LinkBack (1) | Thread Tools |
#201 |
Re: **New Updated Rim/Tire Fitment For S Trucks**
Will a 18x9 inch rim fit in a bagged truck? Or am I going to have to cut the fenderwells? What size rim will fit? Where I don't have to cut the fender wells? Any help will be appriciated
#202 |
No more switches
with vette wheels you need to run spacers and you can't run those wide as spacers with drop spindle's so you won't have the extra 2" when it comes to bagging. I think u have to cut some shit up to tuck a z06 wheel on an s10. I'm almost certain.
#203 |
Baby Blue > Joo
For anyone running 17x8 rims:
What size tires are you running on the front. I'm gunna run 255/50/17 in the back, so it's the same overall height as stock so my speedo and odo are off. However, i'm looking for a little bit of a staggered look, so i want something a little smaller in the front without looking TOO different. Please post size and brand / model of tires. |
#204 |
No more switches
#205 |
Baby Blue > Joo
#206 |
Baby Blue > Joo
Come on guys, i know people are running 17's around here! What size tire and what brand?!
Recommendations? |
#207 |
My '03 R1 is for sale
i ran 245/45/17's on my old X and thought they looked great:
#208 |
Baby Blue > Joo
Yup, looks nice. What brand or model do you recommend?
#209 |
![]() As far as brand, i would suggest the populars: Goodyear Eagle's, BF Goodrich has a good street tire out now, when i buy my 19's i will be rolling with the Nitto 555 Xtreme models. i have heard good things and they are a ZR-rated all seaon tire. i like that, even though my 19's will be fair weather rims (have the stockers for the winter). all depends on what you want, availability, and pocketbook depth... |
#210 |
one of my friends is selling me some 20 inch rims that are 5 lug 5x120 with a 38 offset , if I get these rims will i have any problems if i am plan to get bagged .....
please help me before i buy the rims |
#211 |
+38 offset is kinda large. It's gonna suck the rims inward and make you rub against the control arm or frame when turning. 20's are gonna make it tough to lay frame unless you plan on some fenderwell modifications anyways.
#212 |
would a spacer or adapter fix the problem..and if it does what size od spacer or adapter
#213 |
will 18X9's with a +14 mm offset fit on a bagged 1st gen withotu rubbing to much?
#214 |
I have an '02 Sonoma, 2wd, 2 door, stock ride height and I have a set of 16x8.5 wheels with a 3.5" back spacing. Do you think these wheels will fit on the truck? What size tire would you suggest? Second, I will probably install shocks and springs from a ZQ8 to lower it about 1.5" do you think the above wheel will still fit?
Thanks a lot for any halp, Phil |
#215 |
#216 |
S10 TIRE/WHEEL MASTER
hause those will not fit dont listen to the other guys 16x8.5 on your 2wd truck requires a 245 50 16 tire to look right. for a 8.5 rim you need 4.75 bs. 3.5 bs will stick out way to much
#217 |
woot i got a title
what would you suggest for a 91 s10 that is going to be 3/4 drop. I'm ordering my rims in a few weeks and im looking at these:
http://www.discountedwheelwarehouse.com/Store_Detail.cfm?ID=111095&InfoID=2505&ShowLarge=T rue I know I need a 4.75 backspace n 5-15mm offset. But what tire size do I need? I know nothing about this stuff n it totally confuses the shit out of me... LoL... help a brotha out ![]() |
#218 |
if anyones got a second. just got a set of 20x8.5 inch boss304's. got a set of nitto 245/35/20's.
i have a 2001extended cab "x". i also droped it 2/3. has the correct backspacing also. how bad do you all think im going to rub. my 17's i have only rub in one spot on the frame but thats because they were from my last car and i bought some adapters. |
#219 |
you will likely rub a bit at full lock and when turning might grind a bit against the inside of the fender flares (no big deal as once they wear away it won't happen anymore) but they should be good to go. That will be an awesome looking setup on your X. It was exactly what i was planning on going with until i found a set of 19's i liked better then the 304's. Wish they could come in 20" tho...good luck.
#220 |
Will 2.5" wheel spacer work to stuck 17x9.5 vette wheels with 275/35's under a 1998 2wd Jimmy 4dr?
#221 |
#222 |
Getting Layed
anyone running 17's with a 3/4 drop? j/w what size tire you guys are running? can you run a 255/45/17? how will it look? how about a 245/50? 245/45? i'm running 255/50 on a 2/3 drop and rub some now a little.
#223 |
Will 18x9's fit on a stock height '99 S10. Also, if I do a 2/3 drop will they still fit?
#224 |
Flat Out Fabricator
20x8's..... bagged 92 s10. What backspacing i need and what size tire. Rubbing is not a problem everything is tubbed. Also what's the difference in a rolled lip and step lip?
#225 |
i looked all through and saw a few people ask but no answers. for a bagged s10 it says 20x8 with 4.5bs and 245/35/20 will work but what about 20x8.5 with the same tire and back spacing. need to know soon as i need to order for a show coming up quick. thanks.
#226 |
what width rim could i get in the back of a 1st gen with a 5 or 6 inche drop, im just goin to b useing 15" or 16" mickey thompson drag wheels
#227 |
#228 |
Posts: n/a
i have a 2000 S10 Extended Cab w/ 4.3L V6 and a 3/4 drop.
I would like to put 20's on them if I could but i do not know if i can without alot of modification. I would like to know if i could and with what tire size. Thanks |
#229 |
I found your chart very interesting. I have an '86 S-10 Old School all the way,running Corvette Rally wheels,like early '70's style,15" x7" all way around,3 inch drop front spindles and springs,4 inch in back,pinion angle blocks. My question is with the 15x 10 in rear will it tuck with the 295/50/15 on a 5" backspace since that is all I can find in that style wheel?
Thanks in advance, Darren |
#230 |
drag or go home
Will my noma lay frame when i bag it with like a 8" notch and with the stock 205/75R15 gumbo's? Im worried about the front/rear wheelwells.
#231 |
i have a 2000 xtreme with a 2/3 drop just wondern if i could fit 18's if so what size would be best???? all help apreciated.....
#232 |
I have a 98 S10, 4wd and I am wanting to put the biggest tires on i can with it still being stock hieghth. I'll be putting the new tires on 16" wheels. If you can help me out send me a PM. and I'll get back. thanks 1998redS10
#233 |
Is anyone running 255's with stock ride height? Any rubbing/clearance issues? I can get a good deal on some 255/60/17 take offs but want to make sure they'll work.
