building frame table/jig help - S-10 Forum
post #1 of 8 Old 09-20-2011, 12:12 PM Thread Starter
User is: jminzler is offline
i have been doing some research on here to try and find the best,easiest, and cheapest way to build a frame table/jig. i have found a few things but i am not sure i am understanding most of it. can someone give me a decent break down on what is needed to make the table, and the best way to do the correct measurements of doing the actual body drops.....
jminzler is offline
post #2 of 8 Old 09-20-2011, 06:00 PM
metal work at its finest
sbdfabrication's Avatar
User is: sbdfabrication is offline
Re: building frame table/jig help
get a couple 20 foot sticks of 2x3x1/4 witch isnt very cheep, u wanna make every thing square and level where all the cross bars meet. also put sum kind of adjustable feet for each leg so you can level the table on a uneven surface, hope this helps a little, mine is 18 ft long 5 ft high and 4 ft wide with a brace every 2 feet..
post #3 of 8 Old 09-25-2011, 04:14 PM
00prostreets10's Avatar
User is: 00prostreets10 is offline
I built my frame table/jig from 3x3 10 gauge with 8 legs and adjusters on the floor and 7 crossbars in it and have like 400 into it minus welding and labor cutting it up.
post #4 of 8 Old 09-27-2011, 01:00 PM
S - I - C
DROPTSBLAZE's Avatar
User is: DROPTSBLAZE is offline
Send a message via AIM to DROPTSBLAZE
I built a frame table out of some left over 6x8s, 2x4s, and sheets of plywood. Worked perfectly, built the frame in a day, and didn't cost anything.
'91 Mazda B2200 - LT1 swap
'00 S-10 ex cab 4.8l LS swap
post #5 of 8 Old 10-27-2011, 02:13 PM
Inferno Fab
flnole78's Avatar
User is: flnole78 is offline
Send a message via AIM to flnole78 Send a message via MSN to flnole78 Send a message via Yahoo to flnole78
my table is made from wood. cost effective unless you are going to be doing ultiple frames on it. I built 2 on it and now it needs a new top. the frame i made from 2x6's and the legs are 4x4's its only 12" off the ground. I would suggest making sure that your engine hoist will roll under your table bc you will need it. That's the biggest problem Ive ran into with mine. Oh and to hold it together, we used Lag Bolts. table is plenty strong..
flnole78 is offline
post #6 of 8 Old 11-16-2011, 10:55 PM
Under construction
User is: 98low4x4blazer is offline
Send a message via AIM to 98low4x4blazer
What is the spacing on your 2x6's? I am thinking of build a wood one, since I will only use it a few times.
post #7 of 8 Old 12-04-2011, 06:56 PM
98layinframe's Avatar
User is: 98layinframe is offline
Send a message via AIM to 98layinframe
I made mine out of 2x4" steel I beams. You want the material you use for the table to be stronger then what your building the frame out of.
Like flnole78 said, make sure you build the table up off the ground as it will make storing things under the table possible, it will be much easier on your legs and back to not be sitting on the ground the entire build, and most importantly the engine hoist will fit under the table. I didnt do this on mine and severely regret it on the current build, the table will have legs added for the next build for sure.
post #8 of 8 Old 12-21-2011, 11:18 AM
Inferno Fab
flnole78's Avatar
I want to say they are 18" apart for the 4 long ones. then there are ones that run perpendicular to those under the MDF and they are around 12-16" apart spaced evenly. One other thing I wouldn't do is leave the openings like I did on mine. They are more of a paint to work around than they help.
flnole78 is offline
