parking brake - S-10 Forum
post #1 of 65 Old 12-15-2008, 03:24 PM Thread Starter
oks10's Avatar
User is: oks10 is offline
parking brake
Anybody having problems with their parking brake not wanting to disengage when it gets cold. It was 16 degrees here this morning and it took me 10 minutes to force the damn thing up.
-Jay
oks10 is offline
post #2 of 65 Old 12-15-2008, 03:33 PM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
Re: parking brake
my lt1 truck does that, but barely..... it just feels like the spring is worn tho...... i just tap it up with my shoe
2004 Commemorative Edition Corvette
2014 Lexus IS350 F-Sport
post #3 of 65 Old 12-15-2008, 04:00 PM
Electrical Mod
deathphoenix99's Avatar
Re: parking brake
When its cold as in below freezing temperature? If so, it sounds like you got water or something in your parking brake cables and they are freezing. My fourwheeler has the a problem with its cables freezing and they are easy to apply still, but stick and don't want to release.
post #4 of 65 Old 12-15-2008, 08:46 PM Thread Starter
oks10's Avatar
Re: parking brake
It doesn't necessarily have to be below freezing. Generally when its about 40 or 50 it has a delay and the colder it gets the more force it takes.
-Jay
oks10 is offline
post #5 of 65 Old 12-15-2008, 09:25 PM
207stunting's Avatar
User is: 207stunting is offline
Re: parking brake
I use my frame as my e brake.. lol
no but really does anyone know why the e brake wont even go down?
Bagged 97 DIME
BAGGED 68 valent
if you wish to advertise please email
admin@s10forum.com
post #6 of 65 Old 12-16-2008, 11:02 AM
User is: broncosbybart is offline
Re: parking brake
yeah, sounds like the cables are freezing. wd-40 is a moisture remover. it doesn't work superbly, but when it isn't freezing out, try and get some of it in there. it is about your only option, other than replacing the cables.
post #7 of 65 Old 12-16-2008, 04:04 PM Thread Starter
oks10's Avatar
Re: parking brake
where exactly would I spray the wd40?
-Jay
oks10 is offline
post #8 of 65 Old 12-16-2008, 04:11 PM
Electrical Mod
Re: parking brake
Anywhere under your frame that you see the parking cables, i'd guess after the splitter where the individual cables go into the housing again. Keep it off of your brakes though. Have you pulled a drum hub off yet? may have corrosion in there also, doesn't hurt to look.
post #9 of 65 Old 12-17-2008, 12:57 AM
nemesis8's Avatar
User is: nemesis8 is offline
Re: parking brake
hmmm what if the pedal wont stay down?
mine comes up everytime i step it down.
98 GMC Sierra ext. cab-Bagged and dragged
05 350z touring
nemesis8 is offline
post #10 of 65 Old 12-17-2008, 01:00 AM
Blue Bowtie
Zblue8's Avatar
User is: Zblue8 is offline
Re: parking brake
mine used to come up real slow when it was cold out...like take 10 sec to come up all the way
today i went to get out of my truck and leave it run so it could warm up while i scraped the ice off and it went SNAP, and now it doesn't stay down
...so i have both problems...oh well 1st gear works for me usually
Dan
2001 Extended Cab ZQ8 S-10, 4.3L 5 speed, Indigo Blue, GM Rollpan, Hidden Hitch, and Clear Corners
Zblue8 is offline
post #11 of 65 Old 12-17-2008, 02:49 AM
User is: blipidy is offline
Re: parking brake
the parking brake pedal on my 99 blazer doesnt stay down either, but its because the tab "ear" part of the parking brake assembly that the actual cable connects to broke off one day when i went to step on the parking brake.
next time you are looking at your truck, look under it at the back side of your rotor or drum (depending on your brake setup) and see if the cable is still connected
'99 BlaZeR2 5spd
'98 S10 Ext Cab 2.2 5spd
'69 Camaro under restoration
blipidy is offline
post #12 of 65 Old 12-17-2008, 03:05 AM
nemesis8's Avatar
Re: parking brake
hey yeah ill check that out.
the previous owner did the rear disc swap so ill see whats up
thanks
05 350z touring
nemesis8 is offline
post #13 of 65 Old 12-17-2008, 03:38 AM
S Lo
badandy247's Avatar
User is: badandy247 is offline
Re: parking brake
I hate the stock s10 parking brake system, every s10 I have ever bought has had SOMETHING wrong with the E-brake except one. Like was mentioned before, get under the dash and spray a little WD on all the moving parts. Then get under the truck and spray some anywhere the cable leaves or enters the sheath. Do this with the brake both disengaged AND engaged to be sure to get as much coverage as possible. Cycle the brake a few times and see if there is an improvement. After this I like to spray a little aerosol White Lithium grease on the same places I sprayed the WD. White lithium tends to "stick" to the cable a bit and provide longer lasting lubrication.
91 Mitsubishi 3000GT VR4 Daily Driver
98 ZQ8 project
97 LS Stepside (parts truck for the 98)
95 Extended Cab GF's truck
90 Z71 Farm truck and off road toy
post #14 of 65 Old 12-17-2008, 08:47 AM
Re: parking brake
he went and spelled it out. my brake didn't stay down either. the release mechanism was gummed up and was stuck in the release position. it is under the dash- just follow the brake release cable. there is a liitle arm that it attaches to. it is probably very difficult to move and is stuck in the release position (as if the brake release were pulled back toward you all the time). free it up w/some wd40 and just work it back and forth with your fingers. it should free up. once it's free, a little white lithium would help out too.
post #15 of 65 Old 12-17-2008, 10:59 AM Thread Starter
oks10's Avatar
Re: parking brake
Thanks for the info guys. Just goes to show that as long as you have duct tape and wd-40, you can fix anything!
-Jay
oks10 is offline
post #16 of 65 Old 12-17-2008, 08:13 PM
Re: parking brake
except for a bad head gasket....
post #17 of 65 Old 12-20-2008, 02:45 PM Thread Starter
oks10's Avatar
Re: parking brake
nah, just throw some duct tape around it. it'll be aight
-Jay
oks10 is offline
post #18 of 65 Old 12-20-2008, 02:52 PM
Rarely goes over 20mph
beaniebmx's Avatar
User is: beaniebmx is offline
Re: parking brake
i never used a parking brake, my old 1st gen 5 speed didnt have it, just have to be sure not to park on an incline, tried doing that and i could feel the truck trying to inch down the incline with me still in it, i parked elsewhere
03 S10 Ext Cab-BD 3.5" bagged- 18/20s its ORANGE
1991 s10 reg cab 5spd- SOLD- biggest mistake
1985 2wd 2dr jimmy-totaled- samwhiched in a 5 car pileup
post #19 of 65 Old 12-22-2008, 01:53 AM Thread Starter
oks10's Avatar
Re: parking brake
Well, with all the problems I've had with it not coming up, tonight it won't stay down. This parking brake is pissing me off. Now I get to get out the cold to try and fix my brake.
-Jay
oks10 is offline
post #20 of 65 Old 12-22-2008, 12:21 PM Thread Starter
oks10's Avatar
Re: parking brake
Well after trying to figure out for the past half hour whats up, here is what I have found. The pedal wont stay down, when I push it everything is moving right, and I can see the cable attached to the release handle move when I pull it. The problem is I can't see where the release cable interacts with the brake cable because of the metal housing around it. I've sprayed wd40 all over it with nothing to show for it. Any other ideas?
-Jay
oks10 is offline
post #21 of 65 Old 12-25-2008, 09:54 PM
evandonald's Avatar
User is: evandonald is offline
Send a message via MSN to evandonald
Re: parking brake
Well mine is a different problem. It got to about -5 C here and my parking break always worked fine from factory and its a 98. I got in it and mine wont lock when engaged. Like if I physically hold the parking brake down it works. Just something with the lock mechanism must be broken. Tomorrow I will get it in the garage and get a look at it. Anyone have any similar deals?
post #22 of 65 Old 12-27-2008, 01:56 AM Thread Starter
oks10's Avatar
Re: parking brake
that's exactly what mine is doing. I can't see anything though because of that plate that covers it and is riveted on. Let me know if you come up with anything. I can't look at mine right now bc its in the shop getting the clutch fixed; was making a grinding noise and I had to force it in to gear, surprised I made it to the shop.
-Jay
oks10 is offline
post #23 of 65 Old 12-27-2008, 06:48 AM
evandonald's Avatar
Re: parking brake
Oh well I won't be looking at mine again until about may. It finally got into winter storage that I have been waiting a good month to get into. I will try to fix it come spring. I don't use the parking brake often but it will be fixed for inspection come next september
post #24 of 65 Old 12-28-2008, 07:12 AM
User is: mike_pasara is offline
Re: parking brake
Yes... I park in my driveway and it's on a slight hill... i leave my truck over night with the park brake engaged and it can reach -10 degrees celcius at night. By morning I warm the truck for 2-3 mins and i'm off. I disengage the park brake and set it into reverse and the truck won't budge unless i give it some gas. it stays stuck...
1997 S10 extended cab LS
2.2 5 Speed
post #25 of 65 Old 01-18-2009, 10:52 PM
User is: justinkr58 is offline
Re: parking brake
i have the same prob
the toughness of releasing is proportional to the coldness.
i have gotten under the dasy and sprayed the mechinism wirh lube and still tough.
BUT>>> when the cab warms up fully it is no longer stuck, so it is NOT sticking or frozen on the outside it must be something on the inside.
has anyone found out the problem,
this break release seems to use some sort of a shoe stop because it is not clicking when steeping down on the pedel. but i cant see anything because it is allcovered up with plate.
post #26 of 65 Old 01-18-2009, 11:22 PM
s10noob's Avatar
User is: s10noob is offline
Re: parking brake
my s10 does that, if it is below 40 outside the e brake pedal won't dis engage. i have to push it down farther, then try and release it, then push it down again' then release it i have to work it back and forth.
98 s10 2.2, no a/c, ebay heatshield intake with k&n filter, 8mm accel wires, magnaflow stainless steel muffler, 3.73 gears, custom made shifter, asp underdrive crank pulley.
sold!!! gone, but not forgotten. new toy, 2000 silverado 4.8 auto reg. cab 2wd. K&N cold air intake, duals with flowmasters, dropped 1In. in front, 2In in the back. bed tarp, roll pan, tons more cosmetic stuff.
s10noob is offline
post #27 of 65 Old 01-27-2009, 11:40 AM
Syclone1639's Avatar
User is: Syclone1639 is offline
Re: parking brake
I found out that mine was binding under the frame for some reason.
I must have hit the frame and caused it to pinch.
Jim Kelly
Syclone#1639
post #28 of 65 Old 01-27-2009, 11:55 AM
zzzq8
riipciity's Avatar
User is: riipciity is offline
Re: parking brake
never had problems with mine in the cold, only had the line snap on one once
post #29 of 65 Old 01-27-2009, 04:31 PM
evandonald's Avatar
Re: parking brake
Anyone get theirs to engage that wasn't letting the parking brake engage? I plan to tear into mine as soon as it comes out of storage. If its the parking break mechanism, does anyone know if the part is the same as any other GM vehicles with a foot parking brake?
post #30 of 65 Old 01-29-2009, 05:01 PM Thread Starter
oks10's Avatar
Re: parking brake
I haven't been able to get anywhere with mine. i've just been leaving it in 1st or reverse depending on which direction I'm parked. What sucks is that my parking spot is inclined so I can't just let my truck warm up while I go back inside.
-Jay
oks10 is offline
post #31 of 65 Old 01-29-2009, 05:03 PM
Hmm.. well now..
Gearstix's Avatar
User is: Gearstix is offline
Send a message via AIM to Gearstix Send a message via MSN to Gearstix Send a message via Yahoo to Gearstix
Re: parking brake
My brake sticks a bit. When I first put my truck in the driveway when I got it, and put the park brake one, it stuck, and we had to drive forward and let it roll back to get it to release. Its probably because the truck has been sitting for over a year, and I haven't been driving it myself. Oh well little maintanace things. I also figured out the bolt that holds the spare on rusted off, thats why there isn't one there.
Now I just leave it in 1st or block the wheels.
I'll probably order some airplane wheel chocks from work and toss em in the bed.
1996 Chevrolet S10 LS 2.2/Auto... Soon to have a 305/700R4
'94 Sonoma. < Project Thread... Now with tree damage... Now a parts truck.
'05 Blazer 2DR 4x4 < The 'new' daily
(j-body.org)
Originally Posted by OHV notec
Might as well point out that you could spend $10k modifying a Briggs & Stratton-powered lawn mower, or a dining room table.
Gearstix is offline
post #32 of 65 Old 03-21-2009, 04:59 PM Thread Starter
oks10's Avatar
Re: parking brake
Well, I just replaced my parking brake today. Didn't think to take pictures, just wanted to get it done. I got a discount on the part from the dealership and only payed 40 bucks, its 60 retail. It took be about an hour to finish but that was mainly due to not having the proper tools. It's a pretty simple "out with the old, in with the new" process. Theres two screws on the bottom, one by the pedal and one by the brake cable, and then there is a nut on the top you have to take off. You can't see but its there, just have to feel for it. For me the hardest part was getting the cable off and on the mechanism.
-Jay
oks10 is offline
post #33 of 65 Old 03-21-2009, 06:02 PM
evandonald's Avatar
Re: parking brake
So you replaced the locking mechanism on the pedal assembly?
post #34 of 65 Old 03-21-2009, 10:04 PM Thread Starter
oks10's Avatar
Re: parking brake
I replaced the entire parking brake mechanism. I'm uploading pics to photobucket right now.
-Jay
oks10 is offline
post #35 of 65 Old 03-21-2009, 10:19 PM Thread Starter
oks10's Avatar
Re: parking brake
ok, here we go. here are some pictures that show where the three mounting bolts are. The top is held by a bolt that is actually attached to the truck and you take the nut off of it. Its what puts the assembly in the right spot. Also, be sure to detach the electrical connection to the switch that tells the computer when the brake is engaged.
Also, I used a 13mm socket for the screws and nut. If you have a deep socket it will make it a lot easier. Any questions, pm me and I'll do the best I can to help.
-Jay
oks10 is offline
post #36 of 65 Old 03-22-2009, 10:12 AM
evandonald's Avatar
Re: parking brake
So did you just purchase that whole assembly in the picture above? You say it was around $60? I am thinking I am going to have to tackle this minor swap when I get my truck out in april. Thanks!
post #37 of 65 Old 03-22-2009, 10:49 AM Thread Starter
oks10's Avatar
Re: parking brake
Yeah, I purchased the whole piece. I got it for less but it's 60 retail. You have to get it from a chevy dealer. I didn't take pictures until after I was done so the picture with it standing alone is the old one and the one installed is the new one. The new one is a lot cleaner obviously.
-Jay
oks10 is offline
post #38 of 65 Old 03-22-2009, 01:56 PM
evandonald's Avatar
Re: parking brake
Thanks greatly, I am almost positive that is what mine needs. It was almost like the little teeth in the locking mechanism broke so therefor it would no longer lock the pedal down.
post #39 of 65 Old 03-22-2009, 02:28 PM
evandonald's Avatar
Re: parking brake
oks10, you wouldn't happen to have the part number for that assembly would you?
post #40 of 65 Old 03-22-2009, 07:33 PM Thread Starter
oks10's Avatar
Re: parking brake
The part number I have on my receipt is 15016010. I'm sure if you just call the parts department at the chevy dealer they'll be able to help you.
-Jay
oks10 is offline
post #41 of 65 Old 03-23-2009, 06:40 AM
evandonald's Avatar
Re: parking brake
Alright, I'll give it a shot.
post #42 of 65 Old 04-20-2009, 11:49 PM
User is: Redman89 is offline
Re: parking brake
can anybody who has had the parking break cable snap, give me some help as far as how to replace the cable, and where to buy it. Mine always stuck, so one day i was working it back and forth really hard and snapped the cable right under the cab, so it hangs down with a zip tye on it now.
Redman89 is offline
post #43 of 65 Old 06-15-2009, 10:44 AM
User is: yingyangfox is offline
Re: parking brake
i have a 1998 s10 2.2L and i wanted to know if the e brake engager? is interchageable between the s10 and the blazer
post #44 of 65 Old 10-26-2010, 01:31 AM
User is: littlewazz is offline
Re: parking brake
I have a problem with my e-brake pedal assembly on a 1991 s-10 4 door blazer the ratchet teeth are stripped from being used all the time on a manual trans. so does anyone know where to get one except the dealer.
post #45 of 65 Old 10-26-2010, 08:06 AM
always something new
S10dude's Avatar
User is: S10dude is offline
Re: parking brake
junk yard ?
All truck pics
S10dude is offline
post #46 of 65 Old 10-26-2010, 12:40 PM
User is: RWW1980 is offline
Re: parking brake
Anyone know what to do if you parking break on a manual doesn't hold the truck on a slight hill?
RWW1980 is offline
post #47 of 65 Old 10-26-2010, 12:49 PM
Dump em' Out
Bootylicious's Avatar
User is: Bootylicious is offline
Re: parking brake
Tighten the cable......
post #48 of 65 Old 10-29-2010, 06:56 AM
Smoke Crack-Drive Fast :D
juicedstang999's Avatar
User is: juicedstang999 is offline
Re: parking brake
Found mine on fleabay...
2000 2.2 5speed 2WD with a 5" lift, 4:10's, sittin on 31's, HID's, Hurst shorty shifter, Cold air, Pulleys, Custom 1-2-4 exhaust, rolled out back
post #49 of 65 Old 12-31-2010, 01:38 PM
User is: jboney is offline
Re: parking brake
How did you get the cable off ? Just fight it with needle nose pliers or did you come up with a better way.
jboney is offline
post #50 of 65 Old 01-01-2011, 11:50 AM
User is: BillJ is offline
Re: parking brake
I had that problem. Yesterday I removed the pedal and mechanism from my '86 S-10. The ratcheting lever had half the edge broken off and the lever had gotten sloppy loose. I used a dremel tool to take down the edge so the whole edge could again catch the teeth; then balancing the mechanism on a sledge hammer, I took a drift pin punch and punch into the metal around one side of the large rivet that holds the lever taking out much of the slop but not enough to cause a bind. This placed the lever back over the teeth.
I had been putting it off as it would stay caught unless I applied 'hard' pressure to the parking brake. Also until yesterday it was undependable, sometimes popping out and letting the truck roll unless in gear.
The brake cable broke was what got me fixing it in late December. I'm running into town later for the new cable but can't find any online references to the cable splice clip I broke (would attaching photo but it's too large). Anyone know if there's a tool specific to that splice clip?
BillJ
BillJ is offline
