bodydroppin the sonoma
LinkBack (5) Thread Tools
Old 07-14-2008, 06:34 PM   #201
snow camo!!
FCKNLOW's Avatar
FCKNLOW is on a distinguished road
Re: bodydroppin the sonoma
got the motor painted today, still need to paint the transmission and put the waterpump back on.....bag mounts are almost ready to be fully welded...pics of that soon....
found these random pics...
almost full lift
Old 07-14-2008, 06:51 PM   #202
Makin money to bag...
Drag_Racer408's Avatar
Drag_Racer408 is on a distinguished road
Polish them valve covers and they will look really good.
Old 07-14-2008, 07:37 PM   #203
It's all rattle canned
dagreenmonster's Avatar
dagreenmonster is on a distinguished road
SBC!!! niceeeeee
Old 07-14-2008, 11:52 PM   #204
snow camo!!
FCKNLOW's Avatar
im getting different valve covers for it.....i was looking at these....
Old 07-15-2008, 12:09 AM   #205
Cool. They look good.
Old 07-15-2008, 12:32 AM   #206
i was thinking of getting the same ones, and then painting the ribs
Old 07-15-2008, 01:15 AM   #207
Brads Chop Shop
b-rad's Avatar
b-rad is on a distinguished road
they look good make sure you get some that allows the crank case pressure to be released or ask someone at a machine shop about a pressure valve that goes to the block but most of them are older blocks. But your motor looks like a newer still motor.
Old 07-15-2008, 04:10 AM   #208
The Deftones
djleighk15's Avatar
djleighk15 is on a distinguished road
Damn Nice project Subscribed*
Old 07-15-2008, 03:49 PM   #209
snow camo!!
FCKNLOW's Avatar
its an 1980-84 motor....idk if that helps?
Old 07-15-2008, 04:02 PM   #210
PUNISHING GROUNDS
got_u_sick's Avatar
got_u_sick is on a distinguished road
Looks good man.
Old 07-15-2008, 06:58 PM   #211
Brads Chop Shop
b-rad's Avatar
yeah the valve covers you are showing that you like are for an older motor that has a valve at the back of the block that will allow the release of the crank case pressure. Your motor has the pcv valve located on the top of the valve covers which are the chrome round things on it so if you decide to change out your valve covers make sure they have hole in them for those to go in, billet specialist make some nice custom ones so they dont look so bad.
Old 07-16-2008, 03:54 PM   #212
snow camo!!
FCKNLOW's Avatar
alright good deal....thanks man.....
more updates tonight hopefully.....
Old 07-16-2008, 06:27 PM   #213
snow camo!!
FCKNLOW's Avatar
bag moutns are almost ready to be fully welded.....im adding one more bar that goes forward to the inside of the frame.....
Old 07-16-2008, 08:07 PM   #214
f#ck rich kids
ftp ride's Avatar
ftp ride is on a distinguished road
looking good,what kinda tubing bender and notcher you using
Old 07-16-2008, 11:34 PM   #215
snow camo!!
FCKNLOW's Avatar
no tubing beder its all straight shit i ordered from SD, and my dad has the drillpress rigged up with a 1.5" holesaw to notch tubing...hes a madman...
Old 07-17-2008, 11:35 PM   #216
f#ck rich kids
ftp ride's Avatar
sweet man,i love the diy,home built,work with what you got shit,props 2 u
Old 07-18-2008, 12:06 AM   #217
snow camo!!
FCKNLOW's Avatar
thanks man....my dad thinks up all kinds of crazy ways to do shit....it works though! ill have the drivers side tub in tomorrow hopefully and possibly get the frame primered atleast so the motor can go in asap for first mock up! im anxious as hell....
Old 07-18-2008, 05:21 PM   #218
snow camo!!
FCKNLOW's Avatar
drivers side tub is tacked inplace....i got the steering column deal tacked in too( i cut the haggard ass one out from the first round).....just need a filler from the tub to the steering column mount.....its tubbed to lay 22's
Old 07-20-2008, 05:28 PM   #219
never finished.
herseydestin's Avatar
herseydestin can only hope to improve
sick!
Old 07-24-2008, 05:40 PM   #220
snow camo!!
FCKNLOW's Avatar
the bag mounts work...everything just needs to be prettied up a bit and figure out where to put my shocks... it gets rediculous lift
heres and idea of the lift it gets.....front tubulars are hitting the frame and rear is maxed....
Old 07-24-2008, 09:40 PM   #221
PHAT JOE
blazerida88's Avatar
blazerida88 is on a distinguished road
nice progress man
Old 07-24-2008, 10:54 PM   #222
Have you measured how much actuall lift you get? Looks good!
Old 07-24-2008, 11:50 PM   #223
snow camo!!
FCKNLOW's Avatar
its about 11inches.....fucking rediculous....i gotta fix the pinion angle it changes alot at max lift.....
Old 07-28-2008, 09:44 AM   #224
sskdime is on a distinguished road
hey man truck is looking good so far. This is Jared. I'm jason's (sskjason) older brother. He probably told you this already, but that converter that came w/ that motor/trans is too low of a stall. You'll want to get around a 2000-2200 stall converter for that motor. Oh, and make sure you change that oil and squirt some wd-40 down the cylinders before cranking it over. been sitting for a while.
I don't know if he gave you all the specs on it or not. I built it for him so i'll see what i can remember.
engine was out of an 84' Z28 camaro:
stock pistons(8.5:1cr), rods, crank
block was re-honed, cleaned
new federal Mogule rings and clevite 77 bearings(cam, main, and rods)
heads were redone w/ new seals, valves laped, runners cleaned up and smoothed out, bowl blended. new comp cam springs /dampers
Edelbrock Performer RPM intake, 600cfm Performer carb
Cam is the Comp Cams Magnum 270H grind
the motor ran good and sounded awesome. I would suggest maybe getting a set of decent heads later on to take advantage of that cam. The CR is low enough for some boost too Just keep it to about 6psi
Old 07-28-2008, 09:55 AM   #225
PUNISHING GROUNDS
got_u_sick's Avatar
Nice! The rear is lookin great.
Old 08-01-2008, 04:39 PM   #226
snow camo!!
FCKNLOW's Avatar
well im getting this turd pieced together by carlisle....i didnt get as much done as i would have liked but theres still alot im doing to it though...heres some pics from today....the whole link setup and bagsetup is fully welded....
Old 08-01-2008, 10:56 PM   #227
OBS FSC
rolemodel's Avatar
rolemodel is on a distinguished road
awesome man! keep at it, you'll get it done
Old 08-03-2008, 01:34 PM   #228
snow camo!!
FCKNLOW's Avatar
after low rollers is goin back to bare frame to be fully smoothed and painted... so much work left.
Old 08-04-2008, 07:35 PM   #229
Street Spec Kustoms
SSKJason's Avatar
SSKJason is on a distinguished road
looks good ill see it at carlisle, hopefully next to mine. where you plannin to park at?
Old 08-05-2008, 05:17 PM   #230
snow camo!!
FCKNLOW's Avatar
i was working on welding up the cab today and got a crazy plan...im tired of dealing with welding old shitty sheetmetal for the traditional BD sooo im trashin the cab and stockflooring the current frame..im going to look a mint cab a guy my friend knows was using for a drag truck and gave up on....
progress= backwards a little bit but 100% worth it IMO.
what do yall think?
Old 08-05-2008, 09:27 PM   #231
That lil ole Ranger
83LOWrange's Avatar
83LOWrange is on a distinguished road
do it! post hella amount of pics tho! lol
Old 08-06-2008, 12:02 AM   #232
snow camo!!
FCKNLOW's Avatar
ill take some pics of why im doing this.....
gimme a few...
Old 08-06-2008, 12:30 AM   #233
snow camo!!
FCKNLOW's Avatar
it was a learning experience....im not proud of any of this....stockfloor > trad
