Rear brakes LOCK UP when wet? (ABS Pulsate feeling) - S-10 Forum
 1Likes
  • 1 Post By hi_im_sean
post #1 of 42 Old 03-17-2008, 04:33 PM Thread Starter
98' Cowl Induction
GiveMeBreak's Avatar
User is: GiveMeBreak is offline
Send a message via AIM to GiveMeBreak Send a message via MSN to GiveMeBreak
I had asked about this 2yrs ago, and my brakes still do this.
Now its getting annoying and a little worse.
Please take a minute to read what I have here before replying.
Alot of comments on other threads are a layer of rust builds, and
that can't be the case in only a few hours time. Thanks
- This ONLY happens when its raining.
- The truck can sit for less then a few hours and it can do this as well.
- Take off, give it the brakes and the rear tires lock up.
- This is a Pulse (ABS) type lock up, NOT a solid lockup to complete stop.
It's simulating a ABS situation, where the rears pulsate, then you here the ABS module release, then its does it again, and so on until you stop or let go of the brakes.
I have seen TONS of threads on this, but nobody giving a clear answer as to what the issue is.
I see alot of, "it's normal" answers, which it may be VERY normal to these
trucks, but its far from normal..lol
Where are the ABS sensors? Only on the front wheels?
I am wondering if when our ABS sensors get wet they give off a false reading?
This brake issue only lasts a few minutes then it goes away until the next cycle of sitting for a few hours.
Thanks for any input!
post #2 of 42 Old 04-11-2009, 02:59 PM Thread Starter
98' Cowl Induction
Re: Rear brakes LOCK UP when wet? (ABS Pulsate feeling)
bump? anyone
post #3 of 42 Old 04-11-2009, 03:27 PM
'01 Noma
shift220's Avatar
User is: shift220 is offline
I would guess its just surface rust on the drums. It doesn't take as much time to rust as you think. An hour is enough time for a thin layer. I believe the sensor for the rear wheels is located on the end of the transmission. Not sure if its the same one used for your speedo but it could be.
shift220 is offline
post #4 of 42 Old 04-11-2009, 04:43 PM
Slap my meat on your pita
GeorgesBlazah's Avatar
User is: GeorgesBlazah is offline
Mine are really touchy after it rains for the first stop. After that its fine. Ive learned to deal with it, but it sucks.
Oh and Welcome Back, I havent seen ya post in forever
George
98 Blazah 6in SL - 2in BL - 4.56s - Detroit ITS AN ANIMAL 4x4 BUMPER. IT IS NOT MADE ANYMORE, BUT YOU CAN BUY MINE FOR $6000
BLAZER PICS AND INFO CLICK ME
Founder/Godfather of the Anti-Bag Coalition
"Bags are for groceries"
post #5 of 42 Old 04-11-2009, 05:16 PM
goin broke but n style
S15vortecpwr's Avatar
my 94 does the same thing, but my 01 does not. once you apply the brakes the first time it locks them up, ut than fine after that.
things i have done, readj the shoes, changed brake fluid, actualty swapped drums from side to side, still no fix. I have just gotten used to it. But I am sure there must be an answer somewhere.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #6 of 42 Old 04-11-2009, 06:51 PM
Registered Un-dependent
Mechnix's Avatar
User is: Mechnix is offline
Mine too, my 1994 never was like that and I backed the drums below water every time I launched my boat...
Mine are the front grabbing but it might be possible to mistake that for the rear? or the front grabbing activates the ABS? Do you hear the ABS come on?
Mechnix is offline
post #7 of 42 Old 04-12-2009, 01:09 AM Thread Starter
98' Cowl Induction
I have been busy working on my foxbody cars and not so much with the S10 lately, just been driving it. I pop in her from time to time but your right I haven't posted as much. I need to stick around somemore!
Seems like alot of us have been just living with it. I know I have for years now. Just sick of it. If you forget to dry the breaks out after you first get in, holy crap is it an awakening when you can't stop!!
Its definitely the rears locking up and its triggering the ABS, no light comes on but you can hear the ABS pulsate. Just sucks and annoying as hell.
My wife won't drive it for that reason alone.
post #8 of 42 Old 04-12-2009, 05:58 PM
ohio420jb's Avatar
User is: ohio420jb is offline
my 91 was doing this, even after changing them. I changed them again last week but instead of getting advances cheapest set, I got the next step up. Problem solved so far.
post #9 of 42 Old 04-13-2009, 11:23 PM
radman3120's Avatar
User is: radman3120 is offline
Send a message via AIM to radman3120 Send a message via Skype™ to radman3120
my '94 is very touchy the first time you apply the brakes any time after sitting for a while no matter if its wet or dry. if i pump them before i pull out its better, though. i think it may be normal for these trucks. the early abs is absolutely horrible. i feel so much safer with mine not working now than when it was "working." any time it was wet it would activate too much and not let me stop. the only thing that makes me wonder is that mine woudnt ever change like you say yours goes away after a little bit
post #10 of 42 Old 04-14-2009, 12:34 AM
My ABS deosnt engage. The brakes just grab really hard, but I know when it comes and I usally dont apply the brakes hard enough when im moving slow enough for them to act up. 5spd ftw.
I would assume though that if I would stay steady on the brake pedal when I was braking that it would engage.
George
post #11 of 42 Old 04-15-2009, 10:41 PM
Drewchillin's Avatar
User is: Drewchillin is offline
my truck does it two on the front bad when they get wet scares me
post #12 of 42 Old 04-16-2009, 07:06 PM
bigbads10's Avatar
User is: bigbads10 is offline
My 96 s10 does this, every time its wet and when i first use the brakes they lock up! it pisses me off. But when the roads are wet or i go thru a puddle they lock up and make a odd noise, the pedle gets hard and when the truck slows or stop it gets soft? its dumb that they do it but nothing i can do.
James
96 s-10 355 4 speed muncie
89 s15 "judgment day"
91 s-10 355 turbo 350 trans
post #13 of 42 Old 04-16-2009, 11:26 PM
Nevada: Hookers & Poker
S-10_man66's Avatar
User is: S-10_man66 is offline
Mine doesnt do it. But I did have a ford that did it every time it rained freaked me out the first time it happened
97 GMC SONOMA ZQ8:Totaled.
94 Chevy S-10 Blazer 4x4: Daily.
post #14 of 42 Old 04-17-2009, 12:20 AM
User is: cwk08 is offline
my 94 sonoma does it in the front bakes wet or dry and makes me go all over the road i looked up the recalls for it and turns out there was a recall on the abs
cwk08 is offline
post #15 of 42 Old 04-18-2009, 10:42 AM Thread Starter
98' Cowl Induction
Well I blew a crap load of dust out, cleaned them all up, readjusted them. Lets wait for rain now and see.
post #16 of 42 Old 04-21-2009, 08:40 AM
User is: xXs10Xx is offline
yea i have the same problem.
i just put on new front pads and rotors and bearing less then 5k ago
also cleaned and adjusted rears and this still happens
any idea?
xXs10Xx is offline
post #17 of 42 Old 04-21-2009, 10:09 PM
adamwilkes20's Avatar
User is: adamwilkes20 is offline
I dont know how relevant it is to this thread, but I had bad rear wheel lock up on my 91, I pulled the right rear drum and it was packed with brake dust...I got some brake cleaner and cleaned them up really good and it hasnt done it since...I dont understand why there was so much brake dust in there I had good clearance between the shoes and the friction surface of the drum
post #18 of 42 Old 04-22-2009, 10:47 AM
yea i cleaned them too.
but i positive that its the abs kicking in when is wet out.
call the dealer no recalls. not sure but its annoying me.
99 s10
xXs10Xx is offline
post #19 of 42 Old 04-22-2009, 05:47 PM
Call me Mario, Princess
AceHaag's Avatar
User is: AceHaag is offline
how did your axle seals look if they are leaking the smallest drop of gear oil could cause the lock-up
Mike
my truck
New direction --->Time to get High
2001 s10 ext cab 6.0 243 heads, ls2 cam, nnbs truck intake, 87mm tb, 4l60e, 241c, dana 44's front and rear, 4.30 gears 35" m/t Baja claws.
AceHaag is offline
post #20 of 42 Old 04-22-2009, 06:04 PM
Heavy Metal Junkie
rusty10690's Avatar
User is: rusty10690 is offline
that shit happens to me like its a complte lock up tho like i will barly apply the brakes and my rears will be locked up and it only happens when it rains it suxx
PSN Name= Gopple
post #21 of 42 Old 04-22-2009, 09:00 PM
no leaks of anything.
my problem is the same as the first post
xXs10Xx is offline
post #22 of 42 Old 04-22-2009, 10:05 PM
BarelyGettinBy's Avatar
User is: BarelyGettinBy is offline
My 92 does this. Only when its raining though. Ive learned to live with it but its aggervating
post #23 of 42 Old 04-23-2009, 12:21 PM
User is: gmullin is offline
its just a little rust in the drums deal with it its just when u get the front rotors wet some times they just dont work haha wet rotors
gmullin is offline
post #24 of 42 Old 05-09-2009, 09:51 AM Thread Starter
98' Cowl Induction
Ok....its been a couple weeks since we yanked the drums off, blew them out, used brake cleaner, readjusted.
Hasn't locked up....so, I guess it WAS dust...odd, I swear I tried this before....but we seem to be good again!
post #25 of 42 Old 06-10-2009, 01:54 AM
what i did was just unplug the ABS dont have ABS now but i havent had problems since
cwk08 is offline
post #26 of 42 Old 06-10-2009, 09:02 AM
stockchevy1983's Avatar
User is: stockchevy1983 is offline
my friend just did this on a tahoe yesterday. same problem with abs locking up only when wet out. he had to replace the entire hub assembly to fix the problem.
Jeff
1994 K1500 - 5.7 tbi, magnaflow y pipe, spintech prostreet, leveled on 265/75/16 tw wardens
post #27 of 42 Old 06-10-2009, 06:07 PM
tspears's Avatar
User is: tspears is offline
i have a 96 that does this. how do i go about doing away with the rear abs and keeping the front. or is this even possible. if not possilbe how do i do away the abs totaly
tspears is offline
post #28 of 42 Old 06-10-2009, 07:14 PM
User is: therule546 is offline
Mine has done this since the truck was brand new in 97. ABS SUCKS!!!! I cant wait to delete it when I bag the truck.
post #29 of 42 Old 06-11-2009, 09:43 PM
No More SS
SmokeeJay's Avatar
User is: SmokeeJay is offline
I am pretty sure you either have abs on all or none. If you want to do away with it, you can take the fuse out.
Jason
Sold on 12/7/10 97 SS - 5/6 drop, 225/60/15's on swirlies, Shaved TailGate, Flowmaster, Kicker 10" Sold on 12/7/10
01 2dr Blazer - Daily Driver - 3/4 drop, 225/55/16's on 1st gen ZQ8's, Kenwood 200 watt amp/10" Sub
post #30 of 42 Old 06-12-2009, 03:31 AM
SONOMAZRX's Avatar
User is: SONOMAZRX is offline
Same thing happened to mine in the rain pulled the fuse out from under the hood, hasn't done it in over a year no matter what I do. rain or shine the abs light is always on but just black it out.
post #31 of 42 Old 06-12-2009, 04:51 AM
3.4blazerdude's Avatar
User is: 3.4blazerdude is offline
If you have drum brakes this is caused by the wheel cylinder rotating on the backing plate because of rust or it is worn out. My dad's 93 s10 and the two malibu's which did it, that problem was fixed by getting rid of the slop between the wheel cylinder and the backing plate.
If its good make it better! 99 4X4 S10 pickup K&N, zexel torsen differential, gibson exhaust, egr restricition mod, large sway bars front and rear, power pulleys, Transgo shift kit
transgo shift kit
post #32 of 42 Old 06-16-2009, 12:32 AM Thread Starter
98' Cowl Induction
Mine do not do this anymore since we cleaned the 10lbs of dust and readjusted the brakes.
Its now been 3 months.
post #33 of 42 Old 10-06-2009, 01:04 PM
User is: cams is offline
My 93 locks them up in the rear on the passenger side all the time. Dry or wet, doesnt matter. I have had the drums off a few times and there is dust that I clean out and only on the passenger side I found what looked like fibers or like skoal long cut. It sucks that I cannot stop the truck without dragging a tire half the time.
cams is offline
post #34 of 42 Old 10-06-2009, 07:50 PM
Cfaluck13
cfaluck13's Avatar
User is: cfaluck13 is offline
same thing happened with my '95 noma.
it has abs but no wheel speed sensors, its called RWAL or rear wheel anti lock.... . it uses speed sensors in the trans to detect rear wheel speed.
this only when it was raining. i replaced my drums because they were over spec and when i did, i did not adjust the shoes as tight as before, so far no problems. try adjust your shoes back some.
1994 S-10 blown 2.2.....soon to be LS1
1995 Sonoma 2.2 5 speed
1986 El Camino SS 305
post #35 of 42 Old 10-06-2009, 08:56 PM
mine does it as well, but its not abs, with the slightest touch the front will lock up but after the first initial brake touch, its fine. my 98 did it as well.
Jeff
post #36 of 42 Old 10-07-2009, 08:42 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
yep my truck does this too,i'll have to try taken the drums off and cleaning the dust n crap outta there.one of my 1 ton chevys just started doin it as well...oh well winter projects i guess lol. hey man nice capri i had one that got creamed by a drunk driver and i miss the hell outta that car
post #37 of 42 Old 09-24-2010, 01:27 AM
mykl8's Avatar
User is: mykl8 is offline
I know its been a wile and you have fixed it but a quick question:
Does your truck have the speed sensors inside the drums? I cant remember what year GM started that.
The sensors are magnetic and attract steel filings that build up and are most likely the cause.
Just my 0.02
mykl8 is offline
post #38 of 42 Old 09-24-2010, 02:29 AM
User is: pdxmatt is offline
My 98 extended cab has done this since day one. In the rain the rears kick the abs on and it wont stop until I let off. It's bullshit and caused me to rear end somebody years ago.
pdxmatt is offline
post #39 of 42 Old 09-26-2010, 09:27 AM
User is: bigjuicy1979 is offline
i work as a mechanic at a chevy dealership the problem is the back shoes have a crack in them or they have a glaze on them u should take off the drum take a piece of ruff sand paper sand down the shoes and then take a piece of sand paper and sand the inside of the drum to knock the glaze off of it and check the drums for cracks and the shoes for cracks no matter how small the crack is it will cause this problem
post #40 of 42 Old 09-26-2010, 09:29 AM
and try and adjusting the back brakes this will cause the pulsating your getting from the brakes because the back brakes are wanting to push out more
post #41 of 42 Old 07-29-2014, 07:15 PM
ScagsSdime's Avatar
User is: ScagsSdime is offline
I have the exact same problem, In fact my Sdime has been doing It since the first day I bought her and It's been 7 years now. I recently got new breaks done all around and at the moment having nothing but problems with the rear wheels, Maybe something to do with the ABS I don't know. And like yourself I have read countless threads upon this problem yet no one seems to know how to fix it.
I also read that between 2000 and 2003 the ABS system In all GM cars and trucks were the worst years ever, Many of my friends all have the same problem as well. I did read something about the front wheel sensors getting dirty according to many people but who knows..... I personally pulled both ABS fuses out to see If that would fix this problem, So far so good other then the constant lock up on my passenger side rear wheel. My buddy says that It sounds like the adjuster Is not set up properly, Anyway I suggest you try pulling out the fuses If you haven't already done that.
post #42 of 42 Old 07-29-2014, 08:12 PM
9" strait pipes...
hi_im_sean's Avatar
User is: hi_im_sean is offline
Originally Posted by scagssdime View Post
i have the exact same problem, in fact my sdime has been doing it since the first day i bought her and it's been 7 years now. I recently got new breaks done all around and at the moment having nothing but problems with the rear wheels, maybe something to do with the abs i don't know. And like yourself i have read countless threads upon this problem yet no one seems to know how to fix it.
I also read that between 2000 and 2003 the abs system in all gm cars and trucks were the worst years ever, many of my friends all have the same problem as well. I did read something about the front wheel sensors getting dirty according to many people but who knows..... I personally pulled both abs fuses out to see if that would fix this problem, so far so good other then the constant lock up on my passenger side rear wheel. My buddy says that it sounds like the adjuster is not set up properly, anyway i suggest you try pulling out the fuses if you haven't already done that.
03-17-2008, 12:33 pm
ScagsSdime likes this.
