HELP! - Brakes Pads!
Old 11-07-2009, 02:21 PM   #1
I had a friend recently help me out by replacing my front brake pads on my 2001 4.3 Xtreme.
But I'm not sure he' installed them correctly:
Does the BRAKE PAD SCRATCH SENSOR FACE THE FRONT OR REAR OF THE TRUCK?
Thanks I'd like to know before I drive my truck anymore!
Old 11-07-2009, 03:05 PM   #2
AWD V8's Avatar
Re: HELP! - Brakes Pads!
It really doesn't matter, some vehicles have them on the trailing side of the pad, some on the leading side, it will work fine either side.
Old 11-07-2009, 03:13 PM   #3
Damn well I was told there was a right and wrong way by an older gentleman
Old 11-07-2009, 03:47 PM   #4
AWD V8's Avatar
well of course they are installed only one way from new, but the pads fit either way with no issues. The squeal tab clears everything and squeals just fine when worn.
I've tried both ways on many vehicles and it makes no difference.
Old 11-07-2009, 09:54 PM   #5
You...Tonight
mostizzle's Avatar
that jimmy's schweet man
Old 11-07-2009, 09:55 PM   #6
You...Tonight
mostizzle's Avatar
and i agree about the warning tabs
Old 11-08-2009, 12:22 AM   #7
My last set of pads wore at an angle, wearing the from much more than the rear of the pad. The scratch sensor was on the rear, and was completely untouched while the front of the pad was completely worn, leaving the rivits exposed which came in contact with the rotor, destroying a relativly new rotor..... I'm just gonna make sure they are in the front I guess.
Old 11-08-2009, 04:03 AM   #8
You...Tonight
mostizzle's Avatar
well if ur shits wearin on an angle that means ur slide pins are hangin up or the caliper isn't sliding on the mount properly so you should fix that lol
Page generated in 0.56079 seconds with 31 queries
[Output: 61.87 Kb. compressed to 58.13 Kb. by saving 3.73 Kb. (6.03%)]
