New Updated Rim/Tire Fitment For S Trucks
LinkBack (1) Thread Tools
Old 04-20-2008, 04:26 PM   #601
Brad99Dime is on a distinguished road
Re: New Updated Rim/Tire Fitment For S Trucks
I want Coys C-5. 18 x 8 for the front and 18 x 9.5 in back. Stock height on my 1999 S-10 Std Cab. Any issues???? Or will they fit???
Old 04-20-2008, 06:54 PM   #602
casekey's Avatar
casekey is on a distinguished road
What size tire do i get for a 3/4 drop on 16x8 extreme rim? It says it for the front but not the back...
Old 04-23-2008, 01:36 PM   #603
slightly_custom's Avatar
slightly_custom is on a distinguished road
are the sizes any different for the stepside bed s10
Old 04-27-2008, 10:10 PM   #604
DeathSlinger00's Avatar
DeathSlinger00 is on a distinguished road
yeah, i have the same question.
for me, it'll be for a 1st gen. i have a set of 15's with 215's on, and it's already a tight fit. what tire size would anyone suggest? i'd be too afraid to try the 235/55/16's, for fear they would be too big.
oh, and i'm pretty well certain that stepside is not a factor.
Old 05-09-2008, 12:38 AM   #605
legs drag/truck doesnt
GimpExtreme's Avatar
GimpExtreme is on a distinguished road
im new here and real new too the s10 scene really
im bagged on an 01 and lay front crossmember with 2 inch spindals
frame doesnt lay!!
can i run a 20 inch rim without cutting up front wheel wells and cutting anything in rear?
Old 05-13-2008, 08:23 PM   #606
Malus's Avatar
Malus is on a distinguished road
WHat are the largest and widest tires that will fit on a 1999 2.2 2wd LS stock
Old 05-18-2008, 01:19 PM   #607
Big Ed is on a distinguished road
I've got a 92 s10 x cab 2wd coming in two weeks. Thinking of a 2/3 or 3/4 drop on it. what wheel and tire size combos could i go with and have it look good. Please help.
Big Ed
Old 05-18-2008, 01:55 PM   #608
S10 TIRE/WHEEL MASTER
NORCAL SS's Avatar
NORCAL SS is on a distinguished road
Big Ed
15X5 RALLYS 165 15 front
15x8 rallys rear 295 50 15 or 15x10 rallys 5.5 bs 295 50 15 will look tough.
You can also do 15x7 4 inch bs 225 65 15 and rear 15x8 4.5 bs 275 60 15
Old 05-24-2008, 01:05 PM   #609
ksmith is on a distinguished road
what about a 235/55/17 for a 4" drop in front, its a 2.2 so itll prolly only be like a 3.5" drop but will there be any rubbing?
Old 05-27-2008, 10:35 AM   #610
dusterbd13 is on a distinguished road
im looking at using 17X9 corvette wheels with 275/40/17's on my 88 2WD. im wondering if theyll fit, and what spacer to use. the truck is dropped 2/3 with springs, and has the tall ball joint conversion, which pit thefront down another 1/2 inch, and made the spidle rougly 1 1/2 taller overall from top to bottom of th control arms.
what do you think?
Michael
Old 05-28-2008, 09:42 PM   #611
PLUS12 is on a distinguished road
I have just bought a 97 s10 and I am in dire need of tires and wheels. My OEM ones have been dented and are bubbling the tire that is on them... So.. Since money is tight and I bumped into a deal, I was wondering what problems I could expect with putting on 18x9.5's on a bone stock ext cab 97 stepside ls. I am told (by the sellerof the vehicle) that the suspension and everything else for that matter, aside from the manual transmission, are all parts from the SS package. He says camaro suspension, but i have no idea. Either way, aside from the actual fit, if I would end up ruining my clutch or trans with the added size of the wheel. I am potentially buying the wheels wrapped in Ultra High Performance Sumitomo HTR-Z II's 275/40 18's with spacers 4 $600. The seller is taking them off of a modified (couldn't tell you what mods) 01 blazer x. He says he has no wheel rub and I realize that alot has been changed between 97 and 01...
Any help you guys could give me would be great. thanks
Old 06-01-2008, 08:45 PM   #612
GRUMPY95's Avatar
GRUMPY95 is on a distinguished road
I've got a 95 s10 with a 2/3 drop, spindles in front and beel leafs in rear. I'm plannning on getting the 18"x9.5" zo6 rims. From what i've read i'll need 2.25" spacers in front but in the rear i'm going to be installing a 8.8" rearend from a 2000 explorer which is suposed to be 5.5"-6" longer. if i redrill to chevy bolt pattern will those rims clear fenders or will i need to shorten the diff?
Old 06-02-2008, 11:31 PM   #613
Vtec_killa is on a distinguished road
hi. i was wondering if the rims off my Ta would fit a 03 s10 4door 4x4. they are 17 by 9.5 tires are 255 /4O in front and275/4O in back
Old 06-19-2008, 03:40 PM   #614
n00b is on a distinguished road
this seems like it wont get answered but ill try neways...
03 dime 4.5/5" drop.. will i be able to fit a 15x3.5 front with a 26x7.5 tire and a 15x10 rear with 5.5bs with a 325/50/15?
Old 06-25-2008, 02:29 PM   #615
acharyrd08 is on a distinguished road
what is the bolt pattern for a 2000 sonoma.....
Old 06-25-2008, 09:27 PM   #616
No7
No7 is on a distinguished road
5x4.75
Old 06-29-2008, 09:46 AM   #617
Blazer User
4UH8Rs's Avatar
4UH8Rs is on a distinguished road
can you layout on stock 235/70/15 on a blazer?
Old 07-03-2008, 03:19 PM   #618
Undecided Inches ??
Tea_BaggN's Avatar
Tea_BaggN is on a distinguished road
Have a 88' s10
want to know backspacing for 20 x 8.5 (8)" on 255/35/20 tire. all the way around
bagged/SFBD (2 doors)
Sorry to bug yall, but thanks for info
Old 07-05-2008, 06:17 PM   #619
vinny08 is on a distinguished road
Thumbs up Re: New Updated Rim/Tire Fitment For S Trucks
Quote: Originally Posted by Chevy2000Xtreme
i wanna put 20's on my s10 (2000 X w/ belltech 2/3drop) and was wondering if i could just put the rims on with no problems with a 4.75 bs with 245/35/20 tires. I don't know too much about this so any helpful info would be appreciated. Thanx Brian.
i got 20s on my exreme with a 2/3 drop with the same tires the only prob i have is when i crank the wheel all the way
Old 07-05-2008, 06:20 PM   #620
Quote: Originally Posted by Phillly
dumb question: what exactly is backspacing? and how can it be adjusted?
its a disk that goes inbetweem your rim and axel
Old 07-07-2008, 08:58 PM   #621
copo69's Avatar
copo69
i have a 97 s10 and want to go as wide of a tire as i can on a 17 x 9.5 in the back. what kind of b.s. would I need and how wide of a tire can i go I have belltech 3"leafs in the back. or better yet what width if not 9.5" would be best to fit the widest tire i can without any mods. 10",10.5"? thanks
Old 07-07-2008, 09:00 PM   #622
NORCAL SS's Avatar
17x9.5 285 40 17 on a 5.25 bs will work perfect
Old 07-07-2008, 09:16 PM   #623
copo69's Avatar
copo69
can i go any wider like 305 or 315 because it is v8 power with no traction lol
Old 07-07-2008, 09:24 PM   #624
Groundd Kustoms Sales Rep
Innis's Avatar
Innis is on a distinguished road
ok so im going to be going to 20s this winter, because i had problems with my 18s rubbing once i put them back on after i put my djm drop spindles on, i had some rub issues on the inner side of the rim
anyways, my question is, what width and backspacing should i go with to have the least amount of rubbing when i turn and so on with 20" wheels, the truck is a 2001 stepside s10 and im fully bagged
any help would be good
thanks
Old 07-13-2008, 10:35 PM   #625
BDUB
twolow10's Avatar
twolow10 is on a distinguished road
I m got a question about 22 inch tires. I m going to have 20 22 inch combo on my 88 what would be a good tire mock up since i dont have the rims yet. I have the 14 inch stockers on right now. I have the sd three link about to be installed and the step notch to lay out on 22s. If that matters. Any help would be nice.
Old 07-14-2008, 01:35 PM   #626
iridelo is on a distinguished road
bagged and bodied 99 dime with a vortec v6 for a 20 front and rear whats the corrct offset including rear with a 10.5" / front 9"
Old 07-15-2008, 12:30 PM   #627
JoeWinchester's Avatar
JoeWinchester is on a distinguished road
Can a stepside lay FRAME on 20's in the front and 22' in the rear? Even with a really low profile tire?
Old 07-17-2008, 01:00 PM   #628
broke_enthusiast is on a distinguished road
I'm interested in getting the foose nitrous II rims for my s10 with drop spindles laying frame on air. What backspacing, offset, and tire size would be the best for 20x8.5. Thanks!!
Old 07-17-2008, 01:02 PM   #629
I'm running 18" condors right now that work perfectly and would like to get the same effect with a 20"
Old 07-23-2008, 04:23 AM   #630
NORCAL SS's Avatar
sup guys bring me your questions
Old 07-27-2008, 11:47 AM   #631
a new beginning...
redsdime's Avatar
redsdime is on a distinguished road
how about the fatest size on new style ZQ8 with 3/4 drop and i d like to get the sidewall closest to the fender if i can thanks man
Old 07-29-2008, 01:25 PM   #632
Old 07-30-2008, 11:58 PM   #633
Undecided Inches ??
Tea_BaggN's Avatar
Im using 15x8" wheels, i plan to body drop on 255/35/20s...
what size tire will i need to make the equivalent size of the 20s?
btw, lol, rolling these 15s to do the BD, and to save for the bigger wheels thanks
Old 08-02-2008, 10:35 PM   #634
ArrestMeRed's Avatar
ArrestMeRed is on a distinguished road
What will it take to put the rims off my 01 Z06 on my 03 Xtreme? They are 295/35 ZR 18 on the rear and 265/40ZR 17 on the front. I may get another pair of 18's for the front if they will fit and have 18's all around. My X is bone stock with no drop or bags. What do you think? Mike
