Traction Bars and ladder bars - S-10 Forum
post #1 of 12 Old 07-08-2004, 11:58 PM Thread Starter
Tsb-Xtreme's Avatar
User is: Tsb-Xtreme is offline
Send a message via AIM to Tsb-Xtreme
I need help decinding what is the best to go for i have seen the traction bars on trucks and i dont like the way they hang down and show underneath the truck and i heard that they make for a rougher ride but work great and i have seen ladder bars and i have heard good things about them and i like how they a kinda hidden up in the frame but i cant find a company that makes ladder bars for my s-10 it is a 2002, 4.3 L , 2WD, extended cab, fleetside xtreme if you could tell me where i might be able to find them ither the traction bars or the ladder bars and you oppion on both it would be greatly appreciated.
02s-10 Xtreme 4.3V6 Extended cab SHOW: SS Hood,SS mirrors, Chrome gas door,EuroTaillights,clear coners, Chrome Bowtie,SS Chrome Grill,XtremeGauges,Bedrug,Tonneau Cover,Streetglow Tubes X 10,High And Low Bulbs By Nokya(Arctic White, 120W, Custom Switch Box, Rollpan,Diamond Plate Floor Mats Go:HT-PPIII,K&N Gen 2 Intake,40 Series Catback Dual Side Exhaust,Granatelli MAFS Cross Drilled Rotors,Cal-Tracks,MsD Wires,Flex-A-Lite Electic fans
post #2 of 12 Old 07-09-2004, 02:01 AM
Un-Blown Fake ZQ8
s10rz350's Avatar
User is: s10rz350 is offline
Re: Traction Bars and ladder bars
http://www.calvertracing.com/
These are what you want. Expensive but worth it. They're better than lakewoods etc..
Truck is gone...
s10rz350 is offline
post #3 of 12 Old 07-09-2004, 10:41 AM
stippy32's Avatar
User is: stippy32 is offline
nothing beats the caltracs
you can see them but they arent intrusive, work amazing, and you arent going to be dragging them like you think you will
easy to install, alot easier than making the ladder bars work
98.8 hp and 120lb/ft
#32 FSP
98 s-10 2.2 5spd, centerforce clutch and plate, Volant intake, Jet stage 1, Borla exhaust, Belltech/ZQ8 3/4drop, zexel LSD,caltracs, 17" Colorado Customs, 245 front, 275 rear
stippy32 is offline
post #4 of 12 Old 07-12-2004, 03:33 PM
got bags?
1ofakind's Avatar
User is: 1ofakind is offline
Send a message via AIM to 1ofakind
yea ldder bars are the shit they work and they dont scrape if ya got a 3'' drop in the rear and run 16's with 50 series tries u CANNOT fit traction bars at all they scrape and give lesss then 1/2 clearance!
1ofakind is offline
post #5 of 12 Old 07-12-2004, 03:37 PM
It worked for Superman
Grinch78's Avatar
User is: Grinch78 is offline
Send a message via AIM to Grinch78
I love my Caltracs. I do occasionally scrape on high speed bumps but thats about it. I have a 4 inch drop in the rear so if your extreme isn't dropped you will be fine. Make sure you get the low profile version though.
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning." ~Rich Cook
Grinch78 is offline
post #6 of 12 Old 07-12-2004, 03:57 PM
98layinframe's Avatar
User is: 98layinframe is offline
Send a message via AIM to 98layinframe
if i may just add that it all depends on the type of setup you have in the rear. if you do a 3" drop with 3" leaves, then yes you can run traction bars, or what ever. if you lower the rear with a 3" or 4" block, then noyou can not run a traction device, it will hang way to low.
post #7 of 12 Old 07-12-2004, 04:12 PM
Un-Blown Fake ZQ8
s10rz350's Avatar
I have 3" leaves no clearance probs with lakewoods. Even ran them with 1" blocks for a while and clearance wasnt an issue with 245/50/16's.
I'd rather have the caltracs though. $$ needs to go elsewhere first though.
Truck is gone...
s10rz350 is offline
post #8 of 12 Old 07-12-2004, 04:59 PM
Grinch78's Avatar
I got mine for $300 flat. He didn't charge me tax and no shipping because I went to go pick them up.
Grinch78 is offline
post #9 of 12 Old 07-24-2004, 05:02 PM Thread Starter
Tsb-Xtreme's Avatar
How much are the caltracks and dose anyone know where i can get them for cheep
post #10 of 12 Old 07-24-2004, 05:06 PM Thread Starter
Tsb-Xtreme's Avatar
Can you use the same caltrack if you decide to get a 2 or 3inch Drop kit or do you have to get a new set of them if you decide to drop your truck
post #11 of 12 Old 07-24-2004, 09:04 PM
stippy32's Avatar
$325 for caltracs, there are some knockoffs but they arent built anywhere NEAR as well as caltracs are. Well worth the price.
There shouldnt be any problem with dropping after you get caltracs, the length wont change much. the only difference would be the front bushing if you drop with leaves. You have to use a solid bushing that comes with the caltracs. Just ask them to send you BOTH sizes for S10's. They changed the bushing size and the drop leaves might have the smaller size.
#32 FSP
stippy32 is offline
post #12 of 12 Old 07-25-2004, 06:11 AM
Grinch78's Avatar
My bushings on my truck were 1.5in I believe. Which is the smaller size and I have a 2001 with Belltech drop leafs.
Grinch78 is offline
