Blazer SFBD Progress
Old 03-12-2005, 09:44 AM   #151
2legit2quit
iLLblazer's Avatar
Re: Blazer SFBD Progress
where I'm at now...
ok off to work at my real job...yesssss. i love oil changes.
Old 03-12-2005, 09:56 AM   #152
body dropped
Got_20s's Avatar
Quote: Originally Posted by iLLblazer
OK heres some pics from yesterday. My 4 link and gussets arrived yesterday..it was like a monster garage episode..FREEBIE, FREEBIE...thanks again to Bob at BYONDSIC CUSTOMS in Ontario for sponsoring the rear suspension on my truck. The 4 link and gusstes are all killer. I already started putting some gussets in, and hopefully soon i can get a driveline and some wheels so we can get the 4 link in place. Thanks again Bob.
TIG WELDED BARS...
some gussets in place
all velded up
Bob you guys need a website with all your product line and contact info ASAP so i can get some links up on ssm and blazinlow too...
Somebody won the mini truckin' lotto !
Old 03-13-2005, 02:12 AM   #153
cab
I <3 SPARKS
cab's Avatar
sweet
Old 03-14-2005, 02:00 AM   #154
F**K STOCK
themostoriganal's Avatar
the gussets looks sweet
Old 03-14-2005, 07:52 AM   #155
Hell Yeah I Drag!!
BYONDSIC's Avatar
Looking killer guys. Glad you liked everything. And yes the website is coming and will be up very soon.
Old 03-14-2005, 02:34 PM   #156
2legit2quit
iLLblazer's Avatar
flipped the frame over to weld some stuff on the bottom yesterday. I got a couple pics of the frame on the ground with some tires on the rear end to get an idea of what it'll look like layed out. Hopefully on wendesday i will go over and finsh up a few filler pieces on the bottom of the frame, and then we can get crackin' on installing the 4 link.
Old 03-14-2005, 02:48 PM   #157
Hell Yeah I Drag!!
BYONDSIC's Avatar
so wheres the damn pics then. Don't keep us waiting
Old 03-14-2005, 03:12 PM   #158
tryin ti sponsor another backhalf? muahah
looks good man, you guys are movin real fast
Old 03-14-2005, 03:16 PM   #159
Hell Yeah I Drag!!
BYONDSIC's Avatar
What are you talking about man? What other back half are you referring to?
Old 03-14-2005, 05:23 PM   #160
2legit2quit
iLLblazer's Avatar
pics from yesterday. sorry, i was at school before..couldn't upload any pics.
I think it looks pretty badass now that it all flows together with the old clip, and the gussets round things out pretty nicely.
I also found out that an astro van 700rf4 transmission is the same as what i plan to use in the truck. Since I'm not sure if i can afford a decent one right now, I snagged a buddies to use so I can do the crossmember. I am wishing I would have started with an s10 front clip now, after realizing that v8's sit higher in blazers then they do in pickups. I have some extra risers welded to my crossmember that raise the motor up more for some reason. So we're gonna try to cut those off and drop the motor down.
Old 03-14-2005, 05:35 PM   #161
Hell Yeah I Drag!!
BYONDSIC's Avatar
Coming along great. Middle of the frame where the anlged down bars tie into. How are you getting the exhaust thru there. are you just going to hole saw thru the frame and reinforce it?
Old 03-14-2005, 05:50 PM   #162
2legit2quit
iLLblazer's Avatar
we are not sure yet. we may actually end up cutting the middle right out of it and reinforcing it differentley because I think it could also get in the way of the driveshaft when the truck is lifted.
Old 03-15-2005, 07:53 AM   #163
Hell Yeah I Drag!!
BYONDSIC's Avatar
Drive Shaft hoops are your best friend. Some tubing i bent for another member on the s10 forum.
Old 03-15-2005, 10:42 AM   #164
F**K STOCK
why dont you just get some 3 1/2" round tubing and slice open that back x member and weld in te tubing, or you could just stop the exhaust short of that back x member and throw on a turn down
btw what motor did you have in your blazer, im setting up the tranny x member and 2.8 frame mounts on my truck riiiiight now for the small block, it took some patience trying to get everything perfectly lined up and all. yours is lookin real nice though, im takin notes bc it wont be long here before cab and i will be helpin a friend build a SFBD blazer frame. keep up the good work
Old 03-15-2005, 10:46 AM   #165
cab
I <3 SPARKS
cab's Avatar
just stop it before it gets there.. that's plenty of room for exhaust, unless you're tryin to fit a cat in there too, but that probably will still be enough room.
Old 03-15-2005, 01:21 PM   #166
2legit2quit
iLLblazer's Avatar
i want the floor in the back to follow the slope of the rails, so we may have to do something a little different if we end up cutting it out for the driveshaft. I'm Thinking of some sort of driveshaft hoop that angles with the rails that we can also mount the upper bars off of. If the driveshaft clears, i will either dump the exhaust before that area, or run tubing through it like the driveshaft x-member will be.
Old 03-15-2005, 03:24 PM   #167
cab
I <3 SPARKS
cab's Avatar
hm.. could you possibly go with out one? just mount your upper bars off the side of the framerail and make them angle inwards.. might not be possible though since you have a narrowed rear clip.. its worth checkin into though..
Old 03-15-2005, 04:12 PM   #168
Hell Yeah I Drag!!
BYONDSIC's Avatar
Theres as many options as there is round tube available to buy. It's up to the imagination. You could do hundreds of differnt things back there. Don't let your floor determine what you wanna do. You are gonna have no room back there anyways when your done so go crazy.
Old 03-15-2005, 05:01 PM   #169
2legit2quit
iLLblazer's Avatar
i'm sure we'll figure something out.
Old 03-15-2005, 07:53 PM   #170
F**K STOCK
werd
Old 03-16-2005, 08:00 PM   #171
2legit2quit
iLLblazer's Avatar
this afternoons endeavours..more gussets and patchwork at the bottom:
Old 03-17-2005, 12:53 AM   #172
cab
I <3 SPARKS
cab's Avatar
sick
Old 03-17-2005, 12:56 AM   #173
2legit2quit
iLLblazer's Avatar
ur just loving making the one word posts in my thread aren' t you. hahaha.
Old 03-17-2005, 01:28 AM   #174
F**K STOCK
lmao.............hows that one? well technically its four but whose counting......well i guess you are lol
btw comin along nicely
Old 03-17-2005, 02:27 PM   #175
Afterhours Admin
AVTekk's Avatar
ya man looks good
Old 03-20-2005, 12:37 AM   #176
2legit2quit
iLLblazer's Avatar
thanks guys. i've been de-motivated this weekend for some reason so far. gonna make sure to go tomorrow and finish up the bottom of the frame. won't be too exciting, but i might snap some pics anyways.
Next weekend i have friday and monday off of school as well. so 4 days to bust ass. and its my birthday next sunday too! yay for me. haha.
hopefully i can get something major done..either dropping the motor down and doint the crossmember...or putting the 4 link in..or both.
Old 03-20-2005, 12:52 AM   #177
bitch
LaynLo's Avatar
im stupid do all 1st gen 2wd blazers have a 2 piece driveshaft? ive only seen 2nd gen 2wds up close and 1st gen 4x4s.
Old 03-20-2005, 03:57 AM   #178
I <3 (.)(.)'s
cbauer210's Avatar
where I'm at now...
How big of a BD is this gonna be? I didnt see it mentioned in any other posts.....in this pic it looks like alot more than 3".....eighter way its coming along awsome and i cant wait to see this thing done.....when u shooting to have it drivable?
Old 03-20-2005, 04:25 AM   #179
cab
I <3 SPARKS
cab's Avatar
4 3/4.
Old 03-20-2005, 10:03 AM   #180
streetswepa
streetdreams420's Avatar
I got a 88 2wd blazer and it's got a one piece driveshaft
Old 03-20-2005, 12:45 PM   #181
2legit2quit
iLLblazer's Avatar
Quote: Originally Posted by cab
4 3/4.
how do u know that? I don't even know for sure yet. I'd like to go 1/2" to 1" into the rockers if its not a huge amount of extra work. I don't exactly knwo the amount of BD that works out too.
Old 03-20-2005, 03:01 PM   #182
S - I - C
DROPTSBLAZE's Avatar
That pic with the 2 piece driveshaft was a different truck...
Old 03-20-2005, 03:15 PM   #183
2legit2quit
iLLblazer's Avatar
yeah thats not my truck. bob just posted it as an example of some tube work i could do in the back.
as for today, things are looking shitty as shane, my buddy with the shop, is sick as hell. i still am gonna try to get down there if i can though....
Old 03-20-2005, 09:47 PM   #184
2legit2quit
iLLblazer's Avatar
anyways, heres a couple pics from today. got all the welding done where the new clip joins up finally. started to cap some gussets, but i ran out of gas and only got one done...
Old 03-21-2005, 12:24 AM   #185
F**K STOCK
yeah i hate it when yout working on something and then your gas goes out.......shit sucks
Old 03-21-2005, 02:30 AM   #186
Center your wheels!
layinbody31's Avatar
he he he...I forgot to turn the gas on once when I was welding this past week and welded a couple things with no gas
I thought the welds looked kinda
Old 03-22-2005, 09:56 PM   #187
DoorDragger
DannyBaggs's Avatar
sweet work man...the Pics are sweet...im gunna do a SFBD to my s10 an the pics helped out alot lol
Keep up the good work~
Old 03-23-2005, 12:06 AM   #188
F**K STOCK
lol ive done that too
Old 03-23-2005, 02:38 AM   #189
Center your wheels!
It happens to the best of us...
Old 03-23-2005, 12:55 PM   #190
!! TALK NOW !!
drps10's Avatar
wow I don't feel as slow now.. done that before also..
Old 03-24-2005, 10:54 AM   #191
Hell Yeah I Drag!!
BYONDSIC's Avatar
Updates
Old 03-24-2005, 11:59 AM   #192
2legit2quit
iLLblazer's Avatar
whew bob i thought u might have vanished. haha. like i said above, progress will happen this weekend. I got 4 days off school. I want to get the lower bars tacked in, then we can see where the crossmember for the uppers needs to go. After we get that done, hopefully we can mock up the motor and see what we can do about knocking it down a couple inches. Pics will come this weekend. no worries.
Old 03-24-2005, 12:36 PM   #193
F**K STOCK
yeah the 350 motor mounts that i got had two settings you could choose. i of course used the top one so the motor would sit lower. i cut off the bottom ones bc they were bottoming out on the frame when i went to drop in the motor. i used 2.8 frame mounts............are you going to try and keep yours under the stock hood?
Old 03-24-2005, 12:44 PM   #194
cab
I <3 SPARKS
cab's Avatar
I said 4 3/4 because I thought you were going to the rocker.
Old 03-24-2005, 06:41 PM   #195
2legit2quit
iLLblazer's Avatar
mine only had one setting as far as i can tell....i doubt it will stay under a stock hood, but i'm gonna try my best.
Old 03-24-2005, 06:42 PM   #196
2legit2quit
iLLblazer's Avatar
i know, i was just messing. if anything i may go a little into the rocker if it isn't a shit load of axtra work.
Old 03-26-2005, 03:17 PM   #197
2legit2quit
iLLblazer's Avatar
ok heres some pics from yesterday. got the lower bar tabs tacked on the frame and the fron suspension on to see how its all gonna sit. tomorrow i am getting so wheels that are the same diameter as 20's so we can set up the 4 link...
Old 03-26-2005, 07:39 PM   #198
body dropped
Got_20s's Avatar
Lookin' good. It'll look awesome as a rolling chasis.
Old 03-26-2005, 09:34 PM   #199
Hell Yeah I Drag!!
BYONDSIC's Avatar
Now your talking man. I haven't vanished just keeping very busy. Moved into my new shop on Friday. A 99 Ranger rolled in Friday afternoon so it's a ltille hecktick right now. Progress is awesome.
Old 03-26-2005, 09:57 PM   #200
2legit2quit
iLLblazer's Avatar
cool. shane has a truck comin into the shop for an air install in a week or so, so i need to to get this rolling asap. i might end up spraying it with tremclad and sticking it outside for a week or so if we can't find room for it.
Page generated in 0.67077 seconds with 32 queries
[Output: 212.23 Kb. compressed to 193.39 Kb. by saving 18.83 Kb. (8.87%)]
