tool needed for bleeding brakes - S-10 Forum
post #1 of 7 Old 07-09-2006, 04:39 PM Thread Starter
User is: trigger is offline
Does anyone know where I can pickup a combination valve depressor tool(J-39177)?
What does everyone else use to bleed their ABS brakes?
Thanks
92 S10 Blazer 4.3 vin.W, STOCK no mods, Automatic
trigger is offline
post #2 of 7 Old 07-09-2006, 04:45 PM
Low in Alaska
Alaska's Avatar
User is: Alaska is offline
Re: tool needed for bleeding brakes
11 mm and a buddy?
Danny
S-Clusive-Alaska Chapter
Alaska is offline
post #3 of 7 Old 07-09-2006, 05:01 PM Thread Starter
Originally Posted by hombre_in_atlanta
11 mm and a buddy?
Nope, there is a tool that is used to open the valves in the ABS system so you can bleed the WHOLE system, not just the lower half.
P.S. Mine is a 10mm wrench size
trigger is offline
post #4 of 7 Old 07-09-2006, 09:03 PM
Low in Alaska
Alaska's Avatar
it probably is a 10 mm....but i see what you're sayin, now...i donno that answer:donno:
Danny
Alaska is offline
post #5 of 7 Old 07-18-2006, 09:51 PM Thread Starter
Home > Vehicle Repair > Brake Tools > OTC (OTC7853) Proportioning Valve Depressor for ABS Brake Systems
Proper service procedure requires that a proportioning valve depressor on the 4WAL unit when pressure bleeding the brake system. For best results on 4WAL, use two of these depressors, one for each valve. Services a wide variety of GM utility vehicles, vans, and pickups with Kelsey Hayes anti-lock brake systems. Also works on RWAL systems and must be installed on the proportioning valve (only one depressor required for RWAL). This tool supersedes Kent Moore No. J-35856.
Availability: Usually ships the next business day.
OTC-7853$21.31
trigger is offline
post #6 of 7 Old 07-19-2006, 11:46 AM
xSlammed S10x's Avatar
User is: xSlammed S10x is offline
Send a message via AIM to xSlammed S10x
use the brake pad and c clamp it so it compresses
post #7 of 7 Old 07-20-2006, 12:41 AM
User is: patpatpat is offline
Go to summitracing.com and get speed bleeders. You can bleed your brakes by yourself! you just take the old brakes screws out , put the new ones in. and just start pumping the pedal. Run you 30bucks or so. But you can bleed your brakes as much as you want, anytime you want!
97 gmc sonoma. 4.3L "X" 2wd Auto .
Reg cab w/ a long bed. Body Lifted PA: 2". Monroe Sensa-Trac.
Egr/ TB mod, Drop-in K&N .
Flowmaster, Edelbrock TES system w/ Y-pipe
235/75/15 tires, looking good !
