#1
!! TALK NOW !!
Keeping stock hood.... Pictures 2.2L
Ok.. Everyone always wants to know easiest way to keep stock hood. THere are different ways..
But I went the way of installing the cavailer intake manifold. My truck is a 98 2.2L... the cav intake came off a 2001 2.2L car. Here are pictures of it all. everyone knows the stock one.. big box on top of the motor ![]() Here is the stock one pulled off .. it comes of rather easy... it is time consuming..but nothing hard about it.. just unbolt ALOT of things. ![]() Here is the cav. intake manifold ... it buts the TB down on the pass. side of the motor ![]() Here are pictures installed... ... again.. time consuming.. All bolts right back up. Use stock TB. I had to lengthen 2 electrical wires just cuz i was kinda lazy and didnt feel like making it work.. ![]() LOok how much it took off the top of the motor.. Here are pictures with a hood on. THis hood is my buddies. He gave it to me.. I just put it on to make sure it all fit before i brought mine down from upstairs. Plus you can see how much room I have with the motor..... THe dipstick MIGHT need sectioned down. I will see when I put my hood on.. But it will be close.. Everythng else fits for sure!! ![]() I would do it if you wanted to run stock hood.. Well worth the effort!!!! |
*INDEPENDENT*
Re: Keeping stock hood.... Pictures 2.2L
now you just need a "stock hood' with no holes in it, looks damn good other wise. How many inches did it shrink down?
!! TALK NOW !!
I have my stock hood in the upstairs of the barn/garage... i was just lazy to bring it down and put it on.. Don't wana scratch it up.
ok.. went out and measured for yea and took pictures.. here yea go! That box sticks up that much.. its nuts!! Here is some signs.. my dad just picked up the Trucks Limited Ground Clearance... the other one is from ITB 04 ![]() thanks dave Last edited by drps10 : 04-15-2006 at 02:54 PM. |
SOLD!
now can we door it?
haha nice work man i didnt think itd work even with the tubular arms.. but shit good deal, and whatd you do for the throttle cable? did you make that piece to plug the port on the side?
big pimpin
!! TALK NOW !!
I havn't done anything else.. like the throttle cable or anything.. Plugging the hole wont be to bad. I hae an idea to do it!... throttle cable shouldn't be to bad either. I'll throw pictures up when I get that done!
stone the crow...
what are you going to do for a air filter?
!! TALK NOW !!
ehh.. i havn't decided yet... I think just running one of those rubber 90* off it then puting the air filter behind the pass. headlight. using the ss pipe.. like the pipes they use for inter coolers on those turbo honda's
Rollin' Low in the 619!!!
Can you give us the part number in case I cannot find a used one? thanks...
!! TALK NOW !!
yea.. i'll look that up for yea!
F u c k Wyotech
Stock hoods are cool WOOOOT
Some Day
I still dont know whats wrong with your truck... that you can do that without touching your intake manifold
Heres how you do it on a 94-97 2.2 http://pg.photos.yahoo.com/ph/nofear...2d.jpg&.src=ph http://pg.photos.yahoo.com/ph/nofear...32.jpg&.src=ph http://pg.photos.yahoo.com/ph/nofear...7e.jpg&.src=ph |
Wow I realy like the look of that too
Nice. |
very nice man
Ford+Mazda=betathan a s10
Hey Adam, I see your girl is driving your truck to school now.
Who wears the pants in that relationship![]() |
F u c k Wyotech
i have a question. what did you do with the hard line that comes off the back of the motor? the one with the steel braid on it. also is your truck a 5 spd? do you have pics of your clutch master cylinder?
!! TALK NOW !!
ha.. yea that is part of the egr vavle. I just put a block off plate on it. i think the xtremes run the plate. its a standard part GM sells.
as far as clutch stuff.. all that is going behind the firewall. I havn't worked on it in awhile. just a mock up.. i plan to get back on that project soon |
*INDEPENDENT*
drps10, 96dragginsdime and nigels_world make a how to. Then we can post it
F u c k Wyotech
#24 |
Ooh, Crack Attack
Only thing you forgot to add about this install was that the guys with factory upper arms will have to cut out a section of their a-arm to clear the manifold for when it's laid out. Seeing as you got aftermarket arms you didn't have any clearance issue's.
#25 |
!! TALK NOW !!
ah.... very true.. I did forget to mention that. stock arms will need modification to fit when laid out
a how to?.. this is kinda like one. You dont need ever step into doing this. Just shows yea what your getting into with the cavalier intake. |
#26 |
Mini Trucker...
hey when u get a chance man can u get the part number for that manifold...
Thanks bro! Chris |
#27 |
Some Day
My method only works with a 3" and 2.75" body drop. Anymore and you run into other things on the manifold (it just wont work lol)
#28 |
Some Day
I dont know if anyone cares... But yesterday I decided I wanted to see how the A/C pump fit. It didnt the pulley itself hit the hood. But I think there is about a 1/2" of clearance between the power steering pump pulley and the a/c pulley. So at some point i am going to slot the holes and try to lower it down and clear. If that doest fit. I am going to try to machine like a 1/4" off of the a/c pulley
#29 |
*INDEPENDENT*
yea a part number on the cavi intake, and is it hard to install?
#30 |
Some Day
do they make an underdrive power steering pump pulley?
#31 |
F u c k Wyotech
#32 |
stone the crow...
thats what i wanted to do with my ac bracket (machine it down that is) the clutch was the only part hitting. But i just ditched it instead oh well.
#33 |
!! TALK NOW !!
3AE PA66 GF33
your part number for the intake manifold ![]() Last edited by drps10 : 04-19-2006 at 08:27 PM. |
#34 |
(Chaos)
ok now i have a few questions. im running a york 209 airlift edc. and i want to add a sanden where the ac is . will it clear the hood?? this is super important since i have a trailblazer swap. and the hood took for ever to get right. if i have to run a cowl i will but stock hoods rock!
#35 |
Some Day
refer to my post on the first page near the bottom its about a stock pump but should be close to the same as a sanden
#36 |
JUST BE SURE WHEN YOU EGG OUT THE MOUNTING HOLES FOR THE SANDEN, MOUNT IT AS LOW AS POSSIBLE. |
#37 |
Some Day
#38 |
!! TALK NOW !!
with the cav in take... i am willing to bet.. that you could door it... unless there is something i don't know about.. but you can see with the pictures with the tape measure... the highest part of the motor would be the vavle cover.. and that is 4'' from the top of the hood... and im b/d 3''
edit:.. now i read.. i think your talking about the edc.. o well.. |
#39 |
Some Day
damn 98-up 2.2s
#40 |
!! TALK NOW !!
don't be jealous
... where you living at now.. ? I thought i saw somewhere about FL |
#41 |
Some Day
Good old PA. I sent all my resumes down to florida lol. But decided I am gonna stay in the area for now. Havent begun looking for a job yet, and my dads just getting on me about it now. So hopefully I find some job in the 45minute-1hour driving range.
#42 |
!! TALK NOW !!
ha... i hear yea about dad getting on yea about things.. been there... when i finish my truck (driveable) i wana come check urs out.. u any close to the great old school of Weyotech ( i have a buddy going there now)
#43 |
Some Day
I am 40 minutes west of wyotech down 22 towards Ohio haha.... I should have mine done soon too lol
#44 |
(Chaos)
ya im only doing a 3 inch im thinking since i have a 5 speed that dam clutch master. mayby i will get lucky and the trany will go out so i can switch to a auto.
#45 |
Some Day
what do you mean? moving the clutch master is alot easier than switching trannys and columns
#46 |
(Chaos)
um it wasnt for me. i had to make a new clutch pedal/and bracket to hold it . and of course move it up and back/angel . it was all dirt biked out there. felt like a kick start harley. so i had to make a new pedal to clear the fire wall tubs.
a tranny swap 30 min since the truck is already up on stands. i pulled the colum out to put a tilt in so i swaped that out any way. i moved the ecu and wires on the inside of the firewall any way so pluging a new one in would have been eazyer. my tranny is going to crap out on me soon enough any way last time i changed the fluid a chunk of a gear fell out .might have been a sinkcro? it does like to pop out of third some times lol. |
#47 |
FooldU
just out of curiousity...i plan on running 18's with 215/35-18's and keeping a/c - do you think my ac compressor would clear stock hood also after the intake manifold mod?
#48 |
body droppin'
the a/c compressor will not clear the stock hood.
#49 |
NUMATIK.
my truck is a 98 2.2 and in the process of being body droped 3.5...i was wantting to put a cavi intake to keep the stock hood....i kepp seein summtin about modifing the control arms can someone tell me if thats true????? And i Have a EGR Valve with a Steel Bradied Line Coming Off it will the cavi intake keep this or do i have to bypass some how...sory if this was previously awnserd..any help is apreciated..thanx
#50 |
!! TALK NOW !!
stock arms need to be modified pretty good amount.. There is a guy on here running stock arms and cavi intake.. i woudln't trust it.. its alot..
the egr port is driver side on the manifold just below the TB... yo will probably have to get a longer "tube" to make it fit... I just blocked mine off! they say it will run alittle rougher but I didn't notice any difference or anything that would make me wonder about driving it. GM sells a block off plate.. go there and tell them u want a block off plate for the egr vavle.. I don't throw any codes.. but i don't know if my system is working 100% either.... to asnwer ?.. can be done on stock arms... my recomendation.. block off plate you will also need a new throttle cable... lokar 36" universal cable from summit works well.. i ran it along with alot of other guys Last edited by drps10 : 10-08-2007 at 10:57 PM. |
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f143/keeping-stock-hood-pictures-2-2l-243456/
| krimutinok 69 post | This thread | Trackback | 11-23-2007 09:02 AM | |
