Why do my back brakes lock up??? - S-10 Forum
post #1 of 14 Old 02-10-2008, 05:18 PM Thread Starter
nauticacrya120's Avatar
User is: nauticacrya120 is offline
Hey im from up north and ever since it has been cold, when i start up my truck and start backing out of my driveway, i tap the brakes and the rear brakes just lock up. It will happen 2-4 times before my front brakes start working in a normal matter. Any ideas of what could be wrong or adjusted??
post #2 of 14 Old 02-10-2008, 05:38 PM
benjamin86's Avatar
User is: benjamin86 is offline
Re: Why do my back brakes lock up???
My Cavalier has done this a few times this winter and I would also like to know what it's all about.
post #3 of 14 Old 02-10-2008, 06:53 PM
User is: dimesparks is offline
make sure ur break fluid is full and try to bleed them out u might have air in the lines
my guess
happened to me i did that and it stopped
i drag my shit
http://s232.photobucket.com/albums/e...streetdrag.flv
89 dime bagged on 18s
post #4 of 14 Old 02-10-2008, 07:34 PM
viperstd's Avatar
User is: viperstd is offline
actually, I'm not sure what causes it... but mine do that if it has been raining. After a couple stops everything is normal. Maybe it is a small layer of rust on the braking surface causing a grabbier/more abrasive surface that is quickly sheared off by the braking action.
I don't think it has to do with air in the lines though.
1999 S-10 Ext.Cab | 167k Miles | 2.2L | 5 spd | 4.10s
viperstd is offline
post #5 of 14 Old 02-10-2008, 08:49 PM
chaospartners's Avatar
User is: chaospartners is offline
Send a message via AIM to chaospartners
Mine do it when its raining or cold Notting to worry bout mines done it forever..
03 Extreme, 4.3 5speed! core short throw shifter, custom y pipe, no cats, with flowmaster duals..
post #6 of 14 Old 02-10-2008, 08:53 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
User is: DJDAudio is offline
Send a message via AIM to DJDAudio Send a message via Yahoo to DJDAudio
Mine do it bad,
On gravel the back wheels will lock and drag down the driveway lol
The opinions and views expressed in the above post are the intellectual property of DJDAudio. The above mentioned information shall also hold no legal binding against Doug DeHaven in the court of law.
---\\\CALCULATE Compressor fill time HERE ///---
QUOTE: (Kevdog00) "You sir are like the Einstein of Mini Truckin'! lol"
DJDAudio is offline
post #7 of 14 Old 02-10-2008, 10:22 PM Thread Starter
Originally Posted by DJDAudio View Post
Mine do it bad,
haha thats what mine do. Ill check the brake lines once its not freezing cold with a foot of snow on the ground. Thanks for the input guys
post #8 of 14 Old 02-10-2008, 10:41 PM
TEXAS-S-10's Avatar
User is: TEXAS-S-10 is offline
I Work At A Brake Shop,,check Your Adjustment On The Rears Or Try To Get The Drums Resurfaced And Adjusted....my Opinion,thanks....
post #9 of 14 Old 02-10-2008, 10:51 PM
User is: SSBlazerV8 is offline
G.M. says it is normal for the brakes to grab or make noise on the first or second application. This problem occures after it has sat for a few hours & the humidity is high or has rained. See it all the time. It is caused by rust on the drums or rotors.
post #10 of 14 Old 02-11-2008, 11:24 AM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
check to make sure they are adjusted properly... with the wheel s on, you shouldnt be able to freely spin the wheel with ur hand... it should have slight drag... slight is the key word, u should be able to hear a light scrape of the shoes on the drums... also, first check to make sure ur wheel cylinders are not leaking onto the shoes... when shoes get wet (even water) will make them lock up
post #11 of 14 Old 02-11-2008, 11:41 AM
User is: tuckin20s96 is offline
its from moisture getting in there. make sure you have your rubber plugs in your adjuster holes
97 ext. cab 4/6 on 20's ....under recontruction-junked
96 gmc jimmy tbar crank, 2" shackles, 2" body lift, 32's on cragar soft 8's-sold
95sonoma, 350, th400, 4.10's, leather
post #12 of 14 Old 02-11-2008, 12:27 PM
jman062006's Avatar
User is: jman062006 is offline
x2
post #13 of 14 Old 02-11-2008, 02:10 PM
The Eye is watching you!!
kamesama980's Avatar
User is: kamesama980 is offline
Send a message via AIM to kamesama980 Send a message via Yahoo to kamesama980
on trucks, the brake bias is also rear heavy because they're designed for hauling lots of stuff in back, and then you need more braking where the weight is. combine with light rust on the front disks and viola.
-Russell
1990 Toyota Cressida 7MGE 3l I6/5-speed manual
1987 S10 2.5 not even power brakes it's so base model
"You don't get to judge me for how I fix what you broke."
read this and obey or face my wrath
post #14 of 14 Old 02-11-2008, 02:56 PM Thread Starter
awesom. Thanks a lot again
