Help!!! Why are my brakes sticking???? - S-10 Forum
post #1 of 19 Old 12-01-2007, 02:41 PM Thread Starter
jtupnsmoke's Avatar
User is: jtupnsmoke is offline
Ok, it is my 1999 Tahoe 2wd. I have replaced that Master cylinder and both front calipers and it still sticks real bad. Does anyone know what might be my problem. I can't think of anything else that would cause them to stick.
98' 2.2 , 20" Boss 304's, Roadgrater, Re 6's up front, Checkmate Tonneau
post #2 of 19 Old 12-01-2007, 02:56 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Help!!! Why are my brakes sticking????
Could be the rubber lines are collapsing.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #3 of 19 Old 12-01-2007, 03:28 PM Thread Starter
jtupnsmoke's Avatar
I have just looked at them. They look fine but I haven't replaced them. They don't stick all the time, but pretty frequently.
post #4 of 19 Old 12-01-2007, 10:36 PM
B4U Task Force
They may look fine but that doesn't mean they are. I'd get replacements front and rear.
Apple Red 96 SS
post #5 of 19 Old 12-02-2007, 06:31 PM Thread Starter
jtupnsmoke's Avatar
All the brakes have been changed. It only sticks in the front and the brakes, calipers, and the master cylinder have been changed. So I am hoping someone else has had this problem with their chevy and could help me out. And when I said "I just looked at them" a couple of posts up, I was referring to the rubber hoses, not the brakes. The brakes have all been changed.
post #6 of 19 Old 12-02-2007, 07:36 PM
B4U Task Force
I don't mean to beat a dead horse but if all else has been changed, do the hoses. They can collapse when brakes are released and cause the brakes to stick.
Apple Red 96 SS
post #7 of 19 Old 12-02-2007, 08:40 PM
Blown ex ***
Jess's Avatar
User is: Jess is offline
what do you mean by "sticking" ?
97, VORTECH V2 SQ, PowerStroke FMIC @14 psi, A4, 3.08
a broken down 13.88 @ 96.65
now with, 2114, 270ahr, ported heads, 1 5/8 L/T's & true duals, TunerCat, LC1 & XD-16, 3:73 Z/T
My Truck...
95 x-cab, silver, tint, 4.3cpi, a4, 2/3 = after 10+ years its rusted out badly.
its replacement = pewter reg cab 01, 4.3, A4 and 0 rust
Jess is offline
post #8 of 19 Old 12-02-2007, 09:16 PM
B4U Task Force
My guess is he means the calipers are not releasing causing the pads to drag.
Apple Red 96 SS
post #9 of 19 Old 12-02-2007, 10:57 PM
XTREME
GOTDUBZ's Avatar
User is: GOTDUBZ is offline
I'm no mechanic but I had this problem after being bagged the front brakes would stick on after driving a little. Mine problem ended up being really simple. The brake booster had been replace with a hot rod one and the nut inside need to be turned a couple times so the pin inside would not stick out too far keeping the brakes on when not hitting the pedal. You may be sticking between the booster and the master cylinder. Don't know if that helps or makes since, lol?
ERIC LAYIN FRAME!!!!!!!! TwIzTeD iNtEnTiOns- Ohio
http://s110.photobucket.com/albums/n102/GOTDUBZ/
GOTDUBZ is offline
post #10 of 19 Old 12-04-2007, 03:24 PM
Chat Bitch
Primerdime's Avatar
User is: Primerdime is offline
Send a message via AIM to Primerdime Send a message via MSN to Primerdime
I'm with Rhotpursuit, check your rubber brake hoses.
Nathaniel
91 2wd w/ 1.5/3 Belltech--Sold
90 F250 5.0/5spd-Stock
08 Cobalt 2dr 5spd
Originally Posted by chevy84sdime View Post
i agree!! i must love penis.
Originally Posted by Hucko View Post
I would stand in your bed and piss all over your window.
post #11 of 19 Old 12-04-2007, 03:27 PM
NUKKA!!!
JDnoble18's Avatar
User is: JDnoble18 is offline
Send a message via MSN to JDnoble18 Send a message via Yahoo to JDnoble18
The rubber brake hoses can look perfect on the outside and be mush on the inside. "werd" on the hoses MANG!!!!!!
'90 S-10 4x4 4.3 --SOLD
'90 Camry 2.0 5 spd 318k and going strong!
'07 Impala 3.5 102k
'08 Silverado z71 5.3 34k
post #12 of 19 Old 12-04-2007, 03:29 PM
Banned
User is: SteveHH is offline
Send a message via AIM to SteveHH
x2
SteveHH is offline
post #13 of 19 Old 12-04-2007, 08:37 PM
Molon Labe
BudRacing's Avatar
User is: BudRacing is offline
Send a message via AIM to BudRacing
If its not the hoses, next culprit may be the abs
post #14 of 19 Old 12-06-2007, 11:20 AM Thread Starter
jtupnsmoke's Avatar
I unplugged the abs and it still sticks.And yes, by sticking, I mean the calipers are not releasing. I will change the rubber hoses and see if that helps.
post #15 of 19 Old 12-08-2007, 09:38 AM
Blown ex ***
Jess's Avatar
well. did ya fix it ?
My Truck...
Jess is offline
post #16 of 19 Old 12-12-2007, 02:06 PM
Forvm Lurker
anALLSHOx's Avatar
User is: anALLSHOx is offline
Send a message via AIM to anALLSHOx
must have if he aint back haha..
2002 S10 Xtreme 4.3V6 Auto X-Cab - Its on its 3rd build up since it was stolen twice... 20's, Tuned, Exhaust, Intake, Suede Interior, Blazer Floor Shifter
1999 S10 4.3V6 Auto X-Cab - Bagged on 22's
post #17 of 19 Old 12-12-2007, 02:31 PM
roadlet_411's Avatar
User is: roadlet_411 is offline
Send a message via AIM to roadlet_411
Or he drove off a cliff...
-jason
[02:25] <AK49BWL> I'll be damned!
[02:25] <AK49BWL> he's IRC literate to be sure.
Click on the image above to join!
post #18 of 19 Old 12-22-2007, 03:55 AM
necratic's Avatar
User is: necratic is offline
Send a message via AIM to necratic Send a message via Skype™ to necratic
Not to necropost or bump or anything, but I didn't know if it got fixed.
Anyhow, the culprit could be a couple of things. One, the rubber hoses could be failing, or clogged. 2, I'd replace the rotors. If there is any grease, oil, or brake fluid on the pads, they'll drag on the rotor, ironically enough. Lastly, if it is a floating caliper, pull out your floating pins and grease them up. I'd grease the caliper where it slides on the pins too, for good measure. If it's none of those, I suggest tweaking the power booster, like GOTDUBZ said.
necratic is offline
post #19 of 19 Old 12-22-2007, 04:17 AM
Don't look at my car
travy's Avatar
User is: travy is offline
Nope, he started driving towards the cliff and slammed on his brakes. And he's hung half way over the cliff, stuck.
His brakes are stuck so he can't back up and drive away, so he's just teater totering over a cliff.
Like this:
I love snoboarding and blondes.
travy is offline
