LinkBack (1) | Thread Tools |
#251 |
CHANGE YOUR EMAIL ADDRESS
Re: **New Updated Rim/Tire Fitment For S Trucks**
i looked through a few pages but didnt find a answer for first gen. on the rear. can i run 20x8.5 with 4.75 BS and a 275/30 and lay it out?
#252 |
can i fit 40 or 45 series tires with a 2/3 drop on an extreme blazeer
20'' wheels |
#253 |
with 3.73 gears i want to stuff a 305/35r18 because its the only 26" tall drag tire i've found thats not a million dollars-anyone done it with no problems?
#254 |
any body know what size of tire i should go with 17 by 9 camaro SS wheels? with a 2/3 drop?
#255 |
S10 TIRE/WHEEL MASTER
305 35 18 will be fine. 18x10 with 5.5 bs <<< btw im n20 noma changed my name to norcal sti when i bougth my sti
#256 |
hey i have a question for you I have a 2001 2dr 4x2 s-10 blazer that is lowered 5" in the front and 5" in the rear i found these rims through my work they are 20x8.5 with 5.22" BS i was wondering if you could tell me if they will fit and if so what size tires to go with then i would really be apreciative
#257 |
Getting Layed
alrighty... i currently have a 2'' /4 3/8'' drop. spindles, 3'' blocks, removed one leaf out of the 4 leaf spring pack. as she sits now the front is about 1/2'' higher. i am doing 1'' coils so the front should be 1/2'' lower after the coils settle right. i have a 95 ss and do not have the factory drop. i also have noticed my truck sits higher than most. is it something w/ the 95 ss's? anyway, i am running a large tire, 255/50/17. i know i'm going to rub bad once i put in the 1'' coils up front on the inner fenders, and i thought about going with a 245/50 or 255/45 size tire. i know smaller tires will drop me a little more=good, but how much will they increase wheel gap=bad.
#258 |
Sdimess84
Can I do a 3/3 drop on 245/60/15? I will be doing the drop with 3"springs up front and 2" inch blocks in the rear(I have zq8 suspention with worn out front coils)
#259 |
question. 2003 s-10. stock height. I plan on dropping 3.5/4 I want to put c6 wheels on it. 19x10 rear 18x8.5 front. Will I have any problems with this? need an answer ASAP thank you
#260 |
Layin body over 26's...
NORCAL STI I PM'd you about 22's for my blazer...
#261 |
i have a 98 s10and i wanna get some of these rims
![]() i want them in 18's and the only size width i can get them in is 9in with the 14mm backspacing i need. they come in 8in wide but the backspacing is 40mm will the 18x9 fit all the way around? i wanna do a 2/3 drop in the future also. and what tire size do i use |
#262 |
VVV RIP FOR NOW VVV
would 17x8 with a 4.5" bs fit in the front? i want to get the cragar s/s wheels in 17's
#263 |
[]D[][]\/[][]D
i have 22" 150 spoke knock off.s and a 89 s10.
can i do it? p.s it has a 3 inch coil drop and a 3 inch block in the back. |
#264 |
can i run 20's on my first gen extra cab with a 5/6 drop without any problems? if not what do i have to do to run 20's? thanks in advance.
#265 |
4 7/8" just measured my rozzis |
#266 |
NEED HELP, CAn i Put a 18X8 rim wit a 235X45X50?, if so would a 3/4 dop be ok?
#267 |
#268 |
Needs money and parts
99 Xtreme 4.3 reg cab 3/4 drop in the near future (spindles/blocks) I'd like to go with 18's all around. Just like everyone else is asking....what do you suggest?
#269 |
Blk_blazer00
Location: Orange Park/Tallahassee FL User is: OffLine ![]() |
will a 17x8 tire 0mm offset fit fine with a 5/5 drop?
#270 |
I need a job, No one hire
What hapened to the first gen info?
#271 |
I have a 93 s10 p/u, right now it's bagged and resting on 17x7 with 235/45-17 in front and 17x8 with 255/40-17 in rear......I'm thinking of running an 18x8 with either a 215/40-18 OR 225/40-18 all the way around....Truck will never be driven every day, so I'm not worried about wrecking a rim at all........The rim I'm looking at getting has a positive offset of 18mm..............will these tuck in?...........front fenderwells are gone.....
Thanks, -Niz CS4LIFE www.csautoclub.com |
#272 |
Sweet n Low
#273 |
dang I ordered my Bonspeed rims 17x7 with 4.5 bs and 17x10 with 5.25 hope the fronts work without spacers =(
#274 |
Your Tax's Hard AT Work
what size 22 do i need to run rim and tire on a bagged 3in boddy drop 96 s10
#275 |
#276 |
Banned
what for a bagged s10 on 22's what bs and offset and will a 9.5 wide work
#277 |
#278 |
Banned
on a 9.5 what mm is that 5.75 ? and will a 9.5 work just limit turning a little bit ?
#279 |
does any one make an 8 1/2 wide 22 rim
#280 |
yes boze forged does.
ive done both the below wheels in a 22x8.5 for a s10 and came out great. this one without the groves though ![]() this is a 3 piece set up ![]() |
#281 |
in front a 245 30 22 with a 22x8.5 was nice along with a 22x10 in rear with a 295 25 22 was a nice set up. customers truck was lowered 2/3 and looked perfect |
#282 |
Banned
ya but how much are they all the 22x8.5 i been looking at are like 700 to 1100 a rim i want a 22x10 and 22x8.5 up front for a decent price
#283 |
if u want to be in the game u got to pay to play..
those boze wheels in 22s with 245 30 22 and 295 25 22 were around 4500 bucks but well worth it |
#284 |
Banned
