Gimp users!!!! - S-10 Forum
post #1 of 52 Old 04-12-2009, 03:37 AM Thread Starter
registered smartass
zack's Avatar
User is: zack is offline
Gimp users!!!!
post all your gimp questions in here instead of posting 50 million help me's....
paint
okay heres the deal...in the knock off photoshop and gimp the painting systems are less sensitive, personally i think gimps is better tho....you can use two methods to paint a car....hue saturation, and color balance...colorize works too but is too saturating to do anything with.....
first off, when painting, make a new layer so you can go back to the original if you screw up and fix something...and you can play around with the layer types to creat cool paint jobs....
then select the area you wanna paint with the lasso tool
when you use the hue/saturation try and lower the sat sometimes...too high sat will pixelate it...but also make the colors pop more sometimes..also make sure to use the 1600x1200 pictures so its harder to pixelize them, then do everything normal and resize to 800x 600....f
or color balancing, try desaturating first, then colorbalancing...don't use colorize tho...after color balancing you can go back and use hue/sat to get what you want, but sometimes you just can't make a certain pain job from a certain paint job
then you can use levels to darken, lighten, and make flat paint jobs....and after awhile of playing around sometimes be able to chrome bumpers and things through use of layers
lowering specifialy for gimp will be posted soon along with other gimp specifics
zack is offline
post #2 of 52 Old 04-12-2009, 03:48 AM
HAND MADE
corkyw123's Avatar
User is: corkyw123 is offline
Re: Gimp users!!!!
Well, I was trying to type how to "shave" items like emblems & handles, etc, but I'm not to good at explaining. Atleast not in an understandable way.
'00 'Noma Stepside
Currently being HACKED ON!!!!
post #3 of 52 Old 04-12-2009, 03:52 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
already on it dude but if you want go ahead
zack is offline
post #4 of 52 Old 04-12-2009, 04:02 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
lowering:
you need to select more than just the truck, like everything above the wheels, including the background, like so
then click shift+ctrl+L and pull it lower
also when selecting the rest of the background, try to make it to where you'll pull it down, and the asphault will kinda line up, or grass, water whatever the background is....after doing that you'll see white gaps behind the tires, select them with the lasso, and use the blur tool to drag the black area around it into the white area, or atleast this is my method, you can use many others
zack is offline
post #5 of 52 Old 04-12-2009, 04:05 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
shaving:
this is really easy....outline whatever you wanna shave, with the lasso of course, and vlure the surrounding area into...or select an area close to it with lasso, copy, and paste over door handle or whatever then blur out the outlines after anchoring...thats the method that most people use but on gimp i recomend the blur method
zack is offline
post #6 of 52 Old 04-12-2009, 04:08 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
rims:
on gimp this can be a little annoying...
use the circle select to select the new rims from your rim pix, copy and paste into you chop...use the perspective tool and resize tool to get the rim down to the angle and size you want...be sure to try to find rims allready close to the angle you need or you'll end up bluring out the rim when you angle it
note to mods, feel free to clean this thread up if unneccasry posts are mod but if stickied don't lock so that i can add further tutorials
zack is offline
post #7 of 52 Old 04-12-2009, 04:17 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
clear turn signals/tail lights:
simple...select light, adjust brightness/contrast so its kinda shiney, and go to colors-components-channel mixer and then select monochrome and preserve luminocity
zack is offline
post #8 of 52 Old 04-12-2009, 04:33 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
cowl hood:
okay this can be tricky depending on angle, lighting and desired result
select area that you think seems suitable to use for the front or side of the cowl depending on angle
copy and past at suitable location, like so
select gap area and blur surrounding shade into, selecting which shades to blur in depends on you desired result
note that every mention of blurring is using the smudge tool, i forgot the name and substituted blur
zack is offline
post #9 of 52 Old 04-12-2009, 10:38 AM
ELTC
Gimp's Avatar
User is: Gimp is offline
Re: Gimp users!!!!
LMAO IT'S CALLED GIMP!!!!! so am I
2003 GMC Sierra 6/8
1989 Chevy S10 V8 5/6
Gimp is offline
post #10 of 52 Old 04-12-2009, 11:23 AM
Going up ^
01S10's Avatar
User is: 01S10 is offline
Re: Gimp users!!!!
Holy crap GIMP looks a hell of alot better than when I used it!
Back when I had it the thing looked so friggin plain and ugly but the one you have seems to be almost photoshop like. They must have really improved their user interface. Dayum. That was my biggest thing against gimp and it looks like they fixed it. woot.
Still PS is better
2001 BLACK 2wd S-10 Ext Cab LS. 4.3 V6
01S10 is offline
post #11 of 52 Old 04-12-2009, 01:03 PM
HAND MADE
corkyw123's Avatar
Re: Gimp users!!!!
zack, I was wanting to explain the Copy & Paste method. I don't reccommend using the Smudge tool for shaving. You can with minimal problems, but it's just a longer process and more work.
If I knew how to get the images onhere from Gimp like you did above I'd show exactly how I do it.
Also, with the lowering, I Lasso just like you descrided, but instead of the Ctrl and all you're doing, I just Copy & Paste, then pull it down. It'll never have any white areas behind anything like this. But like you said, I' sure there's a few different ways to do these things.
'00 'Noma Stepside
post #12 of 52 Old 04-12-2009, 09:05 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
well the smudge thing just works best for me...except on real big things....and if you have a copied layer then using my method won't leave any white areas either
zack is offline
post #13 of 52 Old 04-12-2009, 09:47 PM
User is: Connnnor is offline
Re: Gimp users!!!!
Zack, How do you get the Layers "box" on the right like the tool box?
Connnnor is offline
post #14 of 52 Old 04-12-2009, 10:24 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
windows-layers...that simple
zack is offline
post #15 of 52 Old 04-13-2009, 05:16 PM
I drive
SoloSDN's Avatar
User is: SoloSDN is offline
Re: Gimp users!!!!
nice tutorial man. i have never had the pixelating problem,but im gonna give this a try.
project: FULL frame 4door
SoloSDN is offline
post #16 of 52 Old 04-13-2009, 06:42 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
thanks bro..nut i'm not done with it yet
zack is offline
post #17 of 52 Old 04-13-2009, 06:58 PM
Eric
Deja_Vu969's Avatar
User is: Deja_Vu969 is offline
Re: Gimp users!!!!
So i downloaded Gimp a while ago and never actually used it all that often. I couldn't figure out to much with it.
these tips/pointers will help out a lot...thanks
post #18 of 52 Old 04-13-2009, 07:16 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
graphics:
ok there are two ways to make graphics
1. using the lasso or paths tool mark out a design on an area of your vehicle....once you have the desired design simply darken or chang the color and use diferent style layers to get your desired effect...this is more difficult but if enough time is taken will give you very original and better looking results
outline the paint job of your car, google an image type, say, a reaper...copy the reaper image, click paste into, and lower the opacity using the layer box to create an easier, also good looking paint job....an example of the number two style is the chevelle lowrider in my bored thread
zack is offline
post #19 of 52 Old 04-13-2009, 07:38 PM
HAND MADE
corkyw123's Avatar
Re: Gimp users!!!!
zack, I need more explanation on the 2nd paint deal. "pasting images".
I can do 2 tones with a good pinstripe etc, but never figured out how folks were getting the graphic picture type designs on there, like the reaper in a few contest back, and tghe spider like CID has on the fullsize in his thread.
'00 'Noma Stepside
post #20 of 52 Old 04-13-2009, 07:46 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
gimme 20 or 30 mins and i'll have pix to help you with
zack is offline
post #21 of 52 Old 04-13-2009, 08:01 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
ok, copy the image you want from google
i seleceted a silver surfer
past it into a new blank chopping page and select the exact parts of the image you want, then copy it....
go to your car, select the area you wanna paste it into,
go to edit, and click paste into...
if its too big or small for your liking then resize it, copy it, and repaste it
then go to the layers menu, make the mode "overylay" or simply lower the opacity of the pasted image
then just anchor it
zack is offline
post #22 of 52 Old 04-14-2009, 12:46 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
metal flake paint:
first, duplicate the layer and lower the opacity of the top layer to 0%, select the second to top layer and select all the area you want to be like this....
then go to filters-noise-hsv
raise the holdness and value, but not too much just a little of each, then click okay...hit cntr+f until you get enough flake
now play with the level and the top layers opacity and until you get the desired result
note: this works best with blue, green and dark red
zack is offline
post #23 of 52 Old 04-14-2009, 02:57 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
deep dish wheels...
ever add a wheel and it just doesn't looke deep enough like this?
this is one of my favourite things to do that'll most likely be noticed when compared to one which was just slapped on....
first copy and paste your wheels like you normally would, but before you anchor them, copy and paste your angled wheel, and moved it over a little like so
then erase the outer edge just enough to reveal the original edge like so
now just paste again, move over, and erase like before, or leave it after the first time and you'll have rims with more depth and large lips
zack is offline
post #24 of 52 Old 04-14-2009, 06:18 PM
Re: Gimp users!!!!
So on the dark S10 that your doing the metal flake paint on I got a question. When I try to lasso out my body for paint then also shift+lasso the windows so they're excluded from the selection it never seems to work? any idea? Sorry if I didnt explain well enough.
Connnnor is offline
post #25 of 52 Old 04-14-2009, 07:36 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
gimme a sec...
zack is offline
post #26 of 52 Old 04-14-2009, 07:39 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
duplicate the first layer 2x by hitting shift+cntrl+d twice...then outline the whole body after you lower the top layers opacity, select the second layer, do every thing like i said, thne after you finish, select the bottom layer, outline one window at a time, copy, and past to the top layer
if anyone has a request tutorial pm it to me and i'll post it up if i can
zack is offline
post #27 of 52 Old 04-14-2009, 10:50 PM
AJ
I do renders!
AJ's Avatar
User is: AJ is offline
Send a message via Yahoo to AJ Send a message via Skype™ to AJ
Re: Gimp users!!!!
you need to learn more yourself there zack before anymore tuts. just being real...haha
AJ is offline
post #28 of 52 Old 04-14-2009, 10:57 PM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
oh i know...but why not share what i already know with the other gimp users while i'm learning...hell they can refine my techniques and figure out more shit
zack is offline
post #29 of 52 Old 04-15-2009, 08:55 AM
Automatic is crap.
Ilikemice's Avatar
User is: Ilikemice is offline
Re: Gimp users!!!!
Is there a hardness setting for the brush tool? I want to vary the fuzzyness of it but I can't find anything.
Member of the I love CSI coalition.
1987 S10 Blazer 2.8 auto 4x4
1997 Ford Explorer 4.0 auto 4x4
1999 VW Polo 1.0 5-speed - "The Slowpo"
post #30 of 52 Old 04-15-2009, 09:02 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
click the little brush dynamics + symbol in the tool window
zack is offline
post #31 of 52 Old 04-15-2009, 11:31 AM
Automatic is crap.
Ilikemice's Avatar
Re: Gimp users!!!!
I found that but it's only for pressure, velocity and random. I was looking for a control for the fuzziness overall, if you get what I mean.
I found something similar by selecting the fuzzy brush tool and messing about with scale. It'll do
I only do terrible line drawings anyway but expect further questions. Cheers.
post #32 of 52 Old 05-02-2009, 09:05 AM
Gawea
gawea's Avatar
User is: gawea is offline
Send a message via AIM to gawea
Re: Gimp users!!!!
hey zack i got a question..whenever i try to change the color of a car or truck, the fill color is a lottt lighter than the actual color i chose. like for example, i wanted to see my truck with a dark green, but it ended up being lime no matter what color i picked..how would i change that? hope that makes sense. i can show you a pic of my truck i did when it was stock as an example
gawea is offline
post #33 of 52 Old 05-02-2009, 09:08 AM
Gawea
gawea's Avatar
Re: Gimp users!!!!
nevermind, i found that i can adjust the lightness from the colors->hue/saturation menu
great tuts btw, ive been at it nonstop for like 3 days lol
gawea is offline
post #34 of 52 Old 05-02-2009, 09:17 AM Thread Starter
registered smartass
zack's Avatar
Re: Gimp users!!!!
thanks bro...and yeah if you're using hue/saturation you can adjust the lightness/darkness or the intensity by lowering the saturation or raising it...the same with colorize...also after you finish coloring an area before you deselect it try using the levels tool and adjusting the sliders to play with the darkness/tone
zack is offline
post #35 of 52 Old 11-23-2009, 08:27 PM
selfmade__brandon
slownoma63's Avatar
User is: slownoma63 is offline
Re: Gimp users!!!!
i cant figure it out lol im not smart
@selfmade_fab @selfmade__brandon
post #36 of 52 Old 12-29-2009, 12:06 AM
AwesomeO's Avatar
User is: AwesomeO is offline
Re: Gimp users!!!!
to lower i use the laso to select, then push ctrl+shift+l but when i pull up or down it dont work?
AwesomeO is offline
post #37 of 52 Old 03-07-2010, 09:36 AM
just another dime!!!!!
unclejames1's Avatar
User is: unclejames1 is offline
Re: Gimp users!!!!
aAlright how would you go about two toneing. I am a complete newb and am trying to two tone my buddies truck as well as change the color of the rims.
post #38 of 52 Old 09-12-2011, 11:44 AM
Sure why not.
rhygin's Avatar
User is: rhygin is offline
Re: Gimp users!!!!
I dunno if anyone has any experience with autocad or knows what dimensioning is but is there a way to do it in gimp... I made an image I need to take into a shop and get it turned into a decal that has to be a precise size as its an overlay or sorts... Basically I just need it to speak to me in inches and not pixels.
/\ use the lasso and just start at the taillight and draw the line out where you want the two tone then make sure in tool options its set to add and not just selection so you can do it multiple times until all the paint on the top of the truck is selected minus the windows, mirrors, etc... CTRL-C, CTRL-V, floating selection will be displayed in the layer manager right click it then make new layer highlight the new layer once its made. CTRL-A, Then I like to use colorize its the easiest tool until you get he hang of things or black and white can be done with saturation, light/dark. Then you can blur the edges with a small blur brush to big and it will look fuzzy. Tinting he windows always helps make it look a little less hacked too do the same thing to the windows make a new layer dark/lighten. When you done save as XCF as two different names one to keep all your layers and one to flatten, blur, and save as a jpeg.
Originally Posted by itsalldownhill View Post
How do I post a question on this forum?
rhygin is offline
post #39 of 52 Old 09-12-2011, 08:50 PM
Drives a Honda now #JDM
93_Blaze's Avatar
User is: 93_Blaze is offline
Re: Gimp users!!!!
nice explanation rhygin
93_Blaze is offline
post #40 of 52 Old 09-13-2011, 02:14 AM
Sure why not.
rhygin's Avatar
Re: Gimp users!!!!
Thanks lol you know how to dimension?
rhygin is offline
post #41 of 52 Old 09-13-2011, 03:54 AM
93_Blaze's Avatar
Re: Gimp users!!!!
nope, not a clue what that is lol
93_Blaze is offline
post #42 of 52 Old 09-13-2011, 12:14 PM
Sure why not.
rhygin's Avatar
Re: Gimp users!!!!
Like if you drew a rectangle and wanted to know how long in inches one side of it was any idea how you might do that? Sorry lol.
This is what "dimensioning" is but this guy took real life and put it into gimp. I need to take from gimp and put into real life. On a side not that is a pretty strong rectangle and I am nearly certain he failed at measuring lol.
rhygin is offline
post #43 of 52 Old 09-13-2011, 03:24 PM
93_Blaze's Avatar
Re: Gimp users!!!!
Lol maybe I'm just retarded, but I still dont get it
93_Blaze is offline
post #44 of 52 Old 09-13-2011, 03:53 PM
Sure why not.
rhygin's Avatar
Re: Gimp users!!!!
No big deal lol I'll just trial and error it maybe ill figure it out.
Basically its just like if your looking at a circle in GIMP you have no idea how big it is... It may be 4 inches on the screen but that may just be the zoom level or its relation to its size in pixels the same circle at the same zoom level would be larger on a larger monitor... Dimensions just let you know that this circle has a real diameter of 3 inches or something even if your zoomed in 10 times and its 30 inches wide because of the dimension you would know that if you print it at a 1:1 scale it will be 3 inches wide.
rhygin is offline
post #45 of 52 Old 09-13-2011, 04:51 PM
AJ
I do renders!
AJ's Avatar
Re: Gimp users!!!!
Idk about Gimp but you can view the image dimensions in inches or pixels...or just use the on screen ruler.
AJ is offline
post #46 of 52 Old 09-13-2011, 08:01 PM
Sure why not.
rhygin's Avatar
Re: Gimp users!!!!
That should be good enough for what I need I will just try that. Thanks.
rhygin is offline
post #47 of 52 Old 09-13-2011, 09:59 PM
93_Blaze's Avatar
Re: Gimp users!!!!
ah ok, I get it now
93_Blaze is offline
post #48 of 52 Old 09-14-2011, 10:22 PM
Sure why not.
rhygin's Avatar
Re: Gimp users!!!!
I figured it out (shift M) lol too easy... Then change the bottom corner to inches or whatever unit you want... I figured it out and went to kinko's here is what I was working on. Welder got burnt and parts discontinued.
Here is an example of what an actual dimensioning tool might do still no luck finding that but with measure you can just draw them yourself.
rhygin is offline
post #49 of 52 Old 09-14-2011, 10:52 PM
AJ
I do renders!
AJ's Avatar
Re: Gimp users!!!!
cool, did everything line up good?
AJ is offline
post #50 of 52 Old 09-14-2011, 10:55 PM
Sure why not.
rhygin's Avatar
Re: Gimp users!!!!
Yep, I went out there and lined it up I still have to put it on though.
rhygin is offline
