building a sfbd rolling chassis for the girls 1st gen dime
this is for my girlfriends truck
1992 s10 rcsb 4.3 5sp have been collecting allt he parts for the last year. almost everything ive bought has been used except valves kp 6 link art arms drop spindles old kp frame 8 smc 3/8 valves and 3/8 line 4 slam 7s kp gauges.. including the frame and all the parts to bag it i got around 2gs into so far.. started to put it together tonight to get it rolling then will start the body drop ![]() ![]() ![]() ![]() |
Re: building a sfbd rolling chassis for the girls 1st gen dime
heres the truck
![]() it now has a 3/4 drop and air shocks been that way for a while. also got a mint cond bed and tailgate to replace this one. new hood, metal wiper cowl. we own a coffestand and our company colors are white green and brown. since this truck was bought under the company name its a company vehicle. the company name is coffee driven. the truck will be audi candy white. kawasaki green frame and ups brown susp. should look tits i think., with green pinstriping in the company logo ont he tailgate |
Certified Auto HVAC Tech
looks good man...keep us updated on it
i have a thing for first gens |
Hoods are overrated
if you're gonna repaint everything you should defenitely modify the crossmember and raise the gastank up
i have a sd crossmember thats just there till i get my tabs in to put on the crossmember.
and im cutting out the front lower mounts and raising them up just a little bit |
nothing new tonight got some mockup tires for it. laid it on 205/75/15
then put the tie rods back on thats why its not laid inthe pic. ordered some parts from kp and sd got lower tub shock mounts the tabs pre cut to fit my raised gas tank member upper circle plates for the back bags so i can gusset them better and add strength. new front lower frame mounts for the lower four link bars.. to make it look better and suck it up closer to the frame a little more. i think it will look way better and give it more clearance this way since i can fit 2 fingers between the bushing and frame so i bought this mount for them http://www.suicidedoors.com/files/im...8pair%29_0.jpg ![]() |
so ive got a couple questions for the first gen guys
if i just lay 2x3 in the rail and leave stock part of the frame under it will i have to cut up the floor a shit load if i only go to 3" what about 3.5" and how much of a diff do you think it will make if i make the 2x3 lay on the floor and take out the whole section of the stock frame.. i mean the front part of the frame if i lay the 2x3 in it makes it a lot higher since up there it has two sections over lapped onto eachother on the bottom. makeing the 2x3 prolly 3/8-1/2 of inch higher than if it was just laying on the ground.. does any of that make sense? |
well got some ball valves hooked up to her.
got the front horns dropped and sectioned. was gonna get a plazma for this weekend so i could do the tie rod notches and cut out a bunch of rivets and cut out the frame but i got 3 thanksgiving dinners to go to lol one on thur fri and sat ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
i remember seeing this thing for sale on craigslist, where u from man
dont tell me your the kid that always drags by my house at 10mph like a girl ![]() if so then stop by next time. lol i live on north road if you dont remember.. if it is you . ![]() |
yeah my buddy seth bought it from clint at kp.. stripped it sold the wheels and is putting all the stuff that was on on his girls excab.
i bought the frame and drop spindles with hubs from him for 400 bucks |
what? no, i wish i was draggin my shit right now. Its almost driveable, but not yet. Im in mill creek. What truck drags past ur house?
i live right up the road from you.. you might rec. some of my other rides ![]() ![]() ![]() ![]() |
Neighborhood Dragger
Should change the name to "coffee ground" since it's gonna b there.
thats pretty wity man lol good job ima have to mention that to her. maybe itll be the cars name
Haha Like The Name Good Start On The Frame
Just Had A Question??? What Are The Plates On The Front And Back For Or From??
you can see the tube that goes to the pod with the guages and switch box at the front my friend bought it like it is from clint. sold the wheels stripped the parts for his girls dime i bought the frame and spindles and hubs. ![]() |
ohhhh yeahhhhh
FUCK MY TRUCK
clean, i like that blue
the blue is leaving in favor of bright kawasaki green
got the frame horns dropped plated and gusseted. ![]() ![]() ![]() ![]() ![]() |
never finished.
nice projects. your fullsizes look good, i really like the newer one with stock wheels, i've got an '02 f150 i've been wanting to bag forever, can't wait. nice project.
nice rides loving the fullsizes seems like good deal on the suspension half any body mods planned?
#24 |
molded pan smooth gate and thats it.. maybe the key holes who knows
#25 |
Hoods are overrated
front frame horns are always one of the last things i drop after the cab is on the ground. That way you can line the front clip up with the cab.
you'll probably wind up cutting those back off and raising or lowering them to make sure everything lines up. I know every truck is different, some guys wind up having the drop the horns upto 1/2" more than they dropped the cab. i have to cut one of my horns off because it's like 1/4" too high and my front clip is a little bit crooked. |
#26 |
weird. never heard of that problem. before.
if so ill just move the actual mount and not the whole horns if its just that little bit of tweaking. |
#27 |
yea i realized that too. both of mine that are body dropped, i dropped the frame horns the same as the cabs nd they wound up not bein the same on one of em the front is higher on one side by about 1/2 inch nd on my ext. cab it needed to be dropped a good bit more in the front so that it matches with the cab
#28 |
.:|Hustlin4life|:.
#29 |
the tabs from teh old crossmember are temp till i get my new tabs in
![]() also got the tie rod notches done. ![]() ![]() |
#30 |
smooth
Lookin good, I like the color combo, and I drink coffee non stop. Good luck.
#31 |
after some measuring with the s10 i have come to the conclusion that im gonna have to cut the floor no matter what since the area that is by the front cab mount is so small to begin with i dont really gain that much room fromt he 2x3.. so im just gonna go 3.5
![]() ![]() ![]() ![]() Last edited by dava flav : 12-01-2008 at 10:07 PM. |
#32 |
look good man nice progress
#33 |
oh ok, ive seen that silver fullsize on craigslist. Ive seen it rollin around when it was flat black by the shell station at the end of paradise lake road. You were 2 cars behind me and i was in my accord. I was like WTF!? WTF!? I dont see to many bagged rides rollin around anymore so when i do i freak out.
Here is my truck, its an old pic. More has been done lately. <img src="http://img146.imageshack.us/img146/1635/rhj20zn9.jpg"> |
#34 |
nice man... we should all get together.. obv there are more bagged rides around here that you dont know about lol..
theres about 6-8 of us startin a club. my buddy that lives in NY right now going to school is making us a logo.. name is grounded illusions.. |
#35 |
I know a alot of people with bagged trucks, but non ever drive them is the thing. Therefore i never see any rollin around. Two of my roomates are in sittin pretti and i know all the rest of those guys. Im curious to see all the trucks that are gonna be in your club. I might recognize some.
#36 |
right on im friends with shawn.. he lives right down the street from me..
and the black 91 sierra that i bought from some kid.. i guess all the body work was done by sponge himself. hence why i had to get new doors and bed and tailgate. lol.. so far we got my two trucks my girls dime my friend seths stockfloored 88silvy on 22s' his girls sec gen dime stepside ext cab on 18/20s my buddy steve with a 94dime on 18/20 and a nasty smallblock also has a 79 yota he just picked up dan with a 04 ss fully blacked out use to have a laid out 03 silvy on22s and a couple others that arent really into it that much or have sold thier trucks.. but the ones mentioned are for sure.. dan also has a taco that were gonna stock floor prolly next spring |
#37 |
#38 |
headroom
looks clean ...solid build
#39 |
thanks bro
got some parts from sd in a minute ago hopefully with these parts i can get teh instant center to be right!!! its ****ing horrible right now.. my upper bars are painting down to the back of the truck and my lowers are pointing down to the front of the truck lol. im gonna put these tabs in the gas tank crossmember that will bring those mounts down a little then shorten the lowers like 4 or so inches and suck them up against the frame. ![]() |
#40 |
#41 |
Hoods are overrated
frame looks almost identical to mine under the cab, nice work man
#42 |
thanks alot
i found a guy on cl that was a parting out a full s10 rcsb.. wanting to keep on ly the frame and susp for his 49 merc. he said if i come and pull the cab and front clip hell give it to me for 100 bucks with the title.. its 82 s10 so it has the flat dash and almost no wiring as it was a carbed motor.. so im just gonna build a whole new truck then sell bres s10.. gonna go with a 4.3 carbed vortech or a sbc i dont know yet.. 700r4 for sure.. then maybe some billet dash faces with all auto meter gauges.. gonna go strip it tomm and if it goes well bring the cab home and start makin it look like a truck.. i have a mint compl. bed with gate a picked up a while ago for 100 bucks.. so hopefully by next weekend she will look like a truck... lol |
#43 |
hates 4cyl s10s
awesome work man!!! cant wait to se it done....
#44 |
well ive had a mint 1st gen bed for a while now and now i have a cab and whole front clip.. will upload pics later i gotta go toa bday dinner right now..
paid 100 for the bed complete and 100 for the cab and clip with title.. |
#45 |
![]() ![]() ![]() yeah sucka |
#46 |
Look Good
#47 |
PUNISHING GROUNDS
Looks good, looks real good. The rame reminds me a whole lot of mine.
#48 |
Off Vanning. bbl
. I am kidding but its looking good. |
#49 |
im gonna leave it at 3" its low enough for me and her
![]() ![]() ![]() ![]() ![]() [IMG]http://i139.photobucket.com/albums/q303/dubbindave/Breannas%20truck/006-4.jpg[/IMG |
#50 |
smooth
Damn, lookin good. Clean bed and cab also.
