How to bleed the brakes
Old 07-03-2008, 03:29 PM   #1
Goran's Avatar
Goran is on a distinguished road
Can anyone give me a how to on bleeding the brakes...
or a link?
thanks
Old 07-03-2008, 03:32 PM   #2
hot damn.
lee-mill's Avatar
lee-mill is on a distinguished road
Re: How to bleed the brakes
have someone pump them, then open the bleeder valve on the calipers/wheel cylinders, make sure you dont run outta brake fluid in the master cylinder cause ull get a shit load of air in there
Old 07-03-2008, 03:46 PM   #3
Cutting Edge
truefire04's Avatar
truefire04 is on a distinguished road
ill tell you an easyer way, go get you some clear hose, like 1/4" get a power aid or gator aid bottle drill the lid out enough so that you can put the house down into the bottle, fill the bottle with new brake fluid, maybe half way, enough to cover the hose. go to the pass. side rear, crack the line open put the other end of the hose on the bleeder valve, go get in your truck pump away....KEEP AN EYE ON YOUR MASTER CYLINDER....KEEP IT FULL! when you see clean brake fluid stop your done, go dump the bottle out, keep it half full of clean fluid. go on the the others, by the time your done you will have clean fluid in your hole system. and you can do this yourself without any help.
Old 07-03-2008, 03:54 PM   #4
Cutting Edge
truefire04's Avatar
this is what it should look like. it works really good.
Old 07-03-2008, 04:17 PM   #5
Cutting Edge
truefire04's Avatar
oh and becareful and have fun.
Old 07-03-2008, 07:13 PM   #6
e'sxtreme's Avatar
e'sxtreme is on a distinguished road
i was wondering something.i broke a hard line to my pass. front.bought and bent up a new one then replaced it.when i went to bleed the brakes,i got nothing.tried 10x.no air no fluid.but my caliper was claping up perfect.like brand new.does the abs have anything to do with it?(sorry for whoring thread)
Old 07-06-2008, 09:45 AM   #7
Lifted97s-10 is on a distinguished road
Very important when you bleed the brakes to do it in the right order...me and my cousin learned that the hard way on his 2000 noma after doin a ford 8.8 axle swap...if you dont do it in the right order you will easily tell because you'll have almost no pressure when you are pushin down on your brakes. You should be able to look it up online or possibly in your truck manual to find the order it goes in.
Page generated in 0.09417 seconds with 12 queries
