LinkBack (1) | Thread Tools |
#451 |
S10 TIRE/WHEEL MASTER
Re: New Updated Rim/Tire Fitment For S Trucks
245 40 18 front and rear 20x10 275 35 20. Honestly i would do a 18 combo all aroudn just some fat meats in the rear. |
#452 |
#453 |
18X9.5 5.25 BS 285 35 18 i think they make a 295 35 18 also |
#454 |
So Fresh N So Clean
Yea, 19s might be an option, what would I run on those? I just want it to look really good with little as rub or no rub at all. Now all I gotta do is figure out where at online or local to get some good deals on rims w/ tires. |
#455 |
19s might cost more. i think 18x8 18x10 would look best.
#456 |
So Fresh N So Clean
#457 |
#458 |
So Fresh N So Clean
#459 |
4/4 drop 245 40 18 and rear 285 35 18 or 295 35 18 18x8 4.5 bs and 18x10 5.5 bs |
#460 |
i like mine with no shine
and one more question, what is the overall diameter of that size tire? 225/45/16 thanks for the help! |
#461 |
215 45 16 23.6 tall and good for a 7-8 inch wheel if you want to be really safe 225 45 16 23.7 tall and good for a 7-8.5 wheel the first gens with zq8s the wheels are really close to the lip if you bag it so you cant go really wide on it. I would test fit the wheel without the tire on the truck before you buy anythign then you can see if a 215 or 225 would be better for your app Last edited by NORCAL SS : 09-19-2007 at 12:04 PM. |
#462 |
now all i need to do is find some of them damn zq8's lol |
#463 |
Would a 18x9.5 with 5.5" BS be okay on the rear of a 4 door first gen Blazer lowered 5/5?
#464 |
#465 |
You will need to trim the xtreme fenderflare nothing major. 18x8.5 id look into a 4.75 bs wheel |
#466 |
What would be considered and ideal wheel/tire height for an '88 s10 blazer with a 2/3 drop?
#467 |
Re: what will fit my truck
i have 84 s10 with 350 want to lower it 4/5 spindles and springs in front i have 18x7.5 with 2454018 tires they have +35BS will they fit with a 1.25 spacer???
#468 |
I have a 98 S-dime w/ a 255/30/22 Wanli, 22x8.5 rim size and a 35+ offset w/ 1/4" spacers in the front and 3/8" spacers in the rear. They fit fine no worries on the upper fenderwell and wheel well fitment, but does rub frame when turning lock to lock, but ure not going to be going fast w/ 22's and as long as u dont get too crazy whipping the tires around ure not going to rub at all after you figure out how far you can turn lock to lock. I can turn around in gas station parkling lots, in and out of stores etc.....for the people that say 22's wont fit and will rub too much they need to get a set for themselves, and really see. |
#469 |
Ok, If i am 4/5 w 18x7 all the way around how much wheel gap will I have with 225/40 18
#470 |
#471 |
My 2000 sonoma is bagged so if I run a 18x7 with a 4bs with 215/40/18 and in the rear 18x9 with 5.25bs with 275/40/18 I will be okay? I know the 35 series would be better but I don't want to crack rims.
#472 |
ok what about 18x8 w 235/40 18. I appreciate your patience with me, wheels and tires are not exactly a small purchase so i want to get it right.
#473 |
or if i ran a 245/40/18 in the back with an 18x8 wheel, what bs?
#474 |
i have a 89 s10 no front inner fenders this winter i want to put on 18's but im afriad of the rubbing and dont knwo how bad it is really gona be that abd i also want it set up with a 4 inch drop with that if anyone knows anytihng about ti can u throw sometihng up in the air im curious about it but afraid to spend the money on the rims
#475 |
18X7 4 inch bs 215 40 18 rear 18x9 5 inch bs 275 35 18 or if you do 18x8 245 35 18 or 245 40 18 |
#476 |
18x8 4.5 bs 235 40 18 will be fine |
#477 |
Since you have no inner fenders in the front you could run between a 225/40 with a about 4 inch b/s and not have to worry about hitting the nothin at full lock. If you wanted you could put 245/35's on the back maybe a litte more backspacing than 4. Here take a look at mine I know its not the same year but it could give u an idea of what will really fit on a S-10's. I've seen 24's on your body style dime, but if that aint you then do what you do here's a pic. |
#478 |
Since you have no inner fenders in the front you could run between a 225/40 with a about 4 inch b/s and not have to worry about hitting nothing at full lock. If you wanted you could put 245/35's on the back maybe a litte more backspacing than 4. Here take a look at mine I know its not the same year but it could give u an idea of what will really fit on a S-10's. I've seen 24's on your body style dime, but if that aint you then do what you do here's a pic. |
#479 |
#480 |
#481 |
If you ordered them with 5.25" backspacing and u dont end up with quite enough room, u can always use a small spacer.....but u could prob run that tire size w/ that back spacing. Do you have modified fenderwells, since you are bagged? And the 275/40/18 will be taller than the 275/35/18 which shouldn't crack the wheels unless you really hit something |
