Resealing the Tire Bead - S-10 Forum
post #1 of 9 Old 06-16-2008, 11:41 AM Thread Starter
Urban Hick
Firm's Avatar
User is: Firm is offline
As some of you on here know I've recently acquired a 69 Lotus Europa...But I've had very little time to work on it. Anyway, I finally got to the first issue(flat tire), thinking it would be a simple fix....Wrong! It has some aftermarket alloys on it(made in Australia) that look ok for now so I'd like to keep them. The problem is, the front left rim leaks right along the bead....I tired putting some of that tire sealant crap in it for now....but it's still leaking at both the face side and backside of the rim.
How can I get this fixed?? I'd like to keep the tire for now if possible, it will need new tires once i get it running and driving...but for now all I need is for it to hold air. I thought about removing the tire, and cleaning the bead on the rim, and then re-installing the tire....would that work??
Any other thoughts?
1978 MGB, 1984 Camaro, 1985 Trans Am, 1996 Firebird, 2000 Sonoma ZQ8, 2001 M-Benz SLK320, 2006 Cadillac Escalade
www.doubleclutch.ca
Firm is offline
post #2 of 9 Old 06-16-2008, 11:49 AM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
Re: Resealing the Tire Bead
yes, that will work.... what i usually do is remove the tire, clean up the bead surface, and remove any heavy debris from the tire bead, and apply some bead sealer to the rim.... if you put tire sealer in there.... get it out! that stuff will ruin the rim from the inside out.... its only supposed to be temporary til u can fix the leak
post #3 of 9 Old 06-16-2008, 11:55 AM Thread Starter
Urban Hick
Firm's Avatar
Thanks...I'll do that.
www.doubleclutch.ca
Firm is offline
post #4 of 9 Old 06-16-2008, 12:09 PM
oneone3's Avatar
User is: oneone3 is offline
Send a message via AIM to oneone3
tube
oneone3 is offline
post #5 of 9 Old 06-16-2008, 09:33 PM
jwykes's Avatar
User is: jwykes is offline
Send a message via MSN to jwykes
I came across that tire sealer crap this week at work, and man it was TERRIBLE, probly a few months old, I probly spent an hour spraying it with duca-sol and a pressure washer, and it smells like ass once you bust the bead. I would rather call a tow truck then use that stuff in my tires
10 Silverado ECSB. 5.3L. 6L80E. 2wd. Airaid CAI. TSP 220R @ 112LSA. PRC 243's Milled 0.035". Trunion Upgraded Rockers. ASP UD Pulley's. Mike Norris Catch-Can. Pacesetter LT's /w ORY. Magnaflow Exhaust. Black Bear Tune. Detroit Locker /w 4.10's. Circle D 278mm 3000 Stall Converter. 2-Piece DSS Conversion. 3/5 Belltech---- DAILY DRIVER
jwykes is offline
post #6 of 9 Old 06-16-2008, 09:36 PM
Negative 10
illest G's Avatar
User is: illest G is offline
take the tire back off.
tank some sand paper.
sand the shit out of the beed on the rim.
make sure there are no flakes and everything is smooth
then spread a bunch of bead sealer on the rim.
and put the tire back on.
~KENNY~
MY GAL---->PROJECT THREAD<----MY GAL
illest G is offline
post #7 of 9 Old 06-16-2008, 10:02 PM
The Eye is watching you!!
kamesama980's Avatar
User is: kamesama980 is offline
Send a message via AIM to kamesama980 Send a message via Yahoo to kamesama980
most tire shops will clean the bead for 10-20 bucks and about 10 minutes. if it's really bad they'll throw bead sealer on there. that even works on chrysler chrome rims.
-Russell
1990 Toyota Cressida 7MGE 3l I6/5-speed manual
1987 S10 2.5 not even power brakes it's so base model
"You don't get to judge me for how I fix what you broke."
read this and obey or face my wrath
post #8 of 9 Old 06-17-2008, 01:00 AM
yourname's Avatar
User is: yourname is offline
yeah.. lol chrysler's joke of chrome. but the fix a flat crap ruins the tire because it softens it up and can also start to eat the rim.
94 sonoma aka pinky- 5.3 swap. Fully bagged Winter plans bag on bar 4 link and fully shaved/new paint
08 silverado CC 4x4 murdered out daily
yourname is offline
post #9 of 9 Old 06-17-2008, 10:12 AM Thread Starter
Urban Hick
Firm's Avatar
Thanks guys....I'll see if I can get a shop to do it that cheap...If so I'll let them do it...save me some aggrivation.
I didn't use 'fix a flat'....it was just the goopy stuff you put in there to seal slow leaks, not in an aerosol or anything. I will take it out though just in case, not that it really matters with this car.
www.doubleclutch.ca
Firm is offline
