that way ![]() |
#210 |
I SHIT BRICKS
Re: My project s-10
wow i just wing my set up lol u got blue prints....someone knows what he is doing....and im still jelious i am actually willing to drive to new york when its done just to see it
#211 |
Re: My project s-10
well got a little update:
i got the frame all cut and ready to start building off ![]() ![]() also got all of my tubing so i can start cutting that up and get everything placed where i want it. |
#212 |
PUNISHING GROUNDS
Re: My project s-10
Niiiice. Can't wait to see more!
#213 |
stone the crow...
Re: My project s-10
cool man you have a fresh start go off of.
#214 |
DriveWay Innovations
Re: My project s-10
*Subscribing*
nice work |
#215 |
Re: My project s-10
*Subscribing* still my favorite truck on here
#216 |
Re: My project s-10
well have little more of an up date: i got all the piece cut and tack to together. the weather is getting better and better everyday so hopefully soon i will have the garage wired up so i can get this thing done
#217 |
Re: My project s-10
finally, cant wait to see the progress once you have full power in there. its gunna be sweet, keep it up
#218 |
stone the crow...
Re: My project s-10
looks good man, what do you have planned for the transition to the stock front clip?
#219 |
Re: My project s-10
well the plan as of now is to cut the top off what is left of the stock frame before the a-arms and were the bag mounts. then run the 2x3 tubing up to that point and weld the stock frame to the tubing. then just plate it in to make a nice smooth transition. |
#220 |
Re: My project s-10
well i got a lot done over the past two weeks. got all my piece cut and in place. also got the rails all welded out and for the most part smoothed out. start to cut and weld on all the fish plates for most of the joist. hopefully this week i can get all the fish plate welded on and get the transition for stock frame to new frame done. also have to flip the frame over and weld all the bottom seems up
![]() ![]() ![]() ![]() ![]() ![]() and here is a picture of the fish plates that i putting on as many joints as i can ![]() |
#221 |
Re: My project s-10
friggin nice
#222 |
Re: My project s-10
looking good man, power yet?
#223 |
Re: My project s-10
borrowed a generator from my grandfather. most say it works pretty dam good.![]() |
#224 |
Flyin SOLO
Re: My project s-10
HOLY CHRIST!!, Dude this truck is SICK, can't wait to see the finished product, you def know what your doing, and I have mad props for you attempting all of the work yourself. The overall outcome so far is amazing! It's guy's like you that make mini truck building so respectable! So, one question are you going to completely rebuild a new bed, and if you do are you going to section it again, or are you just going to run a slightly modfied stock bed, and leave it the stock length? Once again, MAD PROPS!!!!
#225 |
Re: My project s-10
dam first off thanks alot!! it is nice to know that people like what i'm trying to do. to answer the first question yes i'm going to be rebuilding the whole bed. just going to start with two bed sides and build the rest. next question: yes i'm going to resection the bed. the new frame has already been shorten the 5" that the bed was section. third question: not sure to tell you the truth. it all depends on what i can do with the motor. if i can get the motor in low enough then i would like to only make the hood a little modified. like have a small cowl or something, but the all depend on the way the motor sits and all the clearances that i need around it. once again thanks for the props!!!!! ![]() |
#226 |
DO KC Chapter Prez
Re: My project s-10
Subscribed.
#227 |
Flyin SOLO
Re: My project s-10
#228 |
Re: My project s-10
haha well hopefully that is sooner then later
#229 |
The Schnauzberrys
Re: My project s-10
Sweet, cant wait to see some more progress.
#230 |
DOORED AND CHOPPED
Re: My project s-10
whats up homie? been busy i see? i havent been here in a minuete seems as if you been a busy little bee...ill be back soon gotta go hump on my whip just wanted to check in say whatup! keep it up maybe ill see you at a show...
#231 |
Re: My project s-10
. nice what happens when you make a phone call to see what is out there. just about have all the fish plates made just have to weld them on and i can start finishing off the stock to new frame transition and the rails will be all done. then just have to do all the tubing work. which should be a ton of fun![]() |
#232 |
Re: My project s-10
what a hack job...........
J/k Jason. Trucks coming along good. Ill be over around noon today. |
#233 |
Re: My project s-10
well i got all the fish plate cut and drill out. also got all of them shaped and welded on to the frame. i flipped the frame over to weld up all the joints and to weld the bottom of the fish plates, but run out of gas with two plates left to go.
![]() god i can not tell you how much the pissed me off!!!!!. going to get more gas tonight so hopefully i well get the rest welded up.also started to work on the front transition, but because of no gas i don't get to far. i will try to post pictures when i get everything welded up. |
#234 |
Re: My project s-10
Trucks lookin good man. Let me know if ya need someone to go with to carlisle or low rollers....
#235 |
Re: My project s-10
Lookin good yo. Planning on taking it to the truck nats at carlisle this year?
#236 |
Re: My project s-10
yes 100% it is going to be at carlisle. also planning on going to low rollers but we will have to wait and see on that one |
#237 |
Re: My project s-10
i'm sure that Ron and the guys will go to carlisle but i will let you know on the low rollers. may have to see if Dan G and Dan O are going to go and we all can go out together. but i will let you know when that gets closer so we can plan that one out |
#238 |
DOORED AND CHOPPED
Re: My project s-10
#239 |
Re: My project s-10
#240 |
Re: My project s-10
its probably already been stated, but what motor is going in it?
#241 |
Re: My project s-10
not the stock one ![]() ![]() |
#242 |
Re: My project s-10
#243 |
Re: My project s-10
I think me and Gee man are planning on going to low rollers. You are more then welcome to come with. After low rollers i may start thinking hard about getting the sawzall out...... hmmmm.....
#244 |
Project Piece By Piece
Re: My project s-10
Cant wait to see this thing done keep up the good work
#245 |
Re: My project s-10
ok i will let you know |
#246 |
bitch
Re: My project s-10
i put one of those in my truck last weekendedit~ dont waste money on swap headers they wont fit on a bagged truck. get some early 90s camaro manifolds. Last edited by LaynLo : 04-25-2008 at 12:00 PM. |
#247 |
Re: My project s-10
HAHA well mine is going to be a winter project so that i have time to rebuild it and paint the block and trans and save up for all the goodies that will be on it. the old wish listed on the jegs site is pretty long |
#248 |
DOORED AND CHOPPED
Re: My project s-10
[quote=bdydrp18;5178857]haha not sure you will have to worry about that. i still have to rebuild the motor and thing like that. it is going to have to be machined and lot of other things before it will be in the truck. well if you can push a truck thru you may have something to worry about but i not sure they will let me do that. but i will see you there i can tell you that[/quote\]
actually in 05 they let some kid push thru hi low in a doored toy, but he didnt get the official measurement, if he did he would have won it! im 3/4" into the damn door but if you show up w/that roof so low im done 4! oh well i cant always be lower right? i took hi lo at LR in 06 before it was doored and i heard last year some roached ass old bronco won it doored, but i guess the door was rotteed so bad it actually moved back and forth when the dude opened and shut the door. either way i def. wanna see this rollin! if you go to LR for sure hit me on the pm here and i will drop u the # call and well get up party a lil bit!! if your not rollin we can go for a drag in mine! Last edited by getto : 04-25-2008 at 03:15 PM. |
#249 |
bitch
Re: My project s-10
#250 |
Re: My project s-10
[quote=getto;5186979]
yeah well i pretty sure there is no way that i will make it with the motor running. just too much to do in that amount of time. i have wait this long to drive it under if own power what another year. yeah it sucks so bad see all the friend out drive around and stuff, but i want to make sure that i do things right the first time. ok i definitely will do that. as of now i think we are going to go but we will have to wait and see how carlisle works out. |
