#151 |
Draggin body member
another pic
pop can/ pinch weld ratio
#152 |
damn thats a step and a half hehe
#153 |
Draggin body member
LMAO, hell ya dude...
#154 |
down to earth
gonna have to get a rag top to sit in it..
#155 |
Hey Drag_it..got any pics of your beds backside, where the cab is, where did you cut and how did you weld it back together..?
PS Hell of a job man!! |
#156 |
Draggin body member
Lowrider, go back to page 4, and check it out, i posted a pic of it there once before. Peace , and thanks
Josh |
#157 |
Does anyone know what all would have to be modified in the engine bay for a 2 inch body drop? Would the AC blower and intake manifold still need to be cut?
#158 |
you need at least 2 3/4 to lay rocker. anthing over that your cutting rocker. For a 2 incher you should be able to keep everything pretty much stock. The blower motor housing on the passenger side would have to be sectioned but thats about it. Look at a truckin issue a few months back. There was a red s dime from texas that had a 2 1/2 and he kept everything.
#159 |
Draggin body member
#160 |
#161 |
the new body style s10s don't have pinch moldings and you only need 2 3/4 to lay the bottom of the rocker. This is only if your suspensions lays out. Mine is a 3.5 and i cut an just about an inch off of my rockers
#162 |
Posts: n/a
I have always heard if u do 3.25 or 3.5 it lays rocker.
#163 |
nope. just look at the red s10 featured in truckin a few months back. ektensive bodydropped it 2.5" on 19s and 20s and it lays out. You just have to get your suspension to lay flat out and then take your measurements.
#164 |
this is eric from k-otic on s10s i only have to do 2 3/4 and i have done plenty of them so unless your trucks are different from the factory compared to the ones im getting maybe your doing 3s and what not .....but when i bag customers trucks they lay out flat on the rails before we body drop unlike some places where they say they body dropped it 4 inches and the rockers arent even cut of their laying just like a 2 3/4 b/d sorry to be all mr know how but im just telling you what iv done cuase people that clame they have anything bigger than a 2 3/4 and rocker is not cut then one of 2 things .....1 their lying 2 frame is not on the ground and their is many reasons frame my not be on the ground heres a few.... 1 they cant figure out how to get the front to lay cause the bag cups are to big.... 2 the steering is hitting the frame.... 3 control arms are binding (upper its the ball joint) and some aftermarketball joints dont piviot like stock the space they have to travel is alittle bit less(te slot inwhich itmoves) lower is the back braket that the lower bolts to need to be cut on the inside cuase the inside of the control arm hits it and not that many people notice that .... or the 4th one ..if control arms are hitting the frame youmust cut more out and to lay 20s you have to cut alot including modify the ball joint not tryin to be mean im just helping some people out thanx once again K-OTIC anymore ????s coments or concerns click to the right yulokndwn@aol.com
#165 |
I think some people may have just mixed up the 1st gen's and 2nd gen's. It takes 3 1/4" on the 1st gen's to lay rocker, and from what others have said 2 1/2 - 2 3/4" to lay rocker on 2nd gen's.
#166 |
Still 2 High
I'm body dropping my '95 3.5"
In that Minitruckin article, they said you dont have to take the dash out, but for all the more work it is, I think it makes teh job A LOT easier if you take out the dash. And that way you can get to the heater core and everyting to take it all out, and that gives you a lot more room to work too.. And when your cutting the front of the frame, they dont say how far back to cut it, well, we didnt cut it far enough, and the pet**** on the radiator hit the frame, so the radiator wouldnt sit on the supports right. So, make sure leave room for the pet****. Something else, I forget who it was that has a plate covering his a/c holes. But I dont care if it's a daily driver or a full blown show truck, dude, dont do your sh!t half-assed. Do it right. |
#167 |
body dropped
I had a piece of dynamat covering the hole from the heater box, You might have been thinking of mine. It was only a temp thing to keep the dirt and crap out.
#168 |
#169 |
Still 2 High
![]() Got_20's--No, it was Pos-s10's truck. |
#170 |
hey im in the middle of semi stock flooring my 96 std. cab 5in. i saw semi becaues i used 3x4 box but cuz im going so far i have to cut the floor at the front body mounts so from the seat mounts forward is raised 3 in. and i cant fit my rad. back on because the hose hits the frame rail. any tips on clearing it i cut the rail all the way back to the ps pump. also someone said they teed the lines so the abs module was gone and i was wondering how the braking was now? i was gonna relocate mine to where the air box used to be but i kinda want to remove it. on another project we have a 98 ex. cab with a 3 1/2 in stock floor with 20s going on it and was wonderign why 20s are so hard to untuck? what do you have to modify to lay out as far as a arms and such. anything? because if you dont we stuck them on my 5in std. cab and them untuck by half an in but we didnt check if they lay out cuz they will come out of the fenders? thansk for any help.
#171 |
two young to care
when and if i get my s-10...please let me get one...i am going to bd mine 4.5 because that is about is how far u can go without cutting the rockers off and laying the door...and plus you will lay from front to back...and it looks tight....
#172 |
2 3/4 if you don't wanna cut rocker. 4.5 will almost put you to the door.
#173 |
DragnlikeaPimp-we modified the balljoint. we cut the outside perimeter around the balljoint only leaving it by a strand on the outside. we pulled it up so the angle was 10-15 degrees less than it was and rewelded it. When doing this you lose lift. When my truck is all the way up with a 4" bd on an 18 it untucks an inch. The back portion of my control arm is hitting the piece made to the frame right under the upper control arm. If we cut this out we should be able to get another 1-2 inches out of it.
#174 |
two young to care
i know that i will be almost be laying door...that is the point...and what is the most i can get out of a stock floor and still drive it...
#175 |
two young to care
and also could u lay on dubs with a 4.5 inch bd???
#176 |
linkinlogan
I went 4 inches and it will be close with the hood. I 'm gonna have to notch the side of the hood and the piece where the hood sits on the fender. I would go 4
#177 |
thanks Bandit7 do you have any pics of it?
#178 |
i acutually didn't take any when we did it. I can snap a few or detuckn22s has some.
#179 |
two young to care
could i go with a 4.5 on dubs with a really skinny tire???anyways i dont have to worry about it...i gotta ranger right now but i want a sdime...i would like to find one recked in the back were i could go to a junk yard get a new bed and do a subframe in the back and it would be fixed and then bag the front and bd the normal stuff....
#180 |
the skiniest 20 you can get is an 8 and most companies only make 8.5. it would be really close. 4 will put you door rougly 3/4-1 inch from the ground.
#181 |
two young to care
oh ok i think when i get one i will just measure to see how much of a bd i will do with the dubs...
#182 |
cool thanks bandit7 hey do you know if yuo can lay out on 20s with a extended cab body dropped 3 and a half inches with a 5 speed?
#183 |
two young to care
yea i dont think that their would be any problems...
#184 |
hey linkin how are you getting 4.5in out of a stock floor?
#185 |
two young to care
i am not...and plus i dont have a s-10 yet...i want to get one in the future and i was just wondering....if i do that much of a bd when i get it it will be a regular bd...
#186 |
my truck is an extended cab 5 speed with a 4" bd. it lays hard on 18s and will lay on 20s also. Look under suspension for pics of my ride. The thread is called work in progress: bodydrop
#187 |
cool thanks
#188 |
two young to care
man when r u going to get pics of the truck ''bandit''???i want to see what it looks like cause everybody is saying it is going to be badass...but i think that it is too...
#189 |
i have 2 foot high snow mountians bordering from last weekend. it looks badass but the whole cab is primer and so are the rockers. i hope it warms up soon.
#190 |
two young to care
ohh just your luck...well what color r u going to paint it..or r u just going to leave it n primer for now.....
#191 |
leaving it in primer for awhile to im finished shaving everything
#192 |
two young to care
cool i cant wait untill the day my truck goes in the shop to start a bodydrop....and my truck will never go in anybody's shop...u can take any pride in what u didn't do...
#193 |
i am currently about 3/4 of the way done my 5 1/4 bdy drop on my 95 ext cab s-10 and it was a pain in the ass. i had to loose my ac/heat, my wiper motor and also ended up shortening my pedals to get them to function properly. all that is needed to be done now is the notch, 4 link, front core supports, and the juice installed in the back. And oh yea.. body drop the bed.. piece of cake.
later |
#194 |
post some pics. Damn 5 1/4, thats to the door or past. I hope your short because my head is about 3 inches from the roof and i only went 4. I removed everything, too but i didn't want any of that heat or ac **** anyway.
#195 |
ill take some pics tonight of how i did the floor in mine i kept the seats at stock floor level but moved the part where your feet are bacause you can get a full stock floor with 5 inches so i still have headroom and clearence to the steering wheel.
#196 |
heres down to rockers so i got like 2 inches left to go donwn once the rockers are gone
#197 |
close up
#198 |
and heres all the way up
#199 |
oh ya i rebuilt the upper a arms to get the height here they are
#200 |
heres the floor
