#101 |
simple 5.7
Will the blazer rear end be swap into a 1989 S10 truck, and what year blazer would work???
#102 |
Location: Chester (Home of Popeye), IL User is: OffLine ![]() |
Re: rear disc brake conversion on 99 X
#103 |
1 QUESTION TO ANYONE WHO HAS DONE THIS SWAP.. does this make your rearend wider at all? and is it different for the ls1 or lt1? I really need it to stay the same size.... thanks
#104 |
Still waters run Deep
^^ Good question. Also, I'm looking at getting a LS1 rear-end off of a 2001 Z28 with 3.42's, but since it is off of a manual Camaro, it has no traction control. Should this be a concern or does it not make a difference? Thanks
#105 |
The distance between the rotor center line, and the rear end housing mounting flange (where the caliper mounting brackets bolt up) on a truck is different than that on a blazer. I don't know if the same rules apply for the LS1 / LT1 brakes. Maybe someone who has done that swap could shed some light on it. Hope that clears things up. Last edited by powerhungryv8s10g : 04-14-2004 at 08:31 PM. |
#106 |
hey everyone ... yes my computer did crash. i do still have the how to mentally if you guys are interested. Basically goes like this:
-open rear pumpkin and drain -remove all brake drums and springs, etc. -remove axles - there is a small gold colored bolt running left to right. that gets loosened and the big gold circle will come out (actually a big rod) --- DO NOT TRY TO REMOVE THE BOLT !!!. Push the axles IN and a c-clip will come out for each axle. Pull the axles out -remove the 4 bolts per side to take the drum backing plates off -install the ls1 or lt1 disc backing plates -reinstall the axles in reverse from above -reinstall the rear end cover and seal and refill -put on the rotors -put on the calipers and pads - caliper rubber hose screws directly on the metal brake line -put on the wheels -fill and bleed brake system As a side note, the rear discs WILL push your rear wheels out about 1/8" - 1/4" or so Hope that helps guys Last edited by Onyx02XCabX : 04-14-2004 at 09:11 PM. |
#107 |
#108 |
the camaro read end is wider than the s10 by a couple of inches on each side. Also, you will have to weld leaf spring perches to the axle. If you even barely don't get it right, u joints will suffer. As for the internals if that is what you wanted, they will fit in the s-10 rear end.
You do not want the tration control rear end anyway. |
#109 |
Black & Red
Location: All over the US, from New Orleans User is: OffLine ![]() |
So the Blazer/Jimmy rearend set up is different from the S10/Jimmy. But that doesn't change anything as far as swapping to LS1 or LT1 disc, right? All the brackets and stuff should be the same on the ends? Just different axles and housings.
#110 |
#111 |
i read threw about 20 of the 110 post and still didnt see my answer. Wil this work on the 84-? models. i think they are a first gen...im to tired. w/o swaping axels or anything i want to add. thanks justin
#112 |
With that said, ALL the S-10 rear axles are the same (identicle w/ very minor changes) from the first one, to the last one. Same design that is in the camaro. If you have the same design rear end in nearly every rear wheel drive vehicle you make, it becomes very easy (and cost effective) to tweek the design to fit a particular application. Modifying only length, width, or highth, and the way it is attached to the different vehicles. Are you following me on this one? Brakes have they're own design, drum, disc w/ parking brake integral calipers, disc w/ drum type parking brake, ect. So to make these brake designs fit a rear end design that's in nearly every vehicle you make, Say it with me....You make all the different brake designs mount to the rear end design. Which is especially lucky for us when it comes time to upgrade to better brakes! Happy brake upgrading!! Last edited by powerhungryv8s10g : 04-20-2004 at 09:19 PM. |
#113 |
Road Race/Auto X S10
Location: South Milwaukee, WI. User is: OffLine ![]() |
93-97 Rear Disc Brake Conversion Package
Convert to the simple to use and install 11.7" rotor and aluminum floating caliper system. Requires 16" wheels for most applications for brake to wheel clearance. The package includes the following used parts to complete a conversion. You may require cutting & drilling on an axle tube to install the mounting brackets & the assembly of custom brake lines (Not included). Please check with a sales rep for modification information. 1 pair used rear 93-97 brake rotors. 1 pair used rear 93-97 PBR aluminum brake calipers, and floating brackets. 1 pair used rear caliper mounting brackets. 1 pair used emergency brake cables. Price - $150 used. 98-02 Rear Banksia Brake Conversion Package Convert to the best braking system available. Uses a thick 12" rear brake rotor with an integral parking drum for unsurpassed braking performance and reliability. Package includes the following used parts to complete a conversion. Requires 16" wheels for most applications for brake to wheel clearance. Includes the following used parts to complete a conversion. You may require cutting & drilling on an axle tube to install the mounting brackets. Please check with a salesman for modification information. 1 pair used rear 98-02 brake rotors/drum hats. 1 pair used rear 98-02 PBR aluminum calipers. 1 pair used rear caliper/parking brake mounting brackets. 1 pair used drum brake parking shoes & associated hardware. 1 pair used emergency brake cables & cable mounting brackets. Price - $200 used. http://tacreationsusa.com/suspensi.htm Last edited by 96s10 : 04-21-2004 at 06:34 PM. |
#114 |
Crossroads Customs
Location: Baton Rouge Louisiana User is: OffLine ![]() |
bump with a question. i was looking at a camaro a few days ago and thought about this swap, but figured i would be impossible, then i searched and found this thread, so i'm doing it soon. i work at a body shop and my boss has a wrecked 96 transam with lt1 and 6 speed (no traction control, right??) and also a 99 camaro z28 with LS1 and auto (traction control???) the camaro is really bad and the brake rotors are sheared off half way, so which one should i use? i know the ls1 cars had better gear, but would it be worth it if the rotors are messed up that bad? i'm doing this to a 99 with a 5 speed. i might just throw the gears in there too while i'm at it, since this 2.2 isnt going to be in for long. opinions?
#115 |
I hate you
Location: Castle Rock, Colorado User is: OffLine ![]() |
Is it also true that this swap kicks your wheels out a 1/4" on each side?
#116 |
Crossroads Customs
yeah, it pushed the wheels out 1/4. can someone explain traction control to me, its like electronic limited slip right? what gears come in the camaro tbird rearend, i can swap those in too right? are they posi?
#117 |
hey oynx... new to the site but you seem to be the man to talk to on this thread! hey i found these on partsamerica.com....i searched under '02 camaro z/28 and found reman calipers with the brackets for $61 apeice...will these work?
http://www.partsamerica.com/ProductD...e=5003&ptset=A any help is appreciated, i'm going to do these this spring once it warms up here in ohio. oh and also, did you say you could also purchase the camaro brake lines to work with this? i'm assuming it would be the lines from the block on the axle out to the calipers? am i correct? thanks! |
#118 |
rusty bumper member
dude this thread is really old! Awesome thread though...i'm going to have to pull the rear brakes off the firebird in my local junk yard now
#119 |
Is it done YET?
Hey guys, me and my buddy both have a set of these f-body rear brakes for sale...
#120 |
rusty bumper member
so if im reading this right...i can find a 4x4 s-10, or blazer with disc rear brakes and take off the rotors, calipers, and mounting plates, and just bolt them on my truck?
#121 |
Killer Turtle
Hey guys, new to the group. Lots of info here!!! Too cool and thanks so much!
Now my Q: I am starting a V8 swap into a 94 S10 and definately want rear disc. Have an uncle that works for NAPA and get my parts for COST, Rightous! Since the swap works on the rear, will the bigger F-body front brakes swap out as easily? Or do you know of such a conversion kit to swap out the calipers and rotors? Just in case this has been posted already, sorry. Don't flame me please. TIA!!! |
#122 |
i just upgraded my rears to c5 brakes using the brackets off of ebay and my caliper cage is super close to the backside of the rotor. just wonderin if this is normal? about how much space is susposed to be between the rotor and the cage?
#123 |
Onyx02XCabX, could you send me those pics and instructions aswell... Was looking into the swap for my blazer jus wanna see what im gettin into.. Thanks
xtr3mehe4t@yahoo.com |
#124 |
Wow this thread was brought back to life
I have long since purged the info from my numerous computers over the time. The "how-to" in this thread is still accurate.This really is a straight forward bolt-on conversion. I live in the DFW area now so if anyone is in the area nad wants to meet up, I can show you what you mess with on your truck. Also, depending on the weekend, I would be willing to help. |
#125 |
N pieces
eBay Motors: Firebird Camaro Monte Carlo SS GN S10 rear disc brake (item 220106520419 end time May-02-07 09:21:15 PDT)
won't these work on a newer rear end |
#126 |
which is easier(more straight forward, i guess)....modding the existing e-brake cable or replacing the cables with the Camaro/TA cables? Starting to check bone yards and when i find a car I only want to make 1 trip
#127 |
You can buy a rear drum conversion kit from SSBC but it will run you between $700-$800. But you don't have to worry about the bulls**t. Bolts right on
#128 |
Molon Labe
I'd rather save $400 and worry about some BS. And keep my parking brake.
#129 |
#130 |
Location: Houston/Baton Rouge....SicRides User is: OffLine ![]() |
I know old post..
I think I got most of it figured out, but my only questoin is. oynx... when you say ls1 or lt1 disc backing plates. Do you mean "caliper brackets"? Thanks Steven |
#131 |
I am planning this swap for this fall when i put in the zetel diff and new gears. figured if I have it all apart then.....
plus they will go good with me 12" front brakes I am putting on later this month. (B-body spindles and 1LE rotors with some global west arms. |
#132 |
More Go then Show
LS1 Camaro Rear Disks!
