For those wit SFBD frame size Q's
LinkBack (2) Thread Tools
Old 10-23-2003, 01:17 PM   2 links from elsewhere to this Post. Click to view. #1
Still plays with sparks
ConnecticutX's Avatar
ConnecticutX
mkay...i quick made this up to stop all the rumors about what size box tubing to go with for frame rails.....its kinda self explanitory, ignore the stuff in the middle, just pay attn to the hieght, width, thickness, deflection and weight. The deflection is in inches and the weight is in lbs.
BTW...this is assuming stock dimensions, a 5 foot length, and 1000lbs of force on the beam....
Old 10-23-2003, 01:19 PM   #2
Hell Yeah I Drag!!
BYONDSIC's Avatar
BYONDSIC is on a distinguished road
Where did you find that chart?
Old 10-23-2003, 01:22 PM   #3
ConnecticutX
This chart is only for bending in the vertical direction....But If the beam is square it will bend the same in all directions...If u plan on usin 3" height by 2" width, the beam will bend much more in the horizontal than in the vertical....If thats the plan and u want horizontal bending just look at 2" height by 3" width and that will give u horizontal displacement....
BTW...displacement just means how far in inches the beam will bend.....here is what I mean by 3x2 and 2x3
Old 10-23-2003, 01:24 PM   #4
ConnecticutX
damn u quick.......as u guys can see 2x2 even with 1/2 inch wall still has about 2" of bend in it...I wouldnt want that under me....I personaly went with 3"x3"x1/4" wall
if anyone wants it in its excel for just shoot me a pm and I'll email it to ya...
Old 10-23-2003, 02:26 PM   #5
DFWminis.com
Dragginblazer's Avatar
Dragginblazer
Thank you for proving most these fools wrong!
Old 10-23-2003, 03:27 PM   #6
ConnecticutX
well, I try.....lol....It just helps when u can look at numbers and actualy see what is goin on.....
Old 10-23-2003, 04:14 PM   #7
DFWminis.com
Dragginblazer
Yeah, I'm glad slammy used 3x3x.25" inside the stock frame on mine now.
lol
Old 10-23-2003, 04:42 PM   #8
Hell Yeah I Drag!!
BYONDSIC's Avatar
Now do you have one for round tubing
Old 10-23-2003, 04:54 PM   #9
I hate you
acrofobia's Avatar
acrofobia is on a distinguished road
Yeah but S-10 frames are C-channeled frames not square. Does this throw off the chart?
Old 10-23-2003, 05:51 PM   #10
Hell Yeah I Drag!!
BYONDSIC's Avatar
He's not talking about deflection on the frame he is talking about deflection on the new tubing you are going to be using to make the sfbd possible.
Old 10-23-2003, 06:03 PM   #11
I hate you
acrofobia's Avatar
He has a "stock" frame size in the chart, that's why I was questioning it.
Old 10-23-2003, 06:10 PM   #12
ConnecticutX
2nd gens are boxed in from the radiator support to the back wall of the cab.....not sure about 1st gens......and since under the cab is the only place u would need to use small stuff it works out perfect.....
Old 10-23-2003, 07:05 PM   #13
circa 1996
Slammy
Nice chart man, ive been telling people forever that 3x3 1/4 wall is the smallest youd ever want to use for frame rails.They dont seem to understand the concept, or maybe they do but are being blinded cause they think they HAVE to have a stock floor cause its the "cool" thing right now.Stock floor body drops work great on fullsizes cause it requires almost no cutting on the floor and you can get a decent size frame under the truck easily.A mini is WAY smaller , requires a bigger bodydrop usually and you will have to chop the shit out of the floor to be able to get a strong enough frame under it. I see what people are doing with these 2x2 and smaller frame as dangerous or trucks that dont need to be daily driven at all.Trailer queens would be ok i guess but i still wouldnt do it on anything i worked on.The frame is the back bone of the truck, the body isnt meant to hold the truck together and if you try and make it you will start breaking the spot welds on the cab cause the stress from too much frame flex.Oh well i guess actually knowing about structural intergrity is one of the things that separates being a professional from the rest of the ummmm what should i call them? Hacks i guess?Not trying to be a ass but damn it gets old.
Old 10-23-2003, 07:35 PM   #14
ConnecticutX
Nice chart man
Thanks man....The biggest misconception is that thicker the wall wall the stronger, no matter the size....3x3x1/4 is much stronger than 2x2x1/2. And 3x3 still isnt as strong as factory verticly, but it is stronger horizontaly...so if u use crossmembers correctly u can get a super stiff frame side to side....and close to as srong verticaly.... I see no reason to use 3x2 rather than 3x3 because the stock frame is about 4.5" wide near the firewall and about 2.5-3 inches wide behind the cab.....horizontal space isnt an issue so use 3" wide .....later, Jon
Old 10-24-2003, 12:38 AM   #15
Quit using "FTW"!!!
dragginbalz's Avatar
dragginbalz is on a distinguished road
can you do me a favor?
compare a 2x4 .188 wall box tube with a 2x8 .125 wall channel frame
just curious
thanks!
t
Old 10-24-2003, 10:06 AM   #16
ilovesparks
thanks for posting that chart. it helped me out alot to see some actual numbers. im sure everybody else appreciates it too. good work, batman!
Old 10-24-2003, 09:42 PM   #17
ConnecticutX
yea, no prob....im not on my pc right now tho...i'll have it done for ya on tuesday......and is that 2" tall x 4" wide? or the other way around....
Old 10-25-2003, 01:24 AM   #18
Quit using "FTW"!!!
4 " tall 2" wide 3/16 rect box tubing
i am just curious as to how it compares, ( for my NON s10 truck)
thanks, I really appreciate it
t
Old 10-29-2003, 07:38 AM   #19
Mad man from michigan
blazentrout
i would like to know were this info was dug up at. if you look at the deflection #'s 3x2 and 3x3 1/4 wall, you will notice that the #s are not the same,but differ by.255. what this is telling me is that something is not quite right with your formula. your vertical height stated the same, the thickness of the wall stock is the same. it should not matter how wide the piece is do to the fact that we are not measuring a horizontal deflection. last ? why doesn't my Reese hitch bend big time when it put my car trailer on it with a tongue weight of 900lbs. it is only made of 1/4 wall
2 1/2x2 1/2. thanks
ps i have a machinist hand book at work if you have a page # for the formulas.
Old 10-29-2003, 11:12 AM   #20
DFWminis.com
Dragginblazer
Your trailer hitch is less than a foot long compared to a 5 foot section that was put into the formula. I also have a Rierson book at my work that I'll lookup & see if they have a similar chart.
Old 10-29-2003, 01:35 PM   #21
alteredimage is on a distinguished road
This would make a good sticky!
Old 10-29-2003, 04:19 PM   #22
blazentrout
opps sorry i meant the receiver that mounts to the frame and it about 36" to 40" long(its raining up here so i am not going to get wet to measure it). i have looked in my machinist hand book and did not find the chart. if its a beam formula, i would like to know were you add the second vertical in at. sorry to be a pain but inquiring minds would like to know.
Old 10-29-2003, 07:41 PM   #23
DFWminis.com
Dragginblazer
Bah. The book I have dosen't show it either.
Old 10-30-2003, 10:05 AM   #24
ConnecticutX
let me learn you.....the vertical section of the beam is called the "web"...the horizontal section is called the "flange"....the 1000 pounds, that I estimated, is exerted on on the flange....and from the flange to the web in the form of pressure (psi)... the equation for pressure is P=F/A, where P is pressure, F is force, and A is area of the flange cross section......now I will use your example....
for the 2" wide.....P=1000/(2*.25) which =2000psi exerted on the web
for 3" wide......P=1000/(3*.25) which =1333.33psi exerted on the web
less pressure on the vertical sections (web) means less overall deflection......
because the beam (hitch) is only like 6" long.....the beam on that chart is 5 feet long...
Old 10-30-2003, 10:27 AM   #25
ConnecticutX
well, I guess that info was dug up from the past 5 years ive spent at Central Ct State U. Engineering dept. as for the mec. handbook...what edition do you have?....I have one at home but not with me right now....but here are the equations....
Moment of inertia (I, in^4) =[(1/12) x base x (height^3)] - [(1/12) x (base - (2 x thickness)) x (height - (2 x thickness)^3]
Deflection (in.) = [force x (length^3)] / (3 x modulous of elasticity x moment of inertia)
Modulous of elasticity for steel = 30 x 10^6
all these equations are in any edition mech. handbook...
so as you can see thru the equations, if you increase the width you increase the moment of inertia, which decreases the deflection.....
Old 10-30-2003, 10:36 AM   #26
ConnecticutX
can you do me a favor?compare a 2x4 .188 wall box tube with a 2x8 .125 wall channel frame
mkay....4x2x3/16 deflects .569 inches and will weigh 36lbs
..........8x2x1/8 "C channel" deflects .19 inches and will weigh 25lbs
lemme know if you need to know why....lol
Old 10-30-2003, 10:48 AM   #27
ConnecticutX
okay so ur talkin about the part of the hitch that goes from one frame rail to the other? if so, it is because that beam is under way more torsion (twisting) than bending.....it works out to be the force on the tounge x the length from the tounge to the beam......if you are talkin about the part of the hitch that sticks out, pointing at the trailer...my answer stands as b4..too damn short to noticably bend...
As for where you add in the second vertical....the equation that is used for moment of inertia in that chart is for a rectangular beam...the second vertical is inherent of the equation...If you want the deflection for a c channel frame you can just double the width and then double the deflection.....and divide the weight by 2...
btw...no pain, when I post somthin like this I fully expect to have to defend it....
Old 10-31-2003, 06:00 AM   #28
Your a smart man:thumbup:
Old 11-04-2003, 04:08 AM   #29
blazentrout
thanks for pointing out that it would be torsional instead of deflection,i was not thinking of it in that way. i see what you mean.
Old 11-04-2003, 05:04 AM   #30
blazentrout
[B
[/b]
i was wondering a couple of more ? i did some more digging and found the formulas that you post and see now how to use them. while i was digging i found this formula(pg 224 of the 25th edition of the machinery's hand book) and i was wondering if this would be a better one to use
bd^3-hk^3/12 (with x height^3- inside with x inside height^3 divided by 12) or is it the same thing but by different means. you have a lot more knowledge on this than i do that is why i am asking that way i can have a better idea of what to use for what project i am working on.
Old 11-04-2003, 05:44 AM   #31
can i video tape you?
clean n low's Avatar
clean n low
real men raise the floor and take it like a man.
Old 11-04-2003, 05:50 AM   #32
blazentrout
one of the guys at work gave me this formula for figuring out deflection wl^3/48EI have you heard of this one?
last question in my hand book it said the modulus of elasticity was 29,000,000(pg193) for steel. is this a misprint?i hope to get a chance tonight to play with the formulas at work with my calculator. i thank you for your time in answering these ? i am a machinist and welder by trade if you are wondering. sorry to whore your thread.
to any one else that is reading this stuff just remember when in doubt go thicker/heaver duty than not.
Old 11-04-2003, 05:55 AM   #33
blazentrout
been there done that. i need to gain as much room on the next truck as possible do to the fact i want to go to the doors, chop the top 4" and section the body 2 1/2" all on a gen 1 blazer. you tend to run out of room quick.
Old 11-04-2003, 10:08 AM   #34
