3 1/2 in. BD on 24s!!
Old 07-16-2008, 07:27 AM   #451
boricua4_life's Avatar
boricua4_life is on a distinguished road
Re: 3 1/2 in. BD on 24s!!
haha thanks man.
Old 07-16-2008, 11:10 AM   #452
blueberry96's Avatar
blueberry96 is on a distinguished road
so have they got any where on the truck im sure we all would like to see the progress
Old 07-19-2008, 07:10 PM   #453
swtlownoma's Avatar
swtlownoma will become famous soon enoughswtlownoma will become famous soon enough
thats sucks bigtime man, sorry to hear about that, im out here in cali and we have a lot of hack shops around here, but i know of 2 shops out of prolly 15 or so that i would let work on my truck, the guy that bagged my truck, worked out of his garage, but everything is 100%, welds are perfect, im talking everything is perfectly spaced and all, and anpother shop called hoppos hydraulics, they do bags and juice, and they do some awsome work there, good quality, but like i said, id only trust 2 shops to work on mine. so, like u said, live and learn, huh, good luck with the rest of it all. and im glad you found a good shop.
Old 07-20-2008, 02:52 AM   #454
Jason @ AVS
Infamous Kustoms's Avatar
Infamous Kustoms is on a distinguished road
good luck with the rest of your build....
Old 07-20-2008, 01:26 PM   #455
yeah its gonna get done right! i got my 5 link on the way ima weld all that together and the tanks and getting it ready to sandblast it and powdercoat!
Old 07-31-2008, 12:57 PM   #456
well, no pics yet but i bought some new stuff including a sd5 link that i will be welding up this weekend, re z-ing the frame re plating the body drop and doing as much metal work on the frame and cab that i can do. i also took out my interior pieces,(dash, door panels,etc) what grit should i start sanding with and so on?
Old 07-31-2008, 08:25 PM   #457
in_the_weedz is on a distinguished road
any progress pics?? this will like gnar!
Old 07-31-2008, 10:55 PM   #458
SLASH - S.I.C. St. Louis
jherrell's Avatar
jherrell is on a distinguished road
get more pics up bro...
as for grit, start at 120, move up to 200, then 400, then shoot filler primer after that is super smooth. then wet san filler primer with 400 and move forward from there
Old 08-01-2008, 10:35 AM   #459
i have the tools to do it by air, should i start out with 120 on a DA sander or use something else?
ill be posting up pics of the frame work sunday or monday.
Old 08-01-2008, 08:07 PM   #460
dropt
Big_Bake's Avatar
Big_Bake is an unknown quantity at this point
i would hand sand it. any flat area's maybe, but most of it is curved and if your not too experienced you could make plenty of flat spots. i haven't smoothed my interior yet, but i plan on doing it by hand. easier for me to feel how it's going.
Old 08-01-2008, 10:19 PM   #461
yeah was thinking just that!
Old 08-03-2008, 07:38 PM   #462
cool man just started dash and 3rd door with 120. well see how the first pieces turn out!
Old 08-03-2008, 10:57 PM   #463
body droppin'
Milky4204's Avatar
Milky4204 is on a distinguished road
I just got all my stuff painted last weekend. It took a long as time to sand everything. I started with 80 and hit it hard. Then went to 120, 220. Then I sprayed my slick sand on everything and sanded it back out with 180 and 220. Then sprayed it again with slick sand. There was still a few more pieces that needed to be sanded so I did them again. Wet sanded everything with 600 real good then sprayed a sealer on it right before the paint was layed.
Old 08-03-2008, 11:37 PM   #464
tuckn22's Avatar
tuckn22 is on a distinguished road
ya i started with 80 on the da and the da makes quick work. then go to 220, then 320 and prime. put 3-4 coats of primer on it then sand down with 320 and finish it off with 600. i had to prime my sh*t once since i removed all the texture and not filled them. Make sure you remove the texture and not just fill with primer.
Old 08-04-2008, 10:26 AM   #465
so does anyone have pics of what they should look like in the different stages of sanding? plus theres various grits people use. i started with 120. whats the next best grit to go with? pics.?
Old 08-04-2008, 11:45 AM   #466
TUCKIN
lade-lo's Avatar
lade-lo
by buddys drews truck bd 3 in able to lay 24s but currently runnin 22s. the same guy everybody was hatin on....
might have been answered but what wheels are these
Old 08-05-2008, 12:09 AM   #467
check a couple pages back for the wheels.
so does anyone have any suggestions on what grit to use next because 120 seems to be taken forever! maybe 80? help me out guys.
heres what it looks like now.
Old 08-05-2008, 12:58 AM   #468
TUCKIN
lade-lo's Avatar
lade-lo
cant find it so never mind
Old 08-05-2008, 01:15 AM   #469
dropt
Big_Bake's Avatar
just remember the lower grit will leave bigger scratches that you will still have to sand out with high grits. it's not an easy process, pretty time consuming. on the plus side it's a fairly cheap project compared to everything else going on with your truck.
Old 08-05-2008, 07:34 AM   #470
yeah no shit right! lol so should i stay with 120 or go with 80 then 120 and move up.
Old 08-05-2008, 11:02 AM   #471
jherrell's Avatar
stay at 120, the 80 will scratch into the plastic...
Old 08-05-2008, 03:00 PM   #472
antiflag8737's Avatar
antiflag8737 is on a distinguished road
i do all my parts 80 to 180 to 220 to 320 then adhesion promotor and primer. but then again i do all my snading with a DA. not by hand. you can move to 80 but like said above you are going to have to sand more with the finer grits to get the 80 scratch out. hope this helps. heres one i just finished up.
Old 08-05-2008, 03:07 PM   #473
damn thats sick! so guessing i should just stay with 120 considering its gonna be harder to get the scratches off. btw what kind of car is that.
Old 08-05-2008, 06:24 PM   #474
that is an 08 f-150.. i smoothed and painted EVERY plastic piece in the interior. right now its at my friends shop getting a SFBD for 26's. im sure you will see it when its done. sport truck and truckin already want to shoot it, and its not even done yet....hahah
Old 08-05-2008, 10:41 PM   #475
tuckn22's Avatar
i would start with 80 on a da and then 180 then finally 320. make sure you are sanding the texture completely off. DO NOT FILL TEXTURE WITH PRIMER. your s
Old 08-05-2008, 10:43 PM   #476
tuckn22's Avatar
f*ck hit the wrong kit. here are some pics of mine.
Old 08-07-2008, 12:43 AM   #477
swtlownoma's Avatar
that looks good, nice work man, and as for the sanding, stay with the 120 and move up from there, take the time and do it right, dont make life harder, lol, 80 is way to rough, everyone is right, stick with the 120. good job, looks good.
Old 08-07-2008, 12:58 AM   #478
Its Mini Blazin now.
Woody22's Avatar
Woody22 is on a distinguished road
cant you use high build primer.
Old 08-07-2008, 11:30 PM   #479
yeah you have to... the problem with priming over 80 grit scratches in plastic is when you sand, it makes little hairs of plastic on the surface. when you prime over these and sand the primer you can still feel them. then you would have to re-prime.
Old 08-07-2008, 11:59 PM   #480
rooster52478's Avatar
rooster52478 is on a distinguished road
Any updates on the BD?
Old 08-08-2008, 07:32 AM   #481
no not yet will be getting pics of all the metal work this week!
Old 08-08-2008, 08:23 PM   #482
Qsbodydrop10's Avatar
Qsbodydrop10 can only hope to improve
and there will be bad bad shrinkage and the 80 grit scratches will show when everything cures out all the way
Old 08-09-2008, 12:03 AM
