wheel barrings????
Old 08-12-2008, 02:46 AM   #1
RickRock is on a distinguished road
wheel barrings????
96 GMC Sonoma 4x4. 5speed. 4.3L (just so you know)
Anyone had these go bad. I haven't gotten to jack my truck up to shake the wheel yet, but when I took off down the road it howled like I had gigantic mud tires on. Does that sound about right to you guys?
I was told there should be no play in the 4x4s. If I jack it up and can move the wheel that means it's bad, right?
Is it dangerous to drive it like that? Could my procrastination on getting an alignment have caused premature failure? Anyone know where I can get 200 bones to purchase the parts I need?
Thanks for the help, sorry if this is in the wrong section. Didn't know where else to put it.
ps, I searched and found nothing, so please don't flame me.
Old 08-13-2008, 02:13 AM   #2
The Blown Blazer's Avatar
The Blown Blazer is an unknown quantity at this point
Re: wheel barrings????
I bought an eBay wheel bearing for my gfs 2000 Jimmy for like $85 and it's been on a couple of years w/o any problems.
Her symptoms were the same, howling and odd noises, then hella play with the wheel in the air.
Its easy to replace, you just need an impact gun to work the gigantic axle nut off. All the other bolts (3 holding it on) come off easily with a 3/8 ratchet and some sockets. There's also other small things like brake calipers and rotors, but thats easy.
Old 08-13-2008, 10:37 AM   #3
NObama
2Lo4aFatHoe's Avatar
2Lo4aFatHoe can only hope to improve
bearings*
Old 08-13-2008, 11:01 AM   #4
nox
World's Largest Drum!
nox's Avatar
nox is on a distinguished road
depending on the mileage and rust on your truck you might need to rent a puller to get the CV out of the spindle.
Old 08-13-2008, 02:47 PM   #5
I'm not sure if I'll need one since I just did the front axle half shafts in May. Anyone remember what size bolt the big hub bolt is? Isn't it like 30 something mm?
And thanks for the spell check, 2Lo
Old 08-13-2008, 02:48 PM   #6
Old 08-13-2008, 02:55 PM   #7
Founding member of DA
pack of q tips's Avatar
pack of q tips is on a distinguished road
36mm i think
Old 08-13-2008, 03:19 PM   #8
nox
nox's Avatar
36
Page generated in 0.10718 seconds with 12 queries
