For those that dont understand backspacing and offset
LinkBack (1) Thread Tools
Old 09-05-2005, 09:26 PM   #151
Issues is on a distinguished road
Re: For those that dont understand backspacing and offset
Would i need adapters for a 22x9.5 +18 with a 5.95 bs 265/35/22 for the front and 285/30/22 in the rear, or would that work just fine without adapters?
Kevin
Old 09-06-2005, 12:32 AM   #152
nigglewiggle60's Avatar
nigglewiggle60
22x9.5 Chrome 5 on 4.75 +20 mm 6" that is what I have on the rear and the tire is 265/35/22. on the front i have 20x8.5 Chrome 5 on 4.75 +14 mm 5.238 and its perfect with the 255/35/22. I put the 22 in the front, but with the 4/5 drop all i could do is drive straight. that should give you an idea.
Old 09-06-2005, 01:03 AM   #153
Thanks i think im understanding the backspacing offset now.
Ya i am bagging my truck this winter, hopfully turning shouldn't be to bad.
Old 09-08-2005, 11:52 PM   #154
Yellow Dime 02
myYellowDime02 is on a distinguished road
will one of you experts on the offset/backspacing tell me what specs i should order on 20's on a 02' Dime with a 4-6 drop?????? I have 18"-8.5" and they rub turnin every once in a while......i have never measured their offset or backspacing......
Old 09-11-2005, 11:27 PM   #155
dont scare her, shock 'er
kyhombre's Avatar
kyhombre is on a distinguished road
hey how much BS would i need to run 20x9" rims on the front and 22x9.5" rims on the back of a 2wd 2nd gen.???? thanks
edit: ok i see that ill need 6" of BS for the 22s but still how much for the 20x9"
Old 10-04-2005, 07:28 PM   #156
partyboy3kgt is on a distinguished road
5x4.75 with offset 40
Won't work on our trucks, but what about with a wheel adapter? I can get these wheels for next to nothing, and I think im understanding offset, but I don't understand how wheel adapters can effect it.
I have a GMC Sonoma 2WD
Old 10-05-2005, 08:40 AM   #157
Draggin Moderator
98layinframe's Avatar
98layinframe will become famous soon enough
yes the 5 x 4.75" bolt pattern is correct and will work fine, but no that offset of 40mm will not work. You would simply need a 1.5" thick adaptor to mount those wheels up.
Old 10-05-2005, 06:39 PM   #158
Viperine's Avatar
Viperine
Here's my Q.....
I'm looking to put some Cragar 313's on (15x7f / 15x8r). The rear spacing on the 15x8's is listed at 3 7/8" and 4 1/2" on the 15x7's. What kind of issue is that going to cause? Mine is a 2wd and stock height for the moment.
Thanks,
Mike
Old 10-06-2005, 08:52 AM   #159
Draggin Moderator
Quote: Originally Posted by Viperine
Here's my Q.....
Thanks,
Mike
well the 4 1/2" backspacing on the front 15 x 7's is gona work perfect. Will sit in there just like a factory wheel does. The back 15 x 8's are whats gona cause the problem. The wheels are wider AND have less backspacing... so that means they are gona stick out about 1 1/2" out past where the stock wheels sit now. Not sure if they are gona look right or not, but as long as the rim atleast sits flush with the top of the fender lip it should look ok. If you were buying these wheels new.... you would want those rear 15 x 8" rims to have a backspacing on 4.5" or 4.75" also.... same as the front
Old 10-06-2005, 08:02 PM   #160
Viperine's Avatar
Viperine
Thanks for the info....That is the only option for the rear in 15x8. I guess I'll suck it up and use the 15x7's in the front instead....That should work with the tires that I'm looking to put on (235/60 fr / 255/60 r)
Thanks again,
M
Old 10-11-2005, 11:30 PM   #161
Beer, Bait and Ammo
MoneyMike's Avatar
MoneyMike is on a distinguished road
20x10 with a 275/30/20?
does back spacing effect the "lip" of the rim? if not how is it possible to get the biggest "lip" on a rim?
Old 10-12-2005, 12:24 AM   #162
xtreme5369's Avatar
Location: Back in San Antonio,Tx, but Im moving to Colorado
xtreme5369 is on a distinguished road
Old 10-12-2005, 08:30 AM   #163
Draggin Moderator
yes backspacing does effect the lip of the rim. The problem is you cant just go and pick any backspacing you want and expect the rim to fit and tuck correctly on the truck. With a 10" wide rim your looking for a backspacing around 5" - 5.5" The thing is you cant run any smaller of a backspacing if you want the wheels to fit in a stock width s10 wheelwell, mainly because the less backspacing ya have, the more the wheel is gona stick out too or past the fenders.
The only way you could run a huge lip is have a custom set of 10" wide rims made for ya with a 3.75" backspacing to them. But now to get the wheels to fit on the truck you would need to get the rearend narrowed by almost 2" on both sides. Or unless your going for the dually look and mold a set of stepside bedsides onto a fleetside bed and then run a 10" or 12" wide rim with the normal backspacing of 5.5" and the rest would stick out farther from the truck... but still be under the dually sides..
Old 10-12-2005, 08:37 AM   #164
Beer, Bait and Ammo
MoneyMike's Avatar
thanks.....
Old 10-27-2005, 11:15 PM   #165
Wide N' Low
Twisted99s10's Avatar
Twisted99s10 is on a distinguished road
ok, here is my problem. i dont want flashy chrome rims. id rather get something along the lines of a 5 spoke, light weight rim. the only problem is, i cant find any with the correct offset, or bolt pattern. im really love'n the 5zigen fn01r-c rims. the problem is, the largest bolt patern they have is a 5x114.3, which can be fixed with an adapter. but i want to space the wheels out so they fit about 1-1.5 inches farther out than where stock tires sit. the shalowest offset for those rims in an 18x7.5 is 35, and 30 for 18x8.5. if i got a 2 inch spacer would it put the wheels areound the location i am looking for?
Old 10-28-2005, 08:27 AM   #166
Draggin Moderator
yes it would, you could run a 2" - 2.5" thick adaptor. If you were to run the 35mm offset wheels at the stock location you would need a 1.25 - 1.5" adaptor. Now since you want the wheels to stick out farther, then obviously ya just need to add another 1" to that thickness to achieve your desired depth.
Old 10-28-2005, 10:10 AM   #167
Wide N' Low
ok, thanks alot.
Old 10-28-2005, 03:52 PM   #168
Not Banned
enominus's Avatar
enominus is on a distinguished road
ok, i have a 02 xtreme with 2/3 drop, let me get this straight..if i went with a 20x8.5 245/35/20 and an offset of 34 i would just need to use a 1" spacer right??
Old 10-28-2005, 03:56 PM   #169
Draggin Moderator
yeah 1" would work just fine. 1 1/4" would be better though.
Old 10-28-2005, 06:53 PM   #170
un banned
Baggd's Avatar
Baggd is on a distinguished road
so do you work for a wheel shop or what?
Old 10-28-2005, 07:13 PM   #171
f_tony_'s Avatar
f_tony_ is on a distinguished road
would 20x9 with a 15mm offset fit on my bagged 03 s-10 .
Old 10-29-2005, 02:03 AM   #172
Not Banned
enominus's Avatar
thanks for the info man, also would i be able to not run the spacer for a bit? is the spacer just there so i can have a better turning radius and it just pushes the wheel closer to the fender?
Old 10-29-2005, 05:14 PM   #173
YELLOWMAN
what backspacing would you use on a 15x 10 and 16x10 wheel for a 2wd 1985 s10 that lowerd 5/5
Old 10-31-2005, 09:06 AM   #174
Draggin Moderator
nope... not at all, just understand it and enjoy helping others getting there wheels to fit on the truck. I hate seeing people buy wheels they cant use.
yes it would, but the wheel is gona rub on the control arms for sure when you turn. You could either get longer wheel studs and run a 1/2" spacer to push the wheels out some, or ya could allways get a set of tubular control arms, they would help increase the clearense issues with rubbing.
No i highly doubt your gona be able to run those wheels without a spacer. Thats over 1" that the wheels would sit in to far.... maybe clear going perfectly strait, but when you turn thats where the problems are gone happen. Probably rubb the tie rod end links, possibley hit the brake calipers, and also the wheel could hit the control arm or shock.
5" - 5 1/4" I hope your gona run a really low profile tire, its gona be hard to tuck those in the front fenders and still be able to turn at that low of a drop. It will be really close, make sure to choose a tire that is under 25" in height.
Old 11-01-2005, 08:11 PM   #175
SK= Midwest's Elite
SLAMnoma95's Avatar
SLAMnoma95
heres a silly question...is 5x120 and 5x4.75 close enough to work? ....i know that 5x120 = like 4.7249 " ....i just didnt know if maybe one was the exact metric measurement, and if one was the approx. english....who knows
lemme know please fellahs
Old 11-02-2005, 08:21 AM   #176
Draggin Moderator
5 x 120mm is metric bmw bolt pattern. The pattern is .65mm off from our trucks bolt pattern, so to be correct.. it is not the correct size.... but since its sooooo close, alot of guys have run wheels with this pattern and not had any troubles at all. The metric equivilant to our 5 x 4.75" equals out to be 5 x 120.65mm. So its prettty damn close.
Old 11-08-2005, 07:20 AM   #177
ITS NOT EASY BEING EASY
MODERATOR
Dragginbody's Avatar
Dragginbody is on a distinguished road
damn man you do know your shit.
so 5.5 of backspacing is needed for a 10'' wide wheel to tuck... what offset is that?
Old 11-08-2005, 08:12 AM   #178
Draggin Moderator
thats actually only about a 0 - 5mm offset. 5.5" of backspacing is about the most you can safely run on an s10 or blazer without chances of rubbing the back side of the rim on the frame during hard cornering.
Old 11-08-2005, 06:06 PM   #179
Anybody got 20's?
Bdydrp02s10's Avatar
Bdydrp02s10 is on a distinguished road
Hey man, making sure this is the right wheel size and stuff. Anyhow I'm planning on getting the Intros Pentia in 20 x8.5. I think I need to get them with a 5 x 4.75 bolt pattern, and 4.75" of back spacing. I'm also looking for a good place to order these from. Plan on ordering sometime this week. Also I'm trying to find the biggest tire I can fit under the hood without major problems with a 3" bodydropped truck. I was thinking 245/35/20 but am not sure.
Thanks in advance for you're help.
David
