will 4wd rims work on a 2wd truck? - S-10 Forum
post #1 of 4 Old 04-30-2006, 11:23 PM Thread Starter
User is: GreaseMonkey83 is offline
i just bought a 97 4 door blazer 2wd and it has gmc sonoma steel weels on it. I want to put a set of aluminum wheels off of a 95 blazer 4wd on it. both are 15" wheels. Will they work?
post #2 of 4 Old 05-01-2006, 08:10 AM
User is: aerosmith_freak is offline
Re: will 4wd rims work on a 2wd truck?
They should work but I don't know from experience. Measure the backspacing to check but it should be near identical. Just measure from the mounting surface to the back of the rim and that should tell you whether it will work or not. It should be within an inch either way.
post #3 of 4 Old 05-01-2006, 08:22 AM
Eight433's Avatar
User is: Eight433 is offline
i dont know if they will physically fit, but even if they did, they woud stick way inside the fenders because they have too high of a backspacing. 4wd s-series axels are wider than the 2wd.
even if they bolted on, i wouldent expect to be able to turn lock to lock without scraping your control arms.
-2011 Silverado Regular Cab Short Box 5.3 6 speed auto 4wd
-67 Cadillac Deville on air
-2000 RoadStar Silverado 1600
Eight433 is offline
post #4 of 4 Old 05-01-2006, 10:30 AM
98layinframe's Avatar
User is: 98layinframe is offline
Send a message via AIM to 98layinframe
if you ran a set of 2" spacers front and rear... then yes the wheels would fit. OTher then that, no they will not work just by bolting them on, the factory backspacing is way off between 2wd and 4wd
