another bodydrop question - S-10 Forum
Old 10-29-2007, 08:41 PM   #1
juiced dimebag's Avatar
ok my first question is do you have to get a elictric fan for the radiator right away or can u just run no hood and take off the fan shroud and drive with the stock engine fan or will it over heat the motor ,its a 4.3
also is their some other kind of radiator in front of the engine radiator because my radiator looks to be too fat to recess in the core support info or pics would be great thanx
Old 10-29-2007, 10:08 PM   #2
Disturbed Image Trucks
lowdime96's Avatar
Re: another bodydrop question
i ran the stock mechanical fan on my 2.2L and no shroud.... with a hood. It was alright when i was moving but it ran pretty hot and overheated on those extra hot days. I ditched it and got a basic efan setup from advance auto parts which works mint. cost me about $80 with the thermostat and 14" fan.
Old 10-29-2007, 11:37 PM   #3
PPG sprayin' member
downtoearth's Avatar
You will be happier in the long run to just drop some extra cash on an E-fan.
Old 10-29-2007, 11:57 PM   #4
ok but now what about the radiator issue i was talkin about any suggestions or info?
Old 10-30-2007, 12:19 AM   #5
Kurrupted Kreations
Garage Customs's Avatar
i've seen e fan on the front of the radiator. is that ok too ? is it better to hav two little fans or one big fan ?
Old 10-30-2007, 12:56 AM   #6
kaczarollision's Avatar
the other thing you are talking about is the a/c condenser. looks the same but not. totally different part. its mounted inside the core support. the radiator is mounted to the back.
Old 03-26-2008, 11:34 PM   #7
are people ditching the a/c condenser to recess the radiator into the core support?...i am planning on keeping my a/c.....what are my options? do i have to recess the radiator?
2000 S10 2.2L manual trans......2.75" trad. bodydrop
Old 03-26-2008, 11:56 PM   #8
i ended up ditchin mine and recessed my radaitor at the bottum so my radiator is angled so u might be able to do it like i did and just recess the bottom and keep the condencer
Old 03-29-2008, 04:35 PM   #9
any other opinions???
Old 03-29-2008, 04:40 PM   #10
NUMATIK.
laydout98's Avatar
this is what i did haha
