how to put disc brakes on the rear for under 200 bucks step by step
Old 03-11-2009, 03:25 PM   #51
I dont know what I'm doin
Ians10's Avatar
Re: how to put disc brakes on the rear for under 200 bucks step by step
good for show trucks.. but not a daily driver.. around here you will not get a inspection sticker without a e-brake
Old 03-17-2009, 10:11 PM   #52
hack is wack
tyson_cbr's Avatar
That's why Illinois kicks ass, no inspection and good how to man and thanks for the 4link!!
Old 03-22-2009, 10:13 AM   #53
yay for edc
ronnie36695's Avatar
i love that idea bro great info in this thread im going to look at doing this upgrade
Old 03-23-2009, 11:37 AM   #54
devildragger's Avatar
Thanks very much guys I did this thread to show there is a cheap easy way to put disc brakes on the back of a s10.
Old 03-23-2009, 10:11 PM   #55
ROLL TIDE!!!!!!
draggindime072010's Avatar
Cool Re: how to put disc brakes on the rear for under 200 bucks step by step
Is it possible to just buy rearend from a 98 up blazer and just bolt it in in my s-10 2wd. It is also bagged with a threelink and notchs would that interfere with anything? my three is the bolt in from suicidedoors.com
Old 03-23-2009, 11:11 PM   #56
No wouldn't work blazer rearend is wider
Old 03-24-2009, 12:09 PM   #57
Killing Time
Petro's Avatar
Yes it would work...... 2wd rearend are all 54.5" WMS and 4wd rears are 59" WMS.... So if his was 2wd and he swapped a 2wd rear NO PROBLEMS....and so on...etc...etc...
Old 03-24-2009, 06:43 PM   #58
ROLL TIDE!!!!!!
so all i would need to do is swap the rear end from a 2wd blazer and hook up the brake lines?
Old 03-24-2009, 07:35 PM   #59
Killing Time
Petro's Avatar
YES.... with or without same gears...different gears the speedo would be off and trans would shift differently...Just go with same gears...
Old 03-24-2009, 08:55 PM   #60
ROLL TIDE!!!!!!
Do you know what gears are in my truck? its a 2.2 with the 5 speed and the rear end thats really common i think its 7.5 or something like that
Old 03-24-2009, 08:59 PM   #61
Killing Time
Petro's Avatar
Look for one of these codes in your glovebox...it'll be on a sticker...
GU4=3.08
GU5=3.23
GU6=3.42
GT4=3.73
GT5=4.10
HC4=4.56
G80 - locking differential
compare to the codes in your glove box to know which gear ratio you have
Old 03-24-2009, 10:13 PM   #62
ROLL TIDE!!!!!!
ok thanx a lot there is a place around here that i can get the rear end from pretty cheap so im gonna do it pretty soon
Old 03-24-2009, 11:23 PM   #63
thanks for the info guys ... this really helps & Hopefully I'll be doing the whole rear end setup out of a 98+ for the rear discs then the front rotor swap as well!!!
Old 03-25-2009, 04:42 AM   #64
Juice&Docs' Drop Shop
_juice_'s Avatar
i wonder if this would work on a 62 belair? seems to me it would be pretty much the same thing...right?
Old 03-25-2009, 10:32 PM   #65
*LO4U2NV*'s Avatar
GU4=3.08
GU5=3.23
GU6=3.42
GT4=3.73
GT5=4.10
HC4=4.56
I was able to find the proper ratio rearend at a local salvage yard. Does it matter what size ring gear it has if I plan to use the whole rear end? They only have a 7 5/8" but no 8 1/2".
PS awesome job on the how to here. If the price is right, I might just swap the rear, but if not, this page has been added to my subscriptions.
Old 03-25-2009, 10:38 PM   #66
Molon Labe
BudRacing's Avatar
Ring gear size doesn't matter in a full axle swap. As long as it has the same ratio gears it should work.
Old 03-25-2009, 11:17 PM   #67
Killing Time
Petro's Avatar
If you swapped a 8.5 rear in and you didn't already have one ,then you would have to shorten the driveshaft 2" .Because the pinion yoke sits 2" further forward than the 7.5 rear....
Old 03-28-2009, 08:04 PM   #68
Bad-S's Avatar
this is exactly how mine are done. i have calipers off a old caddy seville that have the ebrake included in them. i dont use them but if anyone wants the ebrake that is an option
Old 04-02-2009, 12:51 AM   #69
no_pulse's Avatar
So if I found a 4wd 98 Jimmy or Blazer rear end, could I use that on my 4wd 97 Jimmy if the gear ratio's are the same? Would I need to modify it or would it be a simple swap.?
Old 04-02-2009, 11:12 AM   #70
Killing Time
Petro's Avatar
No need to modify...It would be a "simple" swap....
Old 04-03-2009, 03:24 AM   #71
no_pulse's Avatar
Sweet. Now its just the task of finding a complete 4wd 98 jimmy rear end.
Old 04-06-2009, 01:31 PM   #72
trucky's Avatar
Yea but wouldn't the proportioning valve have to be swapped out to disk/disk instead of the disk/drum?
Old 04-06-2009, 01:49 PM   #73
Killing Time
Petro's Avatar
Not necessary...but you could if you would like to...
Old 04-09-2009, 10:35 PM   #74
Hmm.. well now..
Gearstix's Avatar
Could you use/make a dust shield or whatever for the back of the rotor like factory disc vehicles come with, just so crap don't get in there, or is it really needed?
Old 04-14-2009, 06:02 PM   #75
Playin in the mud
kacy's Avatar
Found some info few years ago and it worked.The rear brake set up off any 10 bolt gm rear will swap to another 10 bot.I swapped rear brakes from a 95 camaro z28 that has the 7.5 10 bolt to a 69 camaro that had the 8.2 10 bolt.What makes this really nice is you get the backing plates and the mount from the donor rear end and installs and all looks factory.
Old 04-14-2009, 07:01 PM   #76
Killing Time
Petro's Avatar
^^^It's not always that easy...Not all GM 10 Bolts have the same housing ends...And there are different axle flange offsets to take into account...
Old 05-13-2009, 06:55 AM   #77
i dont understand how to get brake fluid to the calipers??
Old 05-13-2009, 07:03 AM   #78
U bolt the brake line to the calipers and bleed the brakes
Old 05-13-2009, 02:20 PM   #79
Lo-noma's Avatar
curious to know, my company goes through alot of astro vans for our service vehicles. and i've notice alot of em have the disk brake rears? would that work out? also would some of them are AWD,(i know i should ask this in the drivetrain thread) but would the awd setup beable to be transplanted? cuz that would be bad ass.
Old 05-13-2009, 07:38 PM   #80
i asked a buddy today and he told me to grab everything starting with the "dual" master cylinder and all the way back. i really want to get rid of the drum brakes. think i'll need to grab the fronts too??
Last edited by rider0033 : 05-13-2009 at 07:40 PM. Reason: read differently then i typed it
Old 05-13-2009, 08:18 PM   #81
Killing Time
Petro's Avatar
No need to change master cylinders...The fronts wouldn't be a upgrade unless they are the dual piston fronts...
Old 05-24-2009, 09:14 PM   #82
Panface
specsix's Avatar
I am having the worst time trying to find the weld on brackets. All the from summit, jegs, and speedway say they are for a 11.75" rotor. Well the rotor for a 98+ blazer is 11.5 inches. Also my axle tube is not 3" in diameter; it is almost 3" , but its not. I have a 7.5 10 bolt rear end.
I guess the brackets will work with slightly smaller rotors?
This is what I want to get
http://www.speedwaymotors.com/GM-Wel...kets,3348.html
But it looks nothing like the one in that is used in this how-to.
Can anyone clear this up?
Old 05-25-2009, 11:55 AM   #83
Killing Time
Petro's Avatar
I know that our axle tubes are 2.75" in diameter...
Old 05-25-2009, 01:25 PM   #84
Panface
specsix's Avatar
Yeah. That is what I thought. Now that you have confirmed that, I think I am screwed. I bought all the stuff for the conversion, but the brackets are the last thing I need. I ordered some locally, but they were the wrong ones, so I decided to look at the online shops, but nobody has them for 2.75" axles. I hope I am just getting unlucky with my search. I really do not feel like taking off the axles on my new rear end rebuild to put on junk yard backing plates.
Old 05-25-2009, 11:37 PM   #85
ya u can use that bracket or the other one in the upper picof the add. all the brackets i found are for 3 inch to i had a lil gap to weld up on the ends of the brackets
Old 05-26-2009, 02:19 AM   #86
Panface
specsix's Avatar
Thanks for clearing that up man. That helps a lot.
Old 05-30-2009, 05:14 PM   #87
Panface
specsix's Avatar
Just to follow up.
I bought those brackets. Well they did not really fit with my rear end/rotor combo. The caliper holes were exact, but the length of the bracket was not long enough to fit the rotor (off about 1/4 of an inch). I was expecting only the ends to have gap, but the entire bracket had to be raised 1/4 off the axle tube.
What I did was weld a 2.75 inch diameter half pipe piece that was 1/4 inch thick to the axle. I then welded the bracket to that. The best thing was to get the correct bracket, but to be honest, I really do not think there is a correct bracket. I have a stock rear end and used blazer 98+ rotors.
Anyways, the calipers are on and both sides seem strong and stable. Just thought I would share my experience.
Old 06-03-2009, 07:08 PM   #88
Killing Time
Petro's Avatar
^^^You should've just used stock blazer parts...Much easier swap...No welding required...Just space the stock bracket out from the axle tube flange about 1/8"-1/4" and plus you would have ebrake....
Old 06-07-2009, 11:38 PM   #89
hey i may have dibs on a complete f-body rear diff with complete disc set up inner parking shoes and all. all of this should be a direct swap too right? When i disassemble everything then reassembly with the clips as above, then install the disc set up ya? will i need to sapce out the brackets as you do with the blazer 2wd? also this has a G80 carrier, is it worth a swap?
Old 06-12-2009, 03:25 AM   #90
thrice4life44's Avatar
can you use a front rotor for the rear?? or are the rotor sizes different....
Old 06-15-2009, 01:00 AM   #91
Molon Labe
BudRacing's Avatar
They are different.
Old 06-15-2009, 12:18 PM   #92
not intending to Thread Jack .......
$199
http://www.s10forum.com/classifieds/...ct/51381/cat/6
Old 07-21-2009, 09:51 PM   #93
kdnybtr's Avatar
i just finished mine, this thread helped out alot. the only thing i would add is to replace the wheel bearings and seals. bearings are about $6 and the seals are about $4. advanced auto has a slide hammer with attachments to rent and it only took about 10 minutes since the axels are already out. it might really need to be done but its cheap and its already apart. just weld up the caliper brackets with the old bearings and seals in before you replace them.
Old 08-06-2009, 07:20 PM   #94
wat u do for brake lines
Old 08-13-2009, 08:39 AM   #95
would these work and how difficult would it be?
http://www.speedwaymotors.com/75-GM-...Kit,14021.html
or these
http://www.speedwaymotors.com/Speedw...rake,1999.html
or
http://www.speedwaymotors.com/GM-Com...Kits,2000.html than
and which one would be the best buy?
thanks
Old 09-30-2009, 04:02 AM   #96
Just Some Guy
l008com's Avatar
So in Massachusetts, you can't get an inspection sticker if your ebrake can't hold your vehicle still with it in drive. Is this mod for off road use only? Or am I missing something?
Old 10-01-2009, 12:17 AM   #97
It's old, but this shows other options instead of having to weld, if you don't have a welder...
http://www.s10forum.com/forum/f14/re...51/index4.html
You can get even fancier, and buy this kit....
http://cbrperformance.com/syclone.php?Category=Syclone
Old 01-23-2010, 05:06 PM   #98
fast truck fleeger
arSonoma's Avatar
are the backing plats off the rear disc equiped blazers all the same weither they are 4wd or not?
Old 01-23-2010, 10:25 PM   #99
DriftinBlzr's Avatar
I know that on my '02 2dr 2wd Blazer, the calipers are toward the rear of the vehicle and I picked up backing plates from a 4dr 4wd Jimmy and the calipers were toward the front. I think the location of the caliper has more to do with a 2dr vs 4dr frame than 2wd vs 4wd. I'm sure someone will correct me if I'm wrong.
Later, Doug
Old 01-31-2010, 01:28 PM   #100
eatinpavement's Avatar
nice idea and write up. yeah there are better ways of doing this but most minitruckers i know are all about pinching some pennies and thinking outside the box to do so.
for the brake lines you can either bend them around or cut them back if you have a means for reflaring the ends and then attach a set of hoses to them like the front has or if you are using the blazer setup just grab the line assembly with hoses from the donor vehicle.
