most cost effiective rear disk swap?
Old 01-02-2008, 01:14 PM   #1
cincystepside00's Avatar
Hi all once again. I'm wanting to do the 4 wheel disk swap on my 00'dime but as i've been looking all the conversion kits are $$$$. Would it be possible just to get a blazer rear end and swap the rear ends out? thanks again all any additional info just ask i'll get it asap.
Old 01-02-2008, 01:28 PM   #2
5, 6, 4, 3....Yea, Right.
Bootylicious's Avatar
Re: most cost effiective rear disk swap?
from what i understand, you should just be able to swap it out with the blazer rear end...ive been looking into doing this also. curious to see what people who have done it have to say.
:subscribes:
Old 01-02-2008, 01:48 PM   #3
Back in CALI
SHROP's Avatar
:subscribes:
Old 01-02-2008, 02:34 PM   #4
More Go then Show
THEKING's Avatar
ls1 camaro rear brakes.
Old 01-02-2008, 05:33 PM   #5
I tried to find out but had to find out for myself
A 54.5" rear end from a 2wd blazer will work, that is what I have in my s10 now...
3:42, limited slip, disk brakes, swap the whole thing for less than a kit...
Hope this helps...
Old 01-02-2008, 05:39 PM   #6
Proud Of My Zuki
Dr.pRymer's Avatar
theres this too
http://www.daymotorsports.com/product/1762#
Old 01-02-2008, 05:53 PM   #7
Under Construction
digbmx4130's Avatar
http://www.s10forum.com/forum/f13/dr...how-to-167132/
Old 01-02-2008, 06:29 PM   #8
Static> Bags
Bad94's Avatar
Quote: Originally Posted by Dr.pRymer
Thats set up is JUNK.
Old 01-02-2008, 06:30 PM   #9
Static> Bags
Bad94's Avatar
I would do the Blazer or LS1.
I see ur in cincy, were about?
Old 01-02-2008, 06:39 PM   #10
thanks for the replys all maybe i'll get into the thread suggested later on tonight.ok say i go with the blazer rear end would i still be able to have my ebrake and would i have to have new lines,master cyclinder....etc to have everything work properly? I'm in West Chester, where abouts do you call home on this single digit snowy night?
Old 01-02-2008, 06:46 PM   #11
Proud Of My Zuki
Dr.pRymer's Avatar
why do you say that? just asking because i was thinking about getting it
Old 01-02-2008, 07:53 PM   #12
Static> Bags
Bad94's Avatar
Just had a car in the shop with a set up like that, and we never got rear brakes, took that set up off and throw it away(yes i really throw it in the dumpster) and put a LS1 set up on it and car stops on a dime.
Old 01-03-2008, 01:13 AM   #13
Proud Of My Zuki
Dr.pRymer's Avatar
how much is an LS1 set-up usually cost??
Old 01-03-2008, 08:09 AM   #14
Static> Bags
Bad94's Avatar
Depends, i have seen them go from $50-$200
I have $75 in mine right now.
Old 01-03-2008, 09:30 AM   #15
Ass-Ten Layin' Y-Pipe
PSYKO_Inc's Avatar
How big are the LS1 rear rotors and will they fit with 15" wheels? Also is there a way to keep the parking brake?
Old 01-03-2008, 12:07 PM   #16
Static> Bags
Bad94's Avatar
They fit in some 15" wheels.
And yes there is a way to keep the E brake(im working on a kit and there is another memeber that is working on a kit)
Old 01-03-2008, 03:15 PM   #17
Proud Of My Zuki
Dr.pRymer's Avatar
you got a parts list for it?
Old 01-03-2008, 03:27 PM   #18
It's a Blue thing...
♠ M®. ßlυε ♠'s Avatar
I have a 97 z28 rear disc on mine.
Old 01-03-2008, 03:31 PM   #19
Static> Bags
Bad94's Avatar
Yea i will find all the part #'s for you.
Also watch Ebay.
Old 01-03-2008, 05:14 PM   #20
the prices i'm seein for the ls1 kit is making me change my mind about the rearend swap, a parts list would be great too, will it affect my rim fitting? i have stock zq8s right now and gonna be getting a set of chromed 17"zq8 style from lmc trucks and don't really feel like blowing the money for new rims/tires come spring time then they don't fit
Old 01-03-2008, 08:58 PM   #21
Stock
2002Chad's Avatar
most fourth gen f-bodies come stock with 16" wheels. you won't have problems with 16" or bigger. just some clearance issues 15" wheels.
Old 01-04-2008, 12:02 PM   #22
More Go then Show
THEKING's Avatar
Mine fit the stock 15" swirls
Old 01-04-2008, 12:35 PM   #23
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
hmm I need to do this.
Old 01-04-2008, 01:32 PM   #24
Proud Of My Zuki
Dr.pRymer's Avatar
hmm i need a parts list to do this....hahaha
Old 01-04-2008, 03:35 PM   #25
Whood'a Thought
russell's Avatar
are you swapping a camaro rear end whole or just the braking system?
Old 01-04-2008, 03:49 PM   #26
bellcranks no more
greencactus3's Avatar
i need you to take high quality pictures of this swap
Old 01-05-2008, 01:12 AM   #27
Fate0N3's Avatar
I agree a parts list and maybe where to even go to pick some of the stuff up (off the internet) would be killer. I have been wanting to do this since I am doing an LT1 but haven't had any luck finding a blazer locally with rear disk. And the first kit linked looks good but I wasn't able to find info on the install or anything. I am interested in doing the LS1 rear swap seems a better route then installing a whole new rear end. Thanks man
Old 01-05-2008, 09:30 AM   #28
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
If I can get the parts I will do that!
and even make a How to!
Old 01-05-2008, 12:20 PM   #29
Static&gt; Bags
Bad94's Avatar
Im working on the parts list, i have it about 50% done.
Also there is a complete set of ebay right now.
I know for a fact that brand new GM parts is way more then a used set on ebay or somewere else.
Old 01-05-2008, 01:14 PM   #30
Proud Of My Zuki
Dr.pRymer's Avatar
link?
Old 01-05-2008, 05:30 PM   #31
Draggin Moderator
98layinframe's Avatar
the Camaro brake setup is nice, but if ya want to run a working e-brake cable u need a custom bracket made. So why not just run blazer rear brakes? It too has a 12" rotor just like the ls1 Camaro setup does, only the nice part is everything bolts right up to the S10. All ya need to order a set of rear brake cables from a 4x4 ZR2 s10 that will connect to your stock front cable and then connect right up to the blazer E brake setup.
I paid 100 bucks for my blazer rear brakes, so its not like there a very expensive setup.
Old 01-05-2008, 07:01 PM   #32
Static&gt; Bags
Bad94's Avatar
There not 12" there smaller. The only thing is the blazer brakes are harder to find cheap.
Here are a few ebay links
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
I wont pay 250 shipped for the kit.
Yes the e-brake is the only down side, but im working a bracket and cables. Wont be long.
Old 01-06-2008, 01:48 PM   #33
Draggin Moderator
How do ya figure? I measured my rear blazer rotors and there exactly 12" in diameter, nearly identical in diameter to my front brakes from the camaro setup.
Old 01-06-2008, 04:09 PM   #34
Static&gt; Bags
Bad94's Avatar
Well i got the list done.
I will be doing a How to: as soon as i get all my parts cleaned and painted.
LS1 Rear Brake Part Numbers:
Backing plates: 10444625 & 10444626
Rear Calipers: 12455127 & (Right) 12455127
Caliper Abutment: 12456459 (need 2)
Flex Hose and Banjo bolt: 22163484 (need 2)
Caliper slide pins: 12530697 (need 4)
Brakepad hardward kit and pads and rotors.
Those are the big parts, but when i do a how to, you will see everystep.
Old 01-06-2008, 04:33 PM   #35
hey thanks a lot, now for the depressing part...spending the money
Old 01-06-2008, 04:54 PM   #36
Proud Of My Zuki
Dr.pRymer's Avatar
thanks man.
i hope i can find this stuff cheap
Old 01-06-2008, 05:32 PM   #37
Static&gt; Bags
Bad94's Avatar
ebay
Those calipers are over in 4 hours, thats a good price for those.
