S10 Blazer Xtreme C6 Z06 Corvette Brakes!! - Page 7 - S-10 Forum
post #301 of 364 Old 06-04-2008, 11:45 PM
Those crazy ass dogs!!!
01cherryreds10's Avatar
User is: 01cherryreds10 is offline
Re: S10 Blazer Xtreme C6 Z06 Corvette Brakes!!
Ya know, right now I wanna give you a big kiss.
Now, will I have to get a modified hub from the member on here that does them? I would assume so considering the hub was built into the S10 rotors, as the F-body rotors are just rotors.
01' Ext.Cab sold and dont miss it
79' Malibu LQ4/4L70e 11.23@118 1.50 60'
07' Silverado 1500 Classic
post #302 of 364 Old 06-05-2008, 12:05 AM
Molon Labe
BudRacing's Avatar
User is: BudRacing is offline
Send a message via AIM to BudRacing
http://www.s-seriesforum.com/forum/s...ad.php?t=71837
post #303 of 364 Old 06-05-2008, 12:12 AM
THANK YOU!!!! Just found the awnser I was looking for.
Originally Posted by ebmiller88
OK fellas, let's give a bit more info to you. Pics of the LS1 and C5 stock spindle specific setups are here: http://pg.photos.yahoo.com/ph/taram...ler72/my_photos
Both use a PBR dual piston aluminum caliper. The LS1s can fit inside a 16" wheel and are 12" x 1.25" thick. The C5s require at least a 17" wheel and are 12.75" x 1.25" thick. The calipers on these two setups will interchange with each other so you can "customize" them so to speak. I do know that you can fit a setup with a LS1 rotor and a C5 caliper (stronger of the two) inside a 16" wheel.
Now for the big one..The 13" Wilwood setup is seen here:
This setup uses the ZQ8 Blazer/Envoy spindle with the one piece hub, a Wilwood 4 piston caliper, and 13" x 1.1" rotor. This will give you all the stopping power you'll ever need.
E-mail me for more info and questions..thanks!
Ed
post #304 of 364 Old 06-05-2008, 12:24 AM
Professional Insultant
TokoDragon's Avatar
User is: TokoDragon is offline
Send a message via MSN to TokoDragon
pretty cool to actually see some people serious about road course track running s-series.
Not sure how it applies: But every 4th of july here the rally car club holds races for its members. Usually it's just cones set around a huge parking lot, but if you're a member they allow pretty much any vehicle type in. Last year we watched a fully loaded Police Tahoe cruiser with a k-9 unit in the back run through the course, kinda proved to me I really shouldn't be worried about ditching one of the police trucks if I had too. other than that they had all sorts of vehicles, from stock 90's imprezas, lotus espirit, to fully rebuilt 69 camaros a chevy nomad and saw a modified caprice wagon.
That's just a large local club, but I've also heard times where they open the tracks to the public for a fee they'll let you run your vehicles on them. Letting them compete in a road rally is a different story, but I'm sure some of these trucks could find a way in.
post #305 of 364 Old 06-05-2008, 12:37 AM
That's kind of the way I'm building my truck. The exception is, I won't be racing it on a course because I'm a very small guy, and I doubt I can keep up with the turns and pulling the wheel from left to right and vice versa so rapidly. I'm building my truck, so when someone gets in, they feel like it's not a truck, but a nice car. One that when/if they get to drive it, they actually want to keep driving it.
post #306 of 364 Old 06-05-2008, 10:22 AM
Blue-X
yz85608's Avatar
User is: yz85608 is offline
Originally Posted by ZZ4Blazer View Post
No, that is just the fronts, why I said, into front brakes, lol. Rears will be about another $600.
$1900 > 1500
Yeah that package included the front and rear.
yz85608 is offline
post #307 of 364 Old 06-05-2008, 10:29 AM
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
thats the worst excuse ive ever heard on why to not race it on a course.....
post #308 of 364 Old 06-05-2008, 11:31 AM
User is: SLStruckin is offline
In regards to the overkill comment. There is a threshold for most things, that a certain amount is overkill.
Frankly, your ultimate stopping distance is determined by the coefficient of grip your truck has on the road. This depends on the coefficient of friction of both the surface you are on, and the surface of your tires.
Not to give a lesson in physics here, but fundamentally, if on dry pavement, you can stomp the brakes and induce ABS, or induce lockup for those without ABS, then you've exceeded the threshold of grip. Now, rotors and calipers are very simple. The caliper presses on the rotor, causing again a coefficient of grip, as determined by the friction, between the two surfaces.
When the grip of the rotor on the disc, exceedes the grip of the tire on the road, simply put, your wheel locks up, or goes into ABS.
Now, obviously the inertia and force of the truck as it travels forward, greatly effect the coefficients, but thats why brake bias is generally ~70% to the front.
In terms of Blazers, and S10's- they are not Mack trucks, nore are they even close to a full size. They do not require the amount of brake force provided by corvette setups.
It has nothing to do with traffic, if somebody cuts you off- frankly thats your reaction time, and how quickly your foot moves to the brake pedal. If you're a slow ass tool, then C6 brakes wont save you.
Now, conceededly larger setups avoid brake fade, and are more tolerant of temperature, but unless you're driving Laguna Seca in 110 degree weather all day long, you again don't require that capability of fade resistance.
I whole heartedly agree, that Bear and SSBC setups, even changing S10's to the blazer 2piston setup, will improve your stopping distance over stock, given you aren't running the narrow ass 205 stock front tires.
I also conceede that larger diameter rotors produce more rotational inertia, however the primary culprit of that rotational inertia is the 18+inch x 8.5+ inch wheel with the big ass spokes and thick rim edges.
All that said- if you are running an LS truck, or blazer as it may be, or maybe you have some really whacked mid engine twin turbo shitsubishi setup, and your passengers asses get hot from the exhaust manifolds, or maybe you've crammed in a 572 that hasnt sipped pump gas since it was installed- then perhaps, just maybe, you'd warrent a C6 setup for the performance aspect.
Maybe you really do circle track your truck, perhaps you're trying to compete in the truck series.
If the above were the case, I doubt you'd be running such heavy beefy setups. Unless you are very lucky and get to go around Bristol, and can actually break 100mph on the straights without going straight into the wall.
But by in large, most users of the forum, don't drive in a manner that requires such a setup, unless they live in LA... I hear the cops out there have pretty quick cars .
So- why do it.
A: Because you have the money.
B: Because you weren't an idiot, and got some nice open spoke design wheels.
C: Because you think stock stuff looks, and feels like poo.
D: Because you want to be the first Sonovette.
and perhaps the biggest reason of all:
E: BECAUSE YOU CAN.
Now my personal take- since you all probably think Im jealous,
frankly, I'd love to do this setup, or even the SSBC/Baer setups, because they look damn cool, and I think the people who have done it, kudo's to you, I wish that GM would have made a 2nd gen Syclone style truck, or even that they would drop the piece of shit Colerado/Canyon, bring the S10 back out with a higher performance option, that had beefed up 4-wheel disc.
If people don't do it, and don't want it, the OEM's will never build it, why do you think they have reinvented the muscle cars 5x over, because people want it.
I love seeing S10's, and Blazers with big brakes, big pipes, and cool amenities, don't get me wrong its why I read this forum.
Ultimately, your grip on the road, your reaction time, and your decision making, will determine if you smash up your front end. I highly doubt that if Baer/SSBC brakes don't save you, that C6 setups would.
post #309 of 364 Old 06-05-2008, 11:37 AM
As an add, Im actually surprised the stock master + booster would provide enough volume and pressure to a C6 setup.
post #310 of 364 Old 06-05-2008, 04:54 PM
Well I'll try it once or twice
post #311 of 364 Old 06-05-2008, 09:18 PM Thread Starter
Undecided
redxtruck's Avatar
User is: redxtruck is offline
So- why do it.
E: BECAUSE YOU CAN.
better tires are better than better brakes, but both of them compliment each other well. and speaking from experience, the total feel, endurance, and look of these are remarkable. I don't know what the baer/ssbc brakes are capable of, but they are what everyone else has.
01cherryreds10- you might want to talk to bad94 about getting brackets, and if you want it to ride really good, get dbl adjustable shocks. I have the dble adjustable shockwaves, but im sure the coilovers will well also. Now for the rear suspension you will have to talk to cactus, i know he has done alittle bit of research on it.
oh yeah, i will get some new pictures soon
Red 04 Blazer Xtreme sold
Black 2003 Zr2
White 2008 Sierra Crew Cab Z71
Washington D.C. Steamfitters Local602 Member
post #312 of 364 Old 06-05-2008, 09:22 PM
It may have been mentioned, but does he also make the hubs?
post #313 of 364 Old 06-05-2008, 09:25 PM Thread Starter
Undecided
redxtruck's Avatar
i beleive he can
Black 2003 Zr2
post #314 of 364 Old 06-05-2008, 09:34 PM
Molon Labe
BudRacing's Avatar
I PM'd Bad94 about brackets almost a month ago and haven't heard from him yet.
post #315 of 364 Old 06-05-2008, 09:43 PM Thread Starter
Undecided
redxtruck's Avatar
no shit, well ed pops up on aim every once in a while. usually around 8pm eastern
AIM: ebmiller88
Black 2003 Zr2
post #316 of 364 Old 06-05-2008, 09:54 PM
s-series #2?
if any of you want to take the dimensions of the bracket, im sure i can machine them on the mill quite simply
post #317 of 364 Old 06-05-2008, 09:56 PM Thread Starter
Undecided
redxtruck's Avatar
you should design me link for my rear, i don't feel like it yet
Black 2003 Zr2
post #318 of 364 Old 06-05-2008, 10:36 PM
Molon Labe
BudRacing's Avatar
Yeah, do one for his---and I'll use it for mine too.
post #319 of 364 Old 08-03-2008, 04:31 PM
fmylife.com
LOW S-10's Avatar
User is: LOW S-10 is offline
Problems with backspacing in the front? or did you do a custom wheel?
LOW S-10 is offline
post #320 of 364 Old 08-03-2008, 04:47 PM Thread Starter
Undecided
redxtruck's Avatar
no problems. the corvette rotors slide right over the blazer hubs. if you use a turned down s10 rotor, you will have problems. about 1/2 and inch
Black 2003 Zr2
post #321 of 364 Old 08-03-2008, 05:02 PM
s-series #2?
so there is no float on the rotor?
post #322 of 364 Old 08-03-2008, 05:10 PM Thread Starter
Undecided
redxtruck's Avatar
right, there is a better answer in the other post
Black 2003 Zr2
post #323 of 364 Old 08-03-2008, 05:56 PM
s-series #2?
aha ill check that
http://www.s10forum.com/forum/f14/c6...lipers-363445/
this thread for other's reference
post #324 of 364 Old 08-03-2008, 11:27 PM
fmylife.com
LOW S-10's Avatar
What about the rear?
LOW S-10 is offline
post #325 of 364 Old 08-03-2008, 11:31 PM Thread Starter
Undecided
redxtruck's Avatar
small change. i had to add a 5mm spacer between the axle and rotor. the guy that made my brackets said that he has corrected the problem though. this is what happened
Black 2003 Zr2
post #326 of 364 Old 10-08-2008, 01:58 PM
fmylife.com
LOW S-10's Avatar
Anyone looked into ZR1 brakes lol?
LOW S-10 is offline
post #327 of 364 Old 10-08-2008, 03:16 PM
Insert witty title here.
bwhitfield24's Avatar
User is: bwhitfield24 is offline
The brakes alone would be worth more than the vehicle.... LOL go ahead and be the first one Robert!
post #328 of 364 Old 10-16-2008, 02:06 PM
fmylife.com
LOW S-10's Avatar
Hell no lol! Im afraid to even look for a price.... But, it would be pretty sick!
LOW S-10 is offline
post #329 of 364 Old 10-16-2008, 03:44 PM
From Corvetteforum.com
Originally Posted by Doctor Electron View Post
I know, I know; fronts are gonna be gone long before the rears and if you can afford a ZR1 are you really worried about the cost of brakes but here ya go anyway. These are GM wholesale pricing.
Front and rear rotors = $1,440.75 ea x 4 = 5763.00
Front Pads per wheel = $581.25 x 2 = 1,162.50
Rear pads per wheel = $441.75 x 2 = 883.50
Total 7809.00
Add about 15% for GM retail parts price = $8,980 for parts only. To see if you need rotors they have to disassemble the brake system enough to remove the rotor to weigh it. Each rotor has its own discard weight stamped on it. "NO sir, you don't need rotors at this point, that will 750 dollars labor, thank you very much" .So add in labor and tax and I am pretty sure you are getting out a ten thousand dollar bill to be paid in full. Getting GM wholesale pricing from GM parts departments is pretty easy. Get ya down to around 9 grand or so. So there ya go, for what it is worth.
Doc E.
post #330 of 364 Old 10-16-2008, 03:51 PM
http://forums.corvetteforum.com/show...ght=brakes+zr1
This guy is even selling a set. $5500!
post #331 of 364 Old 11-28-2008, 08:18 PM
C-130 Crew Dog
xxxotiknightz's Avatar
User is: xxxotiknightz is offline
Send a message via AIM to xxxotiknightz
I'd realy like to make my blazer into a good handleing and performing vehicle, cause I love hitting the twisties around here and just can't do it with stock brakes. Does anyone know if you can stil get this kit. I just want the fronts for now til I get some coil-overs made.
I'm not afraid to die, I just don't want to be there when it happens.
2012 Hyundai Veloster 6MT
2006 Envoy Denali 5.3V8 (stock) tow pig
post #332 of 364 Old 11-29-2008, 03:32 PM
BodyDropped Member
Kenny_Cox's Avatar
User is: Kenny_Cox is offline
Send a message via AIM to Kenny_Cox
Isn't this what you purchased? For the most part anyway?
http://cgi.ebay.com/ebaymotors/C6-Co...Q5fAccessories
Kenny Cox
"If women didn't exist, all the money in the world would have no meaning."
post #333 of 364 Old 11-30-2008, 09:21 PM Thread Starter
Undecided
redxtruck's Avatar
that would be a great start
Black 2003 Zr2
post #334 of 364 Old 12-02-2008, 11:02 AM
The Blown Blazer's Avatar
User is: The Blown Blazer is offline
I can't believe people are whining about an overpowered braking system. That's just like people bitching about an engine having too much power and spinning the wheels instead of acclerating w/o spin.
Z06 brakes ROCK
2000 black S10 Xreme auto v6 - stock on 20's "SLO S10"
2000 white S10 Xtreme auto v8 - unstock "FST S10"
post #335 of 364 Old 12-02-2008, 12:29 PM
BodyDropped Member
Kenny_Cox's Avatar
yeah I'd love to do this on my current project. Not only does it look absolutely kick ass, i am sure it performs just as well. Shame it's just too damn expensive to get everything done haha.
Kenny Cox
post #336 of 364 Old 01-12-2009, 07:39 PM
Killing Time
Petro's Avatar
User is: Petro is offline
Is Bad94 still making the brackets for front and rear?
Petro is offline
post #337 of 364 Old 01-12-2009, 07:47 PM
LT1 S10 Expert
User is: HectorM52 is offline
Yes, PM him.
I'll alert him if I catch him on IM.
post #338 of 364 Old 01-12-2009, 08:55 PM
Killing Time
Petro's Avatar
I just PMed him. Thanks
Petro is offline
post #339 of 364 Old 01-17-2009, 05:33 PM
Killing Time
Petro's Avatar
This setup is for Front C5 brakes but aren't the caliper mounting points the same for Z06 caliper ? Plus they have a pretty cool upper and lower control arm setup for QA1 coilovers..
http://www.spohn.net/shop/1982-2003-...-S-10-2WD.html
Petro is offline
post #340 of 364 Old 01-17-2009, 05:35 PM
Killing Time
Petro's Avatar
Nevermind it says that it'll work with C5/C6 brake setups..haha I jumped the gun on that one. Now all I'll need is the Rear Bracket
Petro is offline
post #341 of 364 Old 01-18-2009, 11:23 AM
Getting faster
ZZ4Blazer's Avatar
User is: ZZ4Blazer is offline
Send a message via AIM to ZZ4Blazer
Yes, those will bolt up any factory C5/C6 brake combo. I have those on my truck and a great investment if your after killer handling IMO. Went up in price though...
Jim 94 Stepside
New v8 combo coming
5/6 drop QA1/hotchkis
ATS tall spindle/14" Z06 brakes
6 speed / 8.5" rear
post #342 of 364 Old 01-18-2009, 01:10 PM
Killing Time
Petro's Avatar
Alright cool..does those spindles really drop the front an 1in like it says and they also claim that the spindles don't push the wheel out like Drop Spindles do.
Petro is offline
post #343 of 364 Old 01-18-2009, 01:13 PM
Killing Time
Petro's Avatar
Do you also have the lower control arms? I was wondering if they also dropped the front? (the ones the hold the stock springs.)The reason ask is because stock lower arms have the hump in them and these mount below the arm so it just seems by looking at them they would also lower.
Petro is offline
post #344 of 364 Old 01-18-2009, 01:17 PM
Killing Time
Petro's Avatar
Did redxtruck ever say what size wheel he was using and with backspacing-offset?
Petro is offline
post #345 of 364 Old 01-25-2009, 11:49 AM
Killing Time
Petro's Avatar
bump
Petro is offline
post #346 of 364 Old 01-25-2009, 11:50 AM
LT1 S10 Expert
I'm pretty sure he did.
You can search this thread - look up at the top of the page under the "page numbers" of the thread. It says "search this thread" then just enter his username. Show results by "post" not "thread."
post #347 of 364 Old 01-25-2009, 12:11 PM
Killing Time
Petro's Avatar
I couldn't find a post with any backspacing/offset spec on redxtruck but some 20" Eagle Alloy 025s should easily clear.
Petro is offline
post #348 of 364 Old 02-09-2009, 04:00 PM
Killing Time
Petro's Avatar
bump
Petro is offline
post #349 of 364 Old 02-09-2009, 05:07 PM
Molon Labe
BudRacing's Avatar
Post 14 shows a wheel fitment template link.
http://www.kore3.com/tech.php#fitment_templates
post #350 of 364 Old 02-09-2009, 05:12 PM
Killing Time
Petro's Avatar
Yeah I figured all the brake issues I could think of about the Z06 upgrade a lil while back..now I just need the money!!!! I was just giving the thread a bump for some guys that maybe hadn't seen it..
Petro is offline
