For those that dont understand backspacing and offset
LinkBack (1) Thread Tools
Old 04-26-2006, 02:35 AM   #301
Trizney's Avatar
Trizney
Re: For those that dont understand backspacing and offset
I am looking at a set of 18x8 inch , 5x120mm 35mm BMW wheels for an S-10. The S-10 is a 03' 2WD. I am pretty sure I would need a 1-1.25" spacer. Is that correct?
Also, BMW wheels are hubcentric, instead of lug centric. How would this effect the wheel on the hub of the truck?
As for tires, I am not sure what I would need. Any suggestions? The truck will also be dropped 2/3.
Thanks,
Trey
Old 04-26-2006, 10:19 PM   #302
98 Sonoma ZQ8
LS1dream's Avatar
LS1dream is on a distinguished road
Sorry to bother you, I have a quick one.
I have a 98 Sonoma, dropped 3" with coils in front and 3" with leafs in back. A member on another forum has 20x9 irocs all the ay around with 255/35-20's. he hasnt responded to my posts yet and I found some on ebay that have a +15mm offset with 5.59" backspace, 20x9. I already bought the 255/35-20 toyos and need to now for sure if these wil fit before I buy them, let me know what you think. BTW right now I have the ZQ8 wheels with 265/50-16 that do rub pretty good on sharp turns. The truck is not a zq8 and is lowered 3" from stock height.
Old 05-08-2006, 12:51 AM   #303
I have No F'ing Title
toddy's Avatar
toddy is on a distinguished road
I want to buy a set of wheels but they are for a 4x4. i cant find em for a 2wd. they are 20x8.5 and have a +35 offset. it doesnt give the backspacing. how large of a spacer will i need so i can roll on them and still tuck when i lay out?
Old 05-08-2006, 03:13 PM   #304
Draggin Moderator
98layinframe's Avatar
98layinframe will become famous soon enough
wow... havent checked this thread in a while... damn theres alot of questions. Ok here we go...
Quote: Originally Posted by 98_S-10_lwrd4now
I'm going to be running 18x8 on the front with 4.5 backspacing and a 224/40/18 tire. But for the back I want to run a 20x9.5, but I need to know the backspacing for it, and also the best tire size. I think for tire I guess 275/35/20? And what offsett also for both.
-Thanks.
For a 9.5" wide rim you should run 5 1/4" backspacing. The wheel should tuck nicely up in the wheel well with that 275 35 20 tire. One thing is those.. as long as you know your gona have to cut out the inner wheel well and inner bed sides or else the truck wont layout.
Quote: Originally Posted by SlammedXtreme913
Alright im in the market for some rims and heres what i found. I want to knonw if these will fit on my 98 s10.
Bolt Circle: 5x100mm
Offset: +45mm
Would it work?
Nope not a chance, the bolt pattern is way off and the offset is way off. The only way these would bolt up is with a 1.5" thick adapter that changes the bolt pattern from a 4.75" x 5 down to the wheels 100 x 5 pattern.
Quote: Originally Posted by sammy1983s10
Did the fourth generation camaro rims fit on the truck nicely with a half inch spacer?
I dont have fourth gen wheels on my truck. I'm running 20" boss 301's. But no a camaro wheel would not work with only a 1/2" spacer... ya need a 2" spacer for a 2wd truck.
Quote: Originally Posted by rbryant4
4" with a 7" rim. can i go with more. i found some 7" with 5.375 back space.. i dont know shit about rims, except i want some.. hahaha
also if it matters it says +35.00 mm offset
please help/
theres also an identical rim with 3.75 back spacing and -6mm offset.. but thats not enough back space.. correct!
all depends on what your doing with the truck. First off for the first set of wheels.. with the 5.375" of backspacing will not work , thats way to much. Now the second set of wheels with the 3.75" backspacing would work just fine if your only lowering the truck. If you are baggin in the future, those tires could be extremely close to the fender lip and may possibley not tuck to well.
Quote: Originally Posted by YELLOWMAN
I would like to know will these rims fit a 1985 s15 pickup 5/5 drop
18x8 5/4.7.5
6.0" Backspace
nope the backspacing is way to much for a 2wd truck. You would need to run a spacer.
Quote: Originally Posted by ThreeFourDrop
20x8.5 in a +20mm offset and a 245/35/20 nitto 555 tire.
would this offset/rim/tire fit an s10? rubbing issues?
scratch that..
its a 12mm offset 20X8.5,
yes both tire and wheel would fit just fine.
Quote: Originally Posted by Glowngo
Help!!! Iam new to the site and i need help...I have a 98 gmc envoy.4x4 I want to get some 20s or 22s .... anyone know what i need and where i can get some?
not sure where, but just look around. As for what ya need... your gona want a 20 x 8.5" wheel with right around a 50mm offset. Also the bolt pattern is 4.75 x 5 if you didnt know that allready.
Quote: Originally Posted by kdh
Thanks for the info, but one more question.. If I go with a 2/3 drop with spindles doesn't that push the wheel out a half inch? with that in mind wouldn't a 9" wide tire work with only a small amount of rubbing? meaning would a 20x9 with a 5" or 5.25" back spacing work with only a small amount of rubbing? thanks again for the help.
yeah you could get away with 5" up front.. but like ya said, there is gona be some rubbing possible during sharper turning.
Old 05-08-2006, 03:18 PM   #305
Draggin Moderator
Thanks,
Trey
yes correct you would need a 1.25" - 1.5" spacer that also adapted the bolt pattern over.
they would work, but theres a good chance the wheels will rub the control arm or the frame when turning. You could allways pick up a set of longer wheel studs, and 1/2" thick spacer to push the wheels out a little further to clear things better.
You will need a 1.5" thick spacer. Is the bolt pattern on the wheels the correct 4.75 x 5 pattern for our trucks or is it something else.... cause its no problem to change the bolt pattern with the adaptors.
Old 05-09-2006, 01:42 AM   #306
toddy's Avatar
ya its for our truck. if i can sell my wheels i am gonna buy em
Old 05-13-2006, 11:41 PM   #307
Bagged4Door94 is on a distinguished road
im not sure if this has been hit before but i have a 94 4 door blazer i have eagle alloy 077 wheels on it, they have a 5-15\16" bs but they still dont appear to be able to tuck in the rear. they are 17x8 btw anyone know any tips on getting around this. or am i just nuts
Old 05-17-2006, 10:40 PM   #308
damned 4banger
Noremac's Avatar
Noremac is an unknown quantity at this point
i was wondering, i am going to buy a set of 17x8 rims with 4.5" backspacing. will these rub on my 2001 s10 with a 3/4 drop?
Old 05-18-2006, 04:41 PM   #309
s10blazer4evr's Avatar
s10blazer4evr is on a distinguished road
Quote: Originally Posted by 98layinframe
Alot of people on here keep asking about how to measure backspaing and offset, so heres a pic i had.
The correct or should say best offset for our trucks is 0 - 4 mm offset.and the best backspace is:
4" with a 7" rim
4.5" with a 8" rim
4.75" with a 8.5" rim
feel free to add extra rim sizes and widths if you want.
EDIT! I was looking at my original post, and now realized why it is confusing some people, the offset desired will change for the width of the rim. I posted a 0-4mm offest... I should of posted this
7" --- 0 - 4mm
8" --- 4 - 10mm
8.5" --- 5 - 15mm
now these are just approximations, the wheels you chose can vary from these measurements a little and still work.
what about for a 4x4, what backspacing does it take for each wheel. like 7" etc
I have an 1988 s10 4x4 blazer and am tryin to find new wheels for it but dont know what backspacing to look for
Old 05-19-2006, 11:01 PM   #310
bestof3worlds
erockschevy's Avatar
erockschevy is on a distinguished road
4" with a 7" rim
4.5" with a 8" rim
7" --- 0 - 4mm
8" --- 4 - 10mm
8.5" --- 5 - 15mm
i am confused does this aplly to 4x4,s or 2wd
Old 05-20-2006, 05:34 AM   #311
Trybal84 is on a distinguished road
18X8 5 on 4.75 offset BSM With a 235X45X50??????
Size Lug Type +40 mm 6
Will this rub? if doesnt rub can i put a 2/3 or 3/4 drop.?
Old 05-22-2006, 12:37 AM   #312
YELLOWMAN
How thick of a spacer is needed for 18x8 5/4.7.5
6.0" Backspace for 1985 s15 pickup 5/5 drop 2wd truck.
Old 05-31-2006, 06:52 AM   #313
cRooKed eDge
nfamus10's Avatar
nfamus10
so.....22x8" rims +20mm offset should tuck fine and not need any spacers to push it out?? 3" bodydrop....
Old 05-31-2006, 09:29 AM   #314
Draggin Moderator
responed to your pm, yeah you should be ok, but if not maybe a 1/4" spacer would help things clear better.
Old 06-01-2006, 12:03 AM   #315
s-10rand is on a distinguished road
Dumb question-sorry. I have a 2001 2wd reg bed with a 2" lift and 31 and 10.50 s on the old, funky white spoke rims (painted black). Surprise! these tires rub at the frame and the fender wells. I am not sure if the white spokers are all the same, but any estimates on how much of a spacer I would need to clear the frame-I'll trim the fender wells as needed. Thanks for your time and reply.
Old 06-01-2006, 12:38 AM   #316
Forgot-15x7 wheels
Old 06-03-2006, 08:16 PM   #317
I Dropped it like its hot
TheLowLife's Avatar
TheLowLife is on a distinguished road
I just bought 31-10.5-15 Bf Goodrich All terrain for my 95 4x4 4 door blazer. Im looking to get some Iroc rims but I havent been able to find someone running these on the search. I am looking for something that sticks out a few inches. any help would be appreciated, I plan on tweaking my torsion bars and perhaps a body lift to clear the tires.
Old 06-03-2006, 11:12 PM   #318
cRooKed eDge
nfamus10's Avatar
nfamus10
thanx bro.
Old 06-05-2006, 02:38 PM   #319
Needs money and parts
flughafen's Avatar
flughafen
oh oh oh my turn! Boss 304's.....18x9" offset +14mm ....would these fit? and what's the best tire size to go with????
99 Xtreme 4.3 reg cab
Old 06-07-2006, 10:05 PM   #320
hondaguy20 is on a distinguished road
what is the backspacing on a 92 s10 4x4 factory 15x7 rim
Old 06-11-2006, 04:03 PM   #321
Blk_blazer00
blk_blazer's Avatar
blk_blazer is on a distinguished road
will an 18x7.5" wheel fit fine if it has a +20mm offset? and would a 245/40/18 tire work with them?
Old 06-25-2006, 12:22 AM   #322
Resident Hardhead
BlackStallion's Avatar
BlackStallion is on a distinguished road
ooooh ooooh me next me next lol im buying a set of wheels that apparently have zero backspacing?? the spokes are flush with the front lip theyre 16x8s and the seller says its 6" from spoke to rear lip i tried looking them up online and the only info i can find are these things apparently have a +42mm offset and are cast magnesium dunno heres the link and help would be appreciated btw im planning on gettin a 2/3 drop soon
eBay Motors: 16" MAG WHEELS AND TIRES - TECNOMAGNESIO - CHEVY S-10 (item 8076869899 end time Jun-25-06 17:31:40 PDT)
Old 07-09-2006, 03:26 PM   #323
Runitover6's Avatar
Runitover6 is on a distinguished road
Hey guys..I have a 93' s-10 blazer..4x4, 4 dr....i am goin to put a 3" trailmaster body lift on it....now for tires and wheels I want to put 31x10.5x15 for tires and a 15x8 inch wide wheel...I am just wondering what the stock backspacing is and if anyone knows if I can kick them out 3/4-1 inch without rubbing or minor trim work because these are wider than stock already..thanks
Old 07-11-2006, 09:44 PM   #324
Classifieds Nazi
2dxtreme's Avatar
2dxtreme is on a distinguished road
im looking at putting a set or rims on one of my trucks i need to know that backspacing and offset to get
im either looking at 15x7
17x7 or x8
18x8
haven't decided yet what size. i need to know what to look for
i know the bolt pattern is 5x4.75 correct?
this is all for a 88 s-10
Old 08-04-2006, 05:18 PM   #325
YELLOWMAN
on a 5/5 drop s10 pickup 1st gen with 20's what size tire do I need to run and also will 20x8.5 with 5.4 backspacing work
Old 08-20-2006, 04:16 AM   #326
peter
peter's Avatar
peter is on a distinguished road
hi gye´s, sorry for bad english. but i think you can read me. i have a´96 ext.cab 2wd with a 4 cyl/man. it runs great and cheep. i just put on cooper lifeline tires,but too bigsins they just interfear the frame. size is 235/75-15. she runs so nice on them but would spacers solv the problem?or do i need offset rims/other tires. the law are hard overhere
http://www.smileycentral.com/sig.jsp?pc=ZSzeb095&pp=ZN
Old 09-07-2006, 04:34 PM   #327
toxxin99 is on a distinguished road
All right I'm havin issues with this, I just got a set of 20X8.5s for my 2WD Blazer.
they are FWD wheels with a 32mm offset.??? I know I'm gonna have to get adapters because the wheels are 5X115mm. Are blazers the same as S-10s??
Old 09-07-2006, 04:39 PM   #328
Draggin Moderator
yes s10 blazers are the same as an s10 pickup.. they all run the 5 x 4.75" bolt pattern. You will need a adaptor that is 1.25" and as you said adapts the bolt pattern down for the wheels.
Old 09-07-2006, 04:41 PM   #329
Man thanks, that was fast.!
Old 09-08-2006, 03:43 AM   #330
