Jays 97 Stepside Bagged/Bodydropped
Old 08-27-2008, 10:38 AM   #1
Afterhours Admin
AVTekk's Avatar
For the past few months I've been working on my buddy Jays stepside after work. It was completed for ITB but I'm just getting around to posting pics of it now. I didn't take a lot of build pics, the things Ive done have been posted many times before. Heres the rundown on the truck:
- 1997 2.2L Std cab Stepside
- Setup for 18s
- Sanden 508
- 5 gal chrome tank
- 3/8" SMCs
- 3" bodydrop
- Superlift wishbone 3link w/ RE7s
- RCI 17gal fuel cell
- MSD 2225 fuel pump
- Stock spindles w/ Dominator 2500s
- SD control arms with sway bar and shocks
- Factory heat retained with new blower box
- Painted Eastwood single stage flat urethane - "Basket Case Blue"
Below is shot of the frame transition from the 3x3 to the stock clip. The top and outside have been plated for strength. Body mount has been moved down 2", back 3/4", and in 1/4" (because of the angle of the frame). Shock mounts are recessed 3/8" for added clearance.
Also pictured is a shot of the motor mounts, the motor was lowered 3/4" to clear the stock hood. Obviously where its welded is where I cut and sectioned the material out. In theory the motor can come down a full 1" but then the pan will be touching the ground.
Old 08-27-2008, 10:42 AM   #2
Afterhours Admin
AVTekk's Avatar
Re: Jays 97 Stepside Bodydrop
Random sheetmetal pics, the floors have been beadrolled, firewalll shaved, factory wire harness eliminated and relocated, stock heat retained. Clutch master moved up and angled for clearance, required the cowl to be cut into.
Old 08-27-2008, 10:45 AM   #3
Afterhours Admin
AVTekk's Avatar
Couple pics of the truck going back together..Got the wife on paint duty in one pic, the other you can see my new favorite fuel cell, RCI 17gal unit, water/oil trap, backup comp incase the Sanden shits, ect
Old 08-27-2008, 10:50 AM   #4
Afterhours Admin
AVTekk's Avatar
Engine bay pics. As you can see, or not see, basically all wires have been rerouted inside the cab and come out firewall grommets for the necc engine components. Ebay $30 intake cut up, swap meet booster and master, Sanden 508 in stock a/c location.
Threw a close up of the clutch master, and also of the heat-only blower box I made for the truck.
Old 08-27-2008, 10:54 AM   #5
Afterhours Admin
AVTekk's Avatar
Rear setup. Pretty basic and clean, superlift wishbone kit I built with Slam Re7s, SK logo welded in, Hurculiner, trap door for fuel cell.
The rear bed floor is stock height, the front has been raised 2.5", you can tell from the side shots, but the sheetmetal was all reworked so it looks factory with no seams.
Old 08-27-2008, 10:56 AM   #6
Afterhours Admin
AVTekk's Avatar
Quick interior shot, nothing going on in there yet but a billet wheel and shifter.
Old 08-27-2008, 10:58 AM   #7
Afterhours Admin
AVTekk's Avatar
Ok, finished pics...
Old 08-27-2008, 10:59 AM   #8
Afterhours Admin
AVTekk's Avatar
More..
Old 08-27-2008, 11:00 AM   #9
Afterhours Admin
AVTekk's Avatar
Lifted pics, stock spindles air this bitch out!
Old 08-27-2008, 11:01 AM   #10
Afterhours Admin
AVTekk's Avatar
Cali style, Jay loves this shit..
Old 08-27-2008, 11:05 AM   #11
forum idiot
orangesonoma's Avatar
Re: Jays 97 Stepside Bagged/Bodydropped
this thing looks even better in person.. top notch work this guy does
Old 08-27-2008, 11:14 AM   #12
Lay'd
BuiltNotBought99's Avatar
Great looking work as always Dave. I would expect nothing less to come out of your shop. Looks awesome layin body.
Old 08-27-2008, 11:18 AM   #13
bdydrp18's Avatar
look nice nice job
Old 08-27-2008, 12:57 PM   #14
Burnt Blazer
black_ice_02's Avatar
as always great work man. can't wait to start my body drop. I'm running my fuel cell the same way with the same fuel pump.
quick question: have you had any problems with that style pump hooked to stock wiring? Mine keeps locking up so i bought a new one and it now seems like low voltage. i've thought bout putting it on a relay but would really like to fix the issue
Old 08-27-2008, 02:58 PM   #15
Afterhours Admin
AVTekk's Avatar
thanks fellas. everything seems fine on the pump man, throw the relay on it if you think thats the problem, certainly wont hurt anything.
Old 08-27-2008, 03:15 PM   #16
House ownership > s10
xtucking22s's Avatar
looked real nice at ITB. my first thought when i saw you rolling in that day was 'holy ranger like camber batman!' haha. good meeting/hanging out with you too man
Old 08-27-2008, 03:47 PM   #17
Burnt Blazer
thanks for the advice again good work
Old 08-27-2008, 07:44 PM   #18
AcrophobiA
STEN_(d_slammd_1)'s Avatar
Looks good! I love that blower box! I need to make me one. Like bad! Which motor did ou use? The stock one or a 1st gen?
Old 08-27-2008, 07:55 PM   #19
Wears Black Shirts
RacerXS10's Avatar
Really nice work as usual. But I gotta say, no paint for the door handles? lol
Old 08-27-2008, 11:56 PM   #20
rusty bumper member
HofinaterSS's Avatar
wow thats really nice
Old 08-28-2008, 12:08 AM   #21
Beams for the HATERS
83LOWrange's Avatar
that looks real good. i bet it took a while to do
nice floor work
Old 08-28-2008, 12:20 AM   #22
Bagged
chevy power's Avatar
Looking good. Everyone makes this stuff look so easy online, but doing something nice takes a lot of time, well for me anyways.
Old 08-28-2008, 12:22 AM   #23
Bagged
What did you do for fittings on the EDC? I havent had much luck other than people telling me they tapped them to 3/8. I didnt have much luck with that. I thought about getting a bung and welding it to the head but...
Old 08-28-2008, 07:29 AM   #24
un banned
Baggd's Avatar
werd dave. good shit!
Old 08-28-2008, 08:05 AM   #25
///Relaxed Moderator
droppedss's Avatar
Saw it at ITB. Awesome work as always. Good seeing ya again
Old 08-28-2008, 09:31 AM   #26
Afterhours Admin
AVTekk's Avatar
the blower motor is just a stock non-a/c unit, the a/c motor has a deeper fan blade and i wanted as much clearance as possible.
for the Sanden, theres no easy way to do it. try to find a local parts store that makes a/c lines and hydraulic lines. the discharge is a -6 a/c fitting, have them use a universal ferrel and crimp a 3/8" hydraulic hose onto it. the a/c fitting has 2 barbs which will make it extremely difficult for the hose to go on, you can cut the first barb off if you like, it wont matter to the line. the suction is a -8 fitting.
the other way is to get the a/c fitting and cut the crimp end off and use a compression fitting on the steel tube thats left. youll see that way more often because its hard to find shops that will crimp, it will work fine but its just not as "strong" ya know.
Old 08-28-2008, 09:46 AM   #27
Resident Wetback
suicidal's Avatar
saw this at ITB. sick!
Old 08-28-2008, 03:20 PM   #28
KentuckyMinis.com
Slammed83Mazda's Avatar
Same here even without wheels, first thing I thought was damn. That thing lays hard...
Old 08-28-2008, 04:18 PM   #29
S - I - C
DROPTSBLAZE's Avatar
that's sic, nice work Dave
Old 08-28-2008, 05:01 PM   #30
F*ck ~Sunkin Sins~
Wybrow's Avatar
Such a sick stepside!
Old 08-28-2008, 08:27 PM   #31
dropyrs's Avatar
I love stepsides! It looks great.
Old 08-28-2008, 10:10 PM   #32
formally Lownoma
jas0ne's Avatar
looked good as always dave....super clean
Old 08-28-2008, 11:48 PM   #33
Afterhours Admin
AVTekk's Avatar
nice pic nick! ya she lays hard, its setup for a larger tire so them 16s are killin the rockers hah
Old 08-29-2008, 12:01 AM   #34
Half-Bagged for now
leroyme's Avatar
Looks damn good! I got your next project waitin for ya!
Old 08-30-2008, 10:20 AM   #35
It's all rattle canned
dagreenmonster's Avatar
dave back at it again! nice work man!
Old 08-30-2008, 11:57 AM   #36
formally Lownoma
jas0ne's Avatar
id put up the pictures that i have from indy dave...but for some reason it wont let me host them from my flickr account
Old 08-30-2008, 10:58 PM   #37
SLASH - S.I.C. St. Louis
jherrell's Avatar
looks real good Dave... I saw it at Indy, I was taking notes
oh yeah, and if you see Big Derek, tell him to send me those valves
Old 08-31-2008, 12:37 PM   #38
Afterhours Admin
AVTekk's Avatar
thanks fellas. ya jason send me those pics if ya want, daveb@afterhoursfabrication.com
Old 08-31-2008, 06:13 PM   #39
355 member
scrubz's Avatar
saw it at ITB. At first I thought it was the guy's truck who did the Coy 22's on here, but sold them. I was mistaken, lolerz
Old 09-01-2008, 04:29 PM   #40
its lime time!
phatfarmer2's Avatar
guys truck looks sick, nice job dave...
Old 09-07-2008, 02:48 PM   #41
i love Hurricane
FCKNLOW's Avatar
truck is effing sexy....
pics from LR
Old 09-07-2008, 02:53 PM   #42
The way of all flesh
J.Cakes's Avatar
cant tell you any thing man
and this truck is badass, love it
Old 09-07-2008, 02:54 PM   #43
blazerxtreme18's Avatar
damn that looks good...great work..i really gotta get the back of my blaze done...
Old 09-09-2008, 04:44 PM   #44
I Like Fire....HaHaHa
JACKEL's Avatar
Didn't read to see if anyone asked.
Looks great but whats up with the bed. Did those forward side steps cave in from lay'n it out on uneven pavement or something? Just curious cause I've got a step side and been contiplating a BD.
Old 09-09-2008, 10:28 PM   #45
( . Y . )
Something Different's Avatar
Thanks for the comments guy's...Yeah true Dave had to shorten the mounts for the steps so everytime I lay it out it crushes the shit out of em but I usually pull it back out don't really know of any way to fix the problem honestly...
Old 09-09-2008, 11:01 PM   #46
Afterhours Admin
AVTekk's Avatar
ya the side steps are a little longer than the cab, and that truck aint no joke, it lays hard as hell so the sides are gettin hurt lol.
Old 11-11-2008, 07:58 PM   #47
ITS NOT EASY BEING EASY
MODERATOR
Dragginbody's Avatar
very nice!
Old 11-11-2008, 08:04 PM   #48
wants a 2 door 98+ blazer
sdime98's Avatar
suicidal was explaining the deal with the intake on this truck when he stopped by this afternoon, and i was asking about pics of it being on the forum, and low and behold, i accidentally came upon this thread...looks good.
Old 11-11-2008, 08:51 PM   #49
3 crazy projects!!he,he
bitchin sonoma's Avatar
nice truck!!oved them step sides!!
Old 11-12-2008, 10:19 AM   #50
Resident Wetback
suicidal's Avatar
lol. I was about to pm you the link...glad i decided to read through the thread
