cutting Wiring harness
Can I cut off the plug in connections I don't need anymore. Such as I no longer have ABS, the a/c, heater unit. What im trying to do is tuck the harness under the dash with the main fuse box and computer in the glove box. I just want to trim down the harness of unneeded plugs. Of course i would tape the end of each wire or crimp a but connector on each end.
Founding member of DA
Re: cutting Wiring harness
do you know what that would do to the resale value????
but yea seriously there is no problem with that |
haha resale value. whats a sfbd do to resale. so i wont experience any problems?
lets get hammered
well think about it, if unplugging it didnt cause a problem, then the plug being gone shouldnt either, i mean the truck doesnt know if the plug and wire is gone, just if what was at the end is gone
!! TALK NOW !!
i agree with the guy above...
but i don't trust it.. if you can leave them in there.. no harm. I know how much of a pain trying to get all the wiring behind the dash. but i'd rather leave them there if I could Let us know how it turns out in what you do! |
Personally i would want to cut down as much as possible..beause if truck has a electrical problem and i have hundreds of wires under my dash that i dont need..i would probly hate myself for not cleaning them up
where's my chippy?
meh i was going to cut all mine when i ripped the inners out, but i decided to keep it
Hoods are overrated
![]() Age: 30
best bet is a carb v8 swap with analog gauges, talk about very little wiring
but yeah rather than just cutting off the connectors, why not pull the wires for each connector and cut them super short from their origin. that way alot of unnecessary wires will be removed completely. |
Layed Out Fabrication
I Was Told A Long Time Ago Not You Cut The Plugs Off, But I Don't See Why Pulling The Wires Out Of The Plug And Cutting Them Down Would Hurt Anything.
Location: Arlington, Tx/at the Nfamus shop User is: OffLine |
I just left all the plugs. It isn't that big of a deal leaving them
I SHIT BRICKS
i was thinkin about doin this on my 1st gen
I guess i'll risk it and cut the unneeded plugs. and trace the wires to cut them as short as i can at the origin. I'll update this thread if i run into any problems. won't know if there will be an electrical issue till later when the truck is close to "back together". I also don't see why it would hurt but i really don't trust it. we'll see.....
Hoods are overrated
![]() Age: 30
install the harness then. pull the truck outside and let it idle while you trace down the wires.
the ones you wanna remove, just test them with a multimeter before you yank them. |
I have a 2.5 S10 and im going with a carb V8, so do i need the wiring harness?
lets get hammered
Actually i just put a wireless V8 in my truck.
Clean as **** Im going out to put on my bolt on body drop. THANKS SD! Im an ass |
i would you the wires and the fuse for something else EI the fuse that is for the ac i would use for the valves or somthing else you know what i mean i am going to buy a painless harness for my truck beacuse mine is gone
so i have to buy a new one or build a new onw frome nothing and i think it would be easer to just get a pinless kit and start there but thatts just my .02
When you cut them just make sure the wires are not touching each other or any metal or anything like that if there is power going to them. Besides that cut away!
Truck #121616
dont be lazy.
trace the wires back, and remove them completely. dont just cut plugs off, you are asking for trouble! i ripped my harness out of my 92, and completely removed about 1/3 of the harness that i didnt need. DRL and all that jazz. seriously about 2-3lbs of wire came off it hahaa! truck works fine! |
DFWminis.com
I have about 20 wires under my dash
FTW! |
| Sponsored Links | |
Advertisement | |
