Basic Body Dropping
Old 11-20-2002, 08:49 PM   #101
NCHEVYHEVN
Posts: n/a
User is:
Cool because removing the heater core can take half an hour of 3 hours on some automobiles. I think it depends on if you have to remove the dash or not. Hope I don't have to find out.
Old 11-21-2002, 08:13 AM   #102
body dropped
Got_20s's Avatar
I still have heat.
Originally posted by AVTekk
heat isnt really gone, just the blower motor is missing. so if the blower motor is missing, obviously theres no heat cuz there nothing to push the hot air at you. heater core is still in position tho. if you want to get rid of it, just barrel the line together in a loop
I drove all last winter with no blower motor, or heater controls. It's cold at first but once you start driving it gets hot in the cab pretty fast. Heat in the summer........ that sucked.
I really think I should have removed the heater core too.
Old 11-22-2002, 01:20 PM   #103
Draggin body member
JoshJPKustoms's Avatar
I removed the heater core, the blower motor and all the hoses. I put plugs in the block so no antifreeze could come out. You have to remove the dash on old style s10s in order to get the heater core out. If anyone needs a heater core setup, I do have it. There makes a lot more room once you get that outta there. My new fiberglassed dash should take care of that!
Old 11-22-2002, 02:21 PM   #104
Afterhours Admin
AVTekk's Avatar
:thumbup: ya ive seen it go both ways...
Old 11-22-2002, 05:51 PM   #105
Draggin body member
LOL be careful of the antifreeze attack LOL ..antifreeze all over shop floor, but i got it cleaned up LOL peace
Old 11-22-2002, 06:03 PM   #106
has gone suicide!
bdydrgns15's Avatar
If you need a heater, you could always do what I did:
Of course, before you comment, this pic was right after the b/d, so alot has been cleaned up under the hood LOL.
Edit: trying to find bigger pic...
Old 11-22-2002, 06:05 PM   #107
has gone suicide!
bdydrgns15's Avatar
Here we go, nice and large... :thumbup:
Old 11-26-2002, 01:52 AM   #108
Draggin body member
Few more pics of bed
Here is my bed all bolted up. Sorry for the seafoam green color on my truck . The digi flash is wackin up the color totally, but you get the point, im happy with the turnout and she lays hard!
Old 11-26-2002, 01:54 AM   #109
Draggin body member
another
another!
Old 11-29-2002, 06:16 AM   #110
blackLS1's Avatar
Lookin good guys.I plan to get mine body dropped one day hopefully in the next year.How has your ride changed since your bdrop?How has it affected your daily driver status?
Old 11-29-2002, 04:42 PM   #111
has gone suicide!
bdydrgns15's Avatar
Josh, you better be cutting them pinchwelds off man...
Old 11-29-2002, 04:43 PM   #112
has gone suicide!
bdydrgns15's Avatar
The ride wouldn't change, you aren't doing anything to the suspension.
I still drive mine everyday in the summer and into late fall...just parked mine 2 weeks ago. Only to work on it, not because the weather.
Old 11-30-2002, 04:01 AM   #113
Layin body
I need money's Avatar
My stock floor bd is about half way done. Only problem is that
i still gots to channel the front of my frame about 2". I'm using 3x3" tubing w/ 1/4" walls. I should have some pics up within the next week or so.
Old 12-08-2002, 12:36 PM   #114
Draggin body member
Depending on how hard the cab lays them pinch's can kiss their ass goodbye!
Old 12-08-2002, 09:34 PM   #115
gumby green
whitebowtie9's Avatar
another thing you can do with the heater core lines if i remember correctly just directly run the coolant line with an adapter from the radiator to the engine, all i noticed the heatercore was doin was just being in the way of the flow to the radiator... thats all
Old 12-08-2002, 09:42 PM   #116
Layin body
What did all you guys do about your steering column. I layed out my cab 2 days ago and I noticed that it was leaking from the power steering gear box. WTF did I do? If anyone has some help, please let me know.
Old 12-09-2002, 03:48 AM   #117
The column is collapsible so it should be a problem unlesss you're doing like a 5" b/d. I did 3" and my column still had some slack to collapse a little more.
Old 12-11-2002, 03:50 AM   #118
Bolt-On Body Dropz
IntenseMtrsprts7's Avatar
Ya I'm thinkin of going with a 3" body drop, I thought you had to do a 3.25" to lay your pinch welds...heres one who did 3" and is layin pretty damn hard. http://www.streetsourcemag.com/ViewO...Profileid=8525
Old 12-11-2002, 12:51 PM   #119
When i first saw those pics, i had a feeling he was running 17s. I think my truck would lay like that if I had 17s.
Old 12-11-2002, 04:34 PM   #120
Bolt-On Body Dropz
I plan on running 17's or 18's.
Old 12-11-2002, 05:37 PM   #121
NCHEVYHEVN
Posts: n/a
User is:
Dubs for me and a stock floor body drop. I found a guy that will do it and knows how to because he did it to his.
Old 12-12-2002, 07:42 PM   #122
lowrider4life's Avatar
3.25 to lay your rockers....
Old 12-13-2002, 06:24 PM   #123
NCHEVYHEVN
Posts: n/a
User is:
5 inches to lay doors which is the badest of the bad in lowering. :headbang:
Old 12-16-2002, 03:03 AM   #124
elcamino's Avatar
5" body dropped blazer!!!!!!!!!!!
http://ep.com/pic3/1507258/1038732563111.jpg
http://www.blazecustomz.com/bodydrop.jpg
Old 12-16-2002, 06:28 PM   #125
hoppin01s10's Avatar
Originally posted by 91350s10
i just was wondering... someone said that alot of body dropped trucks have thier door panels removed. dont you slide the cab down and cut the floor along the sill seam. this wouldnt change the height of the doors would it?
Just to add this if peoples door panals are removed that means something wasn't done right. Click on the link below. I sectioned the floor where the door panel would of hit. Two +'s by doing this more leg room and door panel clearence. Just my 2 cents.
Jeff
Http://www.streetsourcemag.com/Profi...rofileid=11022
Old 12-16-2002, 07:46 PM   #126
DooR DraggeR
shorty's Avatar
i'm just finishing my 5-1/2" b.d. on my 86 x-cab, laying doors almost...will be after a few passes "down" the road, if ya follow me.
lots-o cuttin' & will only fit 18's all around, that's the bummer, I could have went w/ 20's in back, but they're 1/2" too tall......& I didn't want anything poking out the top of the bed....
you can see in the gallery here or in Street source or some of the build up at www.gotrockers.com, my buddies shop where we did most of the work......
Old 12-17-2002, 03:39 PM   #127
Well I disagree thats what I thought to. So I went ahead a bd it 3 1/4". The rocker sticks below the frame about 1/4". Oh well thou looks like i'll be dragging them smooth. Oh yah I performed this bd on my 01 S-10 xtended cab.
Jeff
Old 12-17-2002, 04:04 PM   #128
NCHEVYHEVN
Posts: n/a
User is:
Dayum that blazer lays hard. What kind of door handles are those.
Old 12-17-2002, 05:39 PM   #129
EyePoppin's Avatar
Jeff
i did 3.25 and worked fine on mine...are u sure u didnt go 3?
Old 12-17-2002, 05:42 PM   #130
body dropped
Got_20s's Avatar
Jeff
That would be 3 1/2 then.
Just playin.
Old 12-18-2002, 05:59 PM   #131
I'm sure I only went 3 1/4". Anyways it don't matter to me , they'll be flat with the frame soon.
Jeff
Old 01-01-2003, 08:46 PM   #132
praise the lower'd
Altophobic's Avatar
exhaust on stockfloor BD
i was wondering what everyones ideas were for running exhaust one a bodyless bodydrop.???????
tks
scott
Old 01-01-2003, 09:26 PM   #133
NCHEVYHEVN
Posts: n/a
User is:
Re: exhaust on stockfloor BD
tks
scott
So u are not going to cut the body to bring it down but build a frame so it lays body???
Old 01-01-2003, 11:48 PM   #134
praise the lower'd
Altophobic's Avatar
im not sure exactly what you were asking but, i am going to bodydrop my bed so that i wont have any holes in it when i get my 20s to lay. and they put spacers between the bed and the frame so that in the future IF i want to bodydrop it to the body lays then i just need to remve the spacrers and it will lay down.
scott
Old 01-04-2003, 12:58 AM   #135
Draggin body member
Some more picsof b/d process
Pics
Old 01-04-2003, 01:00 AM   #136
Draggin body member
more
More
Old 01-04-2003, 01:02 AM   #137
Draggin body member
our special pic
special.......
Old 01-04-2003, 01:03 AM   #138
Draggin body member
another
u can kinda see our phat console too
Old 01-04-2003, 02:50 AM   #139
Afterhours Admin
AVTekk's Avatar
ooOOO hehe keep the pics comin!!
Old 01-04-2003, 11:05 AM   #140
NCHEVYHEVN
Posts: n/a
User is:
Man I have never seen a truck with left hand steering.
Old 01-04-2003, 11:10 AM   #141
phat96
Posts: n/a
User is:
you mean right hand steering
Old 01-04-2003, 11:12 AM   #142
NCHEVYHEVN
Posts: n/a
User is:
Man that is what I meant. It is too early in the morning to be typing.
Old 01-08-2003, 09:10 PM   #143
when i body drop the bed to clear the notch and pumpkin, how much higher do i make it? 2inches?
Old 01-08-2003, 09:58 PM   #144
EyePoppin's Avatar
there are 3 or 4 trucks around here that have rt hand steering, 2 that i helped build.....pretty cool mod.
Old 01-09-2003, 01:16 AM   #145
Draggin body member
Slammed safari, do you mean so you dont have to cut the back out???? if so yeah, just figure out how much more it would be and i would do prolly 1-2" more and then just schim it up bro, we finally got my cal combo and fillers welded in so the assend of my sdime is lookin killer
Old 01-09-2003, 03:56 AM   #146
yeah that's exactly what i meant thanks. Also, when i reweld the bed, do i spot weld it or just lay a fat seam down the sides?
Old 01-10-2003, 08:58 PM   #147
Draggin body member
safari, make sure you tack around in places, dont weld a solid bead across it it will burn through and wont work right..just tack it about every 5" and then go inbetween those tacks, so on and so forth..Peace
Josh
Old 01-11-2003, 01:04 AM   #148
so stich weld it as if i were to shave my handles?
Old 01-11-2003, 12:40 PM   #149
Draggin body member
Exactly
Slammed, yup thats right. When you do the filler panel in the back, you should be able to do a few small 1-2" beads and it will be fine, depending on how thick of metal you used, we used 1/8" for the back of mine, and 1/8" for the cab/firewall also...
Josh
Old 01-22-2003, 09:29 PM   #150
Draggin body member
Pics of my cab
Some pics of the cab welded up and dropped
Page generated in 0.67428 seconds with 32 queries
[Output: 195.09 Kb. compressed to 177.96 Kb. by saving 17.13 Kb. (8.78%)]
