For those that dont understand backspacing and offset
LinkBack (1) Thread Tools
Old 07-19-2007, 11:06 AM   #401
Project Dime's Avatar
Project Dime is on a distinguished road
Re: For those that dont understand backspacing and offset
hey guys im was wanting to know if u could help me. i have a 89 4x4 s10 im looking a a 2 in lift and im wanting to get a set of wheels and im not sure how to order ( backspace offset, and any thing else i need to know ) them b/c i dont know much about wheels and stuff but i am wanting a wheel to stick out a little bit klind of like this one http://www.satdirect.com/snow/Perche...%20run/s10.JPG. thanks guys.
Old 07-30-2007, 08:54 AM   #402
former owner
98SS's Avatar
98SS is on a distinguished road
That's not sticking out just a little bit. That's a lot.
You'd need a large positive offset which would translate to very little backspacing. How much? We can't tell you unless you know exactly how much outside the fender you want it to stick.
Old 08-02-2007, 07:14 PM   #403
BLAZINRICH13's Avatar
BLAZINRICH13 is on a distinguished road
http://www.s10forum.com/forum/f14/please-help-307975/
Old 08-11-2007, 02:50 PM   #404
Twentyinchextreme is on a distinguished road
I have a 2000 S10 Extreme and was looking to put some 2006 Corvette wheels do they fit or is it totally different now and if they fit would i need spacers bc of the offset
Old 08-31-2007, 04:51 PM   #405
sonomasls02 is on a distinguished road
I got a set of 20" boss 308s from a friend.
Specs are:
20"x 8.5"
+10mm Offset
5 x 115
Backspacing Is 5.106 Inches
I have an 02 Sonoma ZQ8 stock suspension. My question is what thickness or size adapter would i need? I would need the adapter 5x4.75 to 5x115? I only plan on doing a 2/3 drop on the ZQ8 susp. so far. Also, what size tires would you prefer? Thanks.
Old 09-01-2007, 12:38 PM   #406
I need some help asap. I'm ready to put my wheels on already!
Old 09-03-2007, 03:07 PM   #407
Gow Low or Go Home
99SonomaHeavenS's Avatar
99SonomaHeavenS is on a distinguished road
yeah you would need a 5x 115 - 5x4.75 adapter, be careful and not get a thick one b/c it will push your tire out too far, with 20's you dont have to worry about the tierod with backspacing but it will rub neway around it.
to the guy who wants his wheels to stick out all i can say is run adapters, to have it stick out alot you would need a 9" rim with like 3" or less backspacing, id run adapters that way if you decide to return it to stock or something you can still use those rims
Old 09-04-2007, 06:00 AM   #408
http://www.adaptitusa.com/index.asp?...ROD&ProdID=121
which adapter thickness would be good?
Old 09-11-2007, 01:51 PM   #409
Puncture Wounds FTMFL
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
I'm trying to find out the backspacing for this wheel/tire combination. I eMailed the guy to see what it is... Just waiting for his reply
33/14.50/15 tires on 10" wide wheels with a 5 on 5 1/4 jeep pattern
Looks like I'll be needing some adapters (and maybe a lift, but I'll just take off my body panels until then)
Old 09-16-2007, 11:01 PM   #410
draggin96s10's Avatar
draggin96s10 is on a distinguished road
ok i have a ? so what would a 20mm = to? thanks
Old 09-20-2007, 09:36 PM   #411
layinlow-s-10's Avatar
layinlow-s-10 is on a distinguished road
will a set of wheels 20"x8.5" with an offset of +15mm tuck on a bagged s10?
Old 10-17-2007, 01:35 PM   #412
ateupcajun is on a distinguished road
Aliright well, I'll do the tires. The wheel I'm looking at is available w a +20, +35, +45 offset......... (clueless) also the center bore is either a 73 for the +35 and 74.1 for the +45 and +20. What do I need? and what is a PCD code? Thanks again for all your help. . If I do go with these wheels would I need a spacer?
Old 10-20-2007, 09:37 PM   #413
inh182 is on a distinguished road
will the 10 spoke vett rim fit my 01xtreme
Old 10-20-2007, 09:38 PM   #414
Kurrupted Kreations
Garage Customs's Avatar
Garage Customs is on a distinguished road
idk
Old 10-25-2007, 12:52 AM   #415
SublimeSTYLE is on a distinguished road
well guys looking to put a set of 15x7 cragar soft 8 on the front and 15x8 in the rear of a 4/5 dropped ext cab 85 s10. what size tires would i need to run for it not to rub would i need spacers. and also what offset and bs would i need to look at
. any help will be great from you guys
Old 11-03-2007, 04:41 AM   #416
alan5585 is on a distinguished road
2000 s10 extreme, looking to get foose nitrous rims, 18x8.5, 4.5 bs, -6mm offset, will these work, also i have a 2/3 drop on my s 10, anyone help???
Old 11-10-2007, 10:05 PM   #417
brunosrk is on a distinguished road
I have a 2003 4wd Blazer LS. A guy at my local Les Schwab is telling me that an American Racing Torqlite 15x7 with 4 inch back space and zero offset should work fine with 30/9.5/R15 tires on my rig. I'm scratching my head on this one. Somehow, I just don't think the wheels will work. What do you think?
Old 11-11-2007, 01:52 PM   #418
Gow Low or Go Home
alan - yes
brun - yes
Old 11-11-2007, 03:51 PM   #419
Quote: Originally Posted by 99SonomaHeavenS
alan - yes
brun - yes
yes what? will or won't work
Old 11-11-2007, 04:36 PM   #420
Gow Low or Go Home
will
Old 11-17-2007, 12:26 PM   #421
TwizTid's Avatar
TwizTid is on a distinguished road
Quote: Originally Posted by 98layinframe
Alot of people on here keep asking about how to measure backspaing and offset, so heres a pic i had.
The correct or should say best offset for our trucks is 0 - 4 mm offset.and the best backspace is:
4" with a 7" rim
4.5" with a 8" rim
4.75" with a 8.5" rim
feel free to add extra rim sizes and widths if you want.
EDIT! I was looking at my original post, and now realized why it is confusing some people, the offset desired will change for the width of the rim. I posted a 0-4mm offest... I should of posted this
7" --- 0 - 4mm
8" --- 4 - 10mm
8.5" --- 5 - 15mm
now these are just approximations, the wheels you chose can vary from these measurements a little and still work.
now having between a 5-15mm offset on a 8.5 inch rim, would that be fine on a 5 inch drop up front? My current rims were 20x8.5 w/ 0 offset and I had no rubbing issues. Im looking into getting 22s and do these numbers pertain to that too?
Old 11-27-2007, 02:00 AM   #422
peace out extreme kit!!
dropem10
Boss 335
20x8.5
Offset +25 mm
Backspacing 5.671
I think I have this backspacing nonsense figured out but i wanted to post to double check. I dont think these will work with my truck. i ended up with a 5/6 drop when i added on to my Xtreme suspension. Also I am wondering if the stearing is locked on the zq8's and Xtremes. My truck does not turn as tight as my friends truck who is running a 9.5" wide 20" up front. he rubs but when you put his rims on my truck they dont rub unless the truck is on an incline.
Just figured i would throw that out there.
my next option is the Boss 306's
20x8.5
14mm offset
and 5.25 backspacing.
if none of these will work its back to the drawing board for me!!!
thanks guys
Old 11-29-2007, 10:56 PM   #423
Gow Low or Go Home
i would go with the boss 306's they are the same size (i think) as the 304's, im running 18's in those, fully bagged, with a 5/16th inch spacer b/c it hits my tie rod (not a problem with 20's), and i turn great!
as far as the 22's, i wouldnt do that with a 5 inch drop in front, unless you like barely turning b/c you will be tucking tire/possibly rim..... the higher then offset the better imo for 8.5's, but i bet those 22's are either 9 or 9.5" wide and you would want a higher offset (key is to keep backspacnig bettween 4.5-6"), but dont go too much or you wont tuck the rim
Old 12-02-2007, 01:51 AM   #424
dropem10
I def. wouldnt go with 22's way too big for me. i really like the 306's but i just found out this week that they are out of production.
Old 12-16-2007, 08:34 PM   #425
importx is on a distinguished road
quick question i have a stock height 84 mint dime i have 18x7.5 with 35+ offset they are 5x4.5 bolt so i need an adapter anyway to convert to 5x43/4 i have 245x40x18 on the wheels allready. would i be better runnning a 1" or 1.25" adapter and will tires rub with either one. Also want to drop the truck would they still fit under a 3/4 drop or 4/5 drop??????? truck has a 35o crate with 7004r in it with full posi will this all still fit with which drop?????
Old 12-30-2007, 03:55 PM   #426
cardnut is on a distinguished road
I've got a major problem.. I don't know much about wheels and etc but Here is my problem.
I purchased a set of MHT Luxary rims that are 17 x 7.5 5 lug to fit a 1989 s-10. The guy I bought them from said they would fit the s-10. I put the rims on the front and they sit so far back in the wheel well that they lug stems doesn't come through. The wheel bearing doesn't go through the rim either.
Everything on the 89 s-10 is stock so I have no Idea of what to do to make these rims fit and I don't know if it is even going to look good.
The tires on the rims are 245/45/r17 wheels.............. Any help would be greatly apprecitated.......... Thanks........NUT
Old 01-02-2008, 09:40 PM   #427
Undecided
redxtruck's Avatar
redxtruck is on a distinguished road
sounds like you bought wheels for a 4wd
Old 01-02-2008, 10:41 PM   #428
Undecided
redxtruck's Avatar
so will 35-40mm offset be right with a 1.3inch wide spacer for a 19x8.5 inch wheel. I have a 04 blazer w/ shockwaves in the front and 6 inches in the rear
and what should i look for for a 9.5 inch wide wheel for the rear?
hmmm..... same i think?
Old 01-04-2008, 05:11 PM   #429
Undecided
redxtruck's Avatar
for those who are interested
Quote: Originally Posted by redxtruck
i saw that you said to just send you a pm, becaue you don't get back often
I beleive that Kyle told me that he runs 5 inches of backspacing on his blazers.
so will 40mm offset be right with a 1.3inch wide spacer for a 19x8.5 inch wheel.
Thanks Man,
Andrew
yes a 1.3" thick adaptor would be perfect for the front. for the rear your best bet is to run a wheel with right around a 5" - 5 1/4" backspacing to them.
P.S. does your big brake kit (which i love!!) push the wheels out an extra 1/4" due to the rotor thickness?
later
dave
i ended up ordering a 45mm offset for the rear wheels because , so lets see how they fit
Old 01-24-2008, 10:06 PM   #430
MarkIIISdImE's Avatar
MarkIIISdImE is on a distinguished road
ok i am buying 17 by 8 wheels
just making sure i got this right
Front = 17" x 8" with 4 - 10 mm offset 4.5" backspacing)
cool with a 5in front drop????
Old 01-25-2008, 04:39 PM   #431
KeepDreaminXtreme
Scrat's Avatar
Scrat is on a distinguished road
I'm planning on bagging my truck and was wondering if i will run into problems with this size rim....17x8 with 5 on 4.5/4.75 bolt pattern with 0mm offset and 4.5 backspace. the tire size i was planning on using is 245/45R17.
Old 01-25-2008, 06:12 PM   #432
KeepDreaminXtreme
Scrat's Avatar
ok change in tire size. how about if i ran 225/45 up front and 235/45 in the rear
