Tire sizes - S-10 Forum
post #1 of 14 Old 11-01-2012, 07:13 AM Thread Starter
Should've had a V8.
s10_2.8's Avatar
User is: s10_2.8 is offline
Tire sizes
Okay something that I never figured out: What are the differences in tires?
IE- 195-75x14 vs 195-75x15, or even 195 75x16?
What 15" or 16" is the same size as 215 75x14?
FS: First Gen brake lights, 4.3 TB, 2.8 intake manifold, 2.8 air cleaner housing, heater core shroud, first gen sun visor.
Click the name for the thread.
1992 s10 "Old and Un-faithful" 3.4L RIP
1995 s10 "What the hell, it runs?" 2.2L Long Bed RIP
1996 Saturn SL2, 2000 SL TWIN PILES OF CRAP
s10_2.8 is offline
post #2 of 14 Old 11-01-2012, 10:07 AM
xmbreezy's Avatar
User is: xmbreezy is offline
Example. 245-50-15
245-width of tire
50-height of tire
15-wheel size
Go to tirerack.com and it will explain the tire size.
94 S10-LS1/T56 Swap
01 Bravada- Daily Driver
xmbreezy is offline
post #3 of 14 Old 11-01-2012, 12:14 PM Thread Starter
Should've had a V8.
s10_2.8's Avatar
Re: Tire sizes
what I mean is like, 195 75 14, that's an inch shorter than 195 75 15 right?
or, a 205 75 15 would be the same height more or less than a 215 75 14?
s10_2.8 is offline
post #4 of 14 Old 11-01-2012, 01:08 PM
ukyank73's Avatar
User is: ukyank73 is offline
ukyank73 is offline
post #5 of 14 Old 11-01-2012, 03:34 PM
goin broke but n style
S15vortecpwr's Avatar
Re: Tire sizes
if you have now 195 75 14 tires and you go to a 195 75 15 tires, the only thing that has changed is the wheel size. the tire itself is the same height/width.
the last number (in this case 14 and 15) is your wheel size.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #6 of 14 Old 11-01-2012, 03:48 PM
MEP1's Avatar
User is: MEP1 is offline
Re: Tire sizes
Example: 195/75R14
195 = tread width in millimeters
75 = sidewall height percent in relation to the tread width
14 = wheel diameter
Those numbers don't relate directly to the overall diameter of the tire like a 31x10.5R15 does. A 31x10.5R15 is always 31" in diameter. You HAVE TO use a tire size calculator like the ones linked. S15vortecpwr's explanation might be a little confusing - the numbers don't determine the overall height or diameter of the tire, just the height of the sidewall.
MEP1 is offline
post #7 of 14 Old 11-03-2012, 11:10 PM
9" racing glass pack
MotorNut123's Avatar
User is: MotorNut123 is offline
Re: Tire sizes
the differences in those are the size where the rim goes.
195= width of tire
75= sidewall height
16= rim size
for example a 195/70/15 will have a thinner sidewall than the 75.
its confusing at first but just put it in the terms i labeled above. dont worry about percents or any of that. unless your trying to squeeze a big tire into a space where it requires certain dimensions.
for me, mine came stock with 205/75/15. im planning on doing a 2/3 drop, so im gonna go with a 215/70/15.
a little wider, and a little bit shorter sidewall. i want a little wider to make a different look, and of course a little bit shorter sidewall for clearance and no rubbing.
PROJECT THREAD>
http://www.s10forum.com/forum/f30/my...-piece-508137/
1995 Chevy S10 Extended Cab LS
5 speed V6 Vortec (VIN Z) 2WD
S10's FTW!
I would gladly go shove your truck into the garage of a capable mechanic
post #8 of 14 Old 11-04-2012, 12:18 AM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
Re: Tire sizes
I think MEP1 pretty much covered it.
TelAmeriCorp
post #9 of 14 Old 11-05-2012, 08:03 AM Thread Starter
Should've had a V8.
s10_2.8's Avatar
Re: Tire sizes
yeah, it clicked lol. thanks guys!
s10_2.8 is offline
post #10 of 14 Old 11-05-2012, 08:12 AM Thread Starter
Should've had a V8.
s10_2.8's Avatar
Re: Tire sizes
okay, take that back. here is what confused me:
195 75 14:
Overall diameter: 25.51"
Circumference: 80.14"
revs per mile: 815.3x
195 75 15:
Overall diameter: 26.51"
circumference: 83.28"
revs per mile: 784.5x
that means that the 195 75 15 is an inch taller overall, which is what I had originally thought
s10_2.8 is offline
post #11 of 14 Old 11-05-2012, 08:24 AM Thread Starter
Should've had a V8.
s10_2.8's Avatar
Re: Tire sizes
according to the calculator, a 195 70 15 would be close to my 195 75 14, while a 195 75 15 would be 3.8% bigger.
got what I needed guys! I bought 15" rims and wanted something similar to what I have now, maybe a bit bigger than what I have.
what size tires are you guys running?
s10_2.8 is offline
post #12 of 14 Old 11-05-2012, 10:43 AM
Re: Tire sizes
I am running 235 70 15 (stock) on the blazer
I am running 265 70 16 on the 94 (stock was 205 75 15) on the 94, hopefuly fixin to be 285 75 16
post #13 of 14 Old 11-05-2012, 05:56 PM
Fronk-en-Steen
mostizzle's Avatar
Re: Tire sizes
Dude, enough with the double, triple, quadruple, quintuple posts already, holy hell.
TelAmeriCorp
post #14 of 14 Old 11-06-2012, 12:03 PM Thread Starter
Should've had a V8.
s10_2.8's Avatar
Re: Tire sizes
I think of stuff after I post, and the edit option doesn't work for me lmao
s10_2.8 is offline
