body mount question... - S-10 Forum
post #1 of 13 Old 05-07-2005, 06:06 PM Thread Starter
2legit2quit
iLLblazer's Avatar
User is: iLLblazer is offline
i need to make some body mount sections on my floor so i can bolt up the new frame. the stock mounting locations are just rotten, and they hang to low anyways. would it work to just cut them off and weld 3/16 plate in there place, drill a hole in that and use it as a mounting point? the rest of the floor i build will be 16G.
post #2 of 13 Old 05-08-2005, 11:13 AM Thread Starter
2legit2quit
iLLblazer's Avatar
Re: body mount question...
anyone? i'm kind of lost on what to do for my bodymount locations...
post #3 of 13 Old 05-09-2005, 02:46 AM
cab
I <3 SPARKS
cab's Avatar
User is: cab is offline
Send a message via AIM to cab
I thought you were keeping the stock floor for the most part?
sure, you could cut out that part and replace it with 3/16, but how are you going to hide the nut on top?
cab is offline
post #4 of 13 Old 05-09-2005, 06:12 PM Thread Starter
2legit2quit
iLLblazer's Avatar
i dont know. but it turns out my stock mounts are rotten, so they need to go anyways. if i use them again, they will be to low on the frame and the mounts off the frame would be like at the bottom. i want them close to the top so i can gusset that shit.
post #5 of 13 Old 05-09-2005, 06:13 PM Thread Starter
2legit2quit
iLLblazer's Avatar
there are pics of my floor in the progress thread, its pretty cut up.
post #6 of 13 Old 05-09-2005, 06:13 PM
woof
whitedime's Avatar
User is: whitedime is offline
Send a message via AIM to whitedime
why 16 gauge?
post #7 of 13 Old 05-09-2005, 06:21 PM
shortbox's Avatar
User is: shortbox is offline
thats what i did used 3/16 plate on teh body underneath the section where it mounts to my cab floor then i have 1X1 tubing with 16 gauge over top of the floor just make a box with the 1X1 around the plate
shortbox is offline
post #8 of 13 Old 05-09-2005, 09:24 PM
CHANGE YOUR EMAIL ADDRESS
Scrapin S15's Avatar
User is: Scrapin S15 is offline
Send a message via AIM to Scrapin S15
you can use some accorn bolt's (the one's with the flush head's) and you wouldn't see it under the carpet.
post #9 of 13 Old 05-09-2005, 10:45 PM Thread Starter
2legit2quit
iLLblazer's Avatar
i was also thinking i could drill a hole and weld the nut sunk into the plate.
Originally Posted by whitedime
why 16 gauge?
u think its too heavy? i was planning to use 16 where i could and maybe a thinner gauger where i needed to make some tight bends.
post #10 of 13 Old 05-14-2005, 10:44 AM
streetswepa
streetdreams420's Avatar
User is: streetdreams420 is offline
Send a message via AIM to streetdreams420 Send a message via MSN to streetdreams420
I got a question, what could I use for body mount bushings? instead of the big spoonge ones from factory. I did a little seach on the web, and most people seem to say hockey pucks, but i'm thinking that would be a little stiff, any ideas.
post #11 of 13 Old 05-14-2005, 02:01 PM Thread Starter
2legit2quit
iLLblazer's Avatar
hockey pucks? what the f*ck...use your factory mounts, or get some aftermarket ones (enegy suspension). If you feel you need to, trim them down a bit. but why would anyone use a hockey puck?
post #12 of 13 Old 05-14-2005, 02:09 PM
Afterhours Admin
AVTekk's Avatar
User is: AVTekk is offline
lol hockey pucks are no good, most people use them for body lifts on 4x4 and they break and crack in no time. energy suspension makes mounts or you can cut the stock ones down a bit if theyre too tall for you.
Serving the Tri-state: New Jersey - New York - Pennsylvania[/center]
AVTekk is offline
post #13 of 13 Old 05-14-2005, 05:01 PM
streetswepa
thanks boy's, I thought the hockey pucks was a bad idea, thats why I asked. and your right most of the info I found about using hockey pucks for body mounts were on off road web sites.
