Help! 2000 S10 Tire Size - S-10 Forum
post #1 of 19 Old 01-14-2004, 09:37 AM Thread Starter
User is: pow211 is offline
Cool Help! 2000 S10 Tire Size
Hey,
I have a 2000 S10, with Tiger Paw 205-75-R15 tires.
I'm wanting to replace them with something
bigger- that doesnt look so puny.
What would be a good size that will fit on the standard 15" rims
without rubbing or causing problems?
Any reccomendations on Brand and size is appreciated.
pow211 is offline
post #2 of 19 Old 01-14-2004, 07:32 PM
eugenen's Avatar
User is: eugenen is offline
I went up one size 215-75-r15 but can't tell much of a difference, maybe try two sizes bigger. I think GM should have to reimburse us for those tiger paws, I had to replace them really early because I couldn't stand them.
2004 Silverado 4x4 z71
eugenen is offline
post #3 of 19 Old 01-14-2004, 07:38 PM
CastawayRay's Avatar
User is: CastawayRay is offline
I wonder if a 255 65 15 would fit aiight?
2003 2.2 Auto LS Ext Cab Fleetside
Goodies on the way <G>
ZQ8 Sway Bars, 33 mm and 24 mm
Energy Suspension Red Polyurethane Bushings
Soft tonneau and Duraliner bed liner
FIrestone FireHawk Indy 500 255-60-15 Bad Ass Tires!
post #4 of 19 Old 01-15-2004, 02:52 AM
a 255 60 15 wont affect the speedometer, I just dont know if the stock LS rim can handle the extra two inches of width
any ideas gang?
post #5 of 19 Old 01-15-2004, 09:52 PM
the guy on the couch
User is: tryptamine is offline
i put 235/60 on mine
i think its a good size, although it wouldnt hurt to have gone wider
'02 sonoma SLS ext. cab, white, v6 vortec, power everything, 2WD, emblems removed, DRL and AHL deactivated, basic home-made intake from eBay
dropped 3/4, on cooper cobra radial g/t 235/60/15s
still stock rims
want to go flowmaster soon, and im thinking about putting a system in soon as well
post #6 of 19 Old 01-17-2004, 06:11 PM
the buddman's Avatar
User is: the buddman is offline
Send a message via AIM to the buddman
i got a few compliments on my 235/75 michelins i had on my truck when it was stock.....they rubbed at full trun though.....even worse when i lowered the truck 3 inches
It's not how you stand by your ride, it's how you list it in your sig.
post #7 of 19 Old 01-17-2004, 06:37 PM
Ole skule VW nut
Pewter1's Avatar
User is: Pewter1 is offline
Funny you should ask. I just put 245/60's on mine, and I love the way they look. No rub at full locked turn either. Pd $300 mounted and balanced for the set.
'97 s10 Stepside
Pewter1 is offline
post #8 of 19 Old 01-17-2004, 11:33 PM
User is: oldredsel is offline
I ran 225/70/15 on my stock 94 LS 4.3 5 speed with no problem. Tony (N20 NOMA) has said in one of his old posts he ran 255/60/15 on a stock 94, so I'm considering those to replace the "kitty paws" on my 03 LS 4.3 5 speed. Those tires are pathetic!
post #9 of 19 Old 01-18-2004, 11:47 PM
Ole skule VW nut
Pewter1's Avatar
Re: Help! 2000 S10 Tire Size
I dunno about that. I run the 245's like I said, and they are really pretty wide. You can tell that the tire is way wider than what was planned. After looking at these, you would think 255 would be wayyy to wide. Tell us how that works.
'97 s10 Stepside
Pewter1 is offline
post #10 of 19 Old 01-19-2004, 01:10 AM
Green Monster 98's Avatar
User is: Green Monster 98 is offline
Send a message via AIM to Green Monster 98
i got 215/65/15 on mine i wish i went a little wider but like them.
post #11 of 19 Old 01-19-2004, 01:19 AM
footbraker
Rhansen's Avatar
User is: Rhansen is offline
Bottom of page:
http://www.geocities.com/return2sndr/calc.html
I use 275/60-15 rear and 235/60-14 front in the summer and 215/75-15 all the way around in the winter - with a 2/2 drop. The winter tires rub a little at full turn.
spare parts...
Rhansen is offline
post #12 of 19 Old 01-19-2004, 07:34 PM
mde83's Avatar
User is: mde83 is offline
On stock 15x7 wheels, you can run 225/60/15 in front and 255/60/15 out back...this combination is best for looks and the rear tires are almost exactly as tall as the stockers which means your speedo remains accurate. The only downside is that you wont be able to rotate your tires anymore. Also, the front tires are only about 1" smaller so it does not mess with your ABS. The rear size 255/60 is about as wide as you can go on a 7 inch rim. Some people have said the middle of their rear tires wore faster than the outsides. That did not happen to me or 2 of my friends running the same size.
2000 S-10 Base Model Regular Cab, Indigo Blue, 33K miles, Mods = bedliner, Extang soft tonneau, cluster with tach, 60/40's, audio, tinted windows, ventvisors, painted grille, billet grille insert, xtreme stripes, 15" Eagle 203's, keyless entry and alarm. Future mods = 3/3 drop, rollpan, mirrors, cowl hood and more.
Click HERE to see pics of my S10
mde83 is offline
post #13 of 19 Old 01-21-2004, 12:40 AM
Hi Kirk,
I ran 225/70/15 tires with no problems. I can vouch for this size.
The 255/60/15 tire option was suggested by Tony (N20 NOMA, 98 SS ON NOS, and now NORCAL STI) who is the author of the 2 "sticky" threads at the top of this forum. I have not yet tried them, but if you read through his threads/postings, Tony says he has. And he seems to know what he's talking about. The 255/60/15 tires are the same height as the stock 205/75/15, just 2" wider. My concern with smaller tires, like the 245/60/15, is not just the speedo, etc., but also they just look lost in the wheel well at stock height. In regards to the rim width, all tire manufacturers list acceptable rim widths of 7 - 9" for the 255/60/15. (Some manufacturers even list the acceptable range as 6.5 - 10"). So, since they don't rub and the rim width is not an issue, I think I'll try them. . . when the snow melts!
post #14 of 19 Old 01-21-2004, 09:38 AM
footbraker
Rhansen's Avatar
FYI the first three numbers in the tire size are the tread width in millimeters. So the difference between a 235 and a 255 is only 20 mm or less than 1 inch (1 inch= 25.4mm).
spare parts...
Rhansen is offline
post #15 of 19 Old 01-22-2004, 08:12 AM
S10 TIRE/WHEEL MASTER
NORCAL SS's Avatar
User is: NORCAL SS is offline
255 60 15 FIT ALL around no probs on stock s10 rims ive done tons of them
www.geocities.com/marks98s10
that had 255 60 15 rear
DJM LOWERING PARTS GARAGE BLOWOUT!!!
http://www.s10forum.com/forum/f291/d...erally-680138/
If you have any questions on lowering or tire sizes that fit on a s10 feel free to call or text me 415 519 2432 my name is Tony and around to help 24/7. YES 24/7 email norcalss06@aol.com
post #16 of 19 Old 01-22-2004, 12:58 PM
FBK
User is: four_by_ken is offline
Just to add my 2 cents...
I have 255/50R16 on all 4 of mine. Rear are fine. But the fronts rub at full turn.
Ken H.
post #17 of 19 Old 01-23-2004, 10:50 PM
User is: bri2203 is offline
Send a message via AIM to bri2203
I heard going 255 on a 7 inch rim is not the wisest idea.
bri2203 is offline
post #18 of 19 Old 01-23-2004, 11:34 PM
NORCAL SS's Avatar
255 60 15 fits on stock 7 inch rim fine
here is a 2000 s10 i did with 4/5 and 225 60 15 front and 255 60 15 rear
www.geocities.com/rods00s10
post #19 of 19 Old 01-27-2004, 12:38 AM
mrgtbike's Avatar
User is: mrgtbike is offline
Anyone got a pic of the rear of their truck with the 255/60s? Just wondering what it looks like from the back.
98 4.3 5 speed, K&N, Flowmaster Exhaust, Short Throw Shifter, 255/60's all the way around, Bucket Seats, efan
Spark Plugs, and wires to come
GO HERE!!!
mrgtbike is offline
