For those that dont understand backspacing and offset
LinkBack (1) Thread Tools
Old 11-30-2004, 12:39 PM   #51
Tucker is mah name
-Tucker-'s Avatar
-Tucker- is on a distinguished road
Re: For those that dont understand backspacing and offset
I know after reading this I should be an expert, and after it all, I feel pretty good about making my next wheel purchase, but I wanted to have someone clear it up for me and help me feel absolute sure that I can fit them. I am looking at a set of Boss 304's, chrome 18x9's (since I can't find 18x8's that fit our bolt pattern). They have a Backspace of 5 1/2 and an offset of +14mm. I am lowered 2 in the front using Beltech Spindles and 3 in the back using blocks. Will I have any issues at all? Thanks.
Old 11-30-2004, 01:45 PM   #52
Draggin Moderator
98layinframe's Avatar
98layinframe will become famous soon enough
you should be fine, where are few guys on here that are running that wheel on the front of there trucks and dont have a problem. Now yes you most likley are going the have some minor tire rubbing issues on the inner fenders, and possibley the frame when you turn the wheel lock to lock... but thats to be expected with a wheel and tire combo that wide.
Old 12-01-2004, 07:01 AM   #53
91S10's Avatar
91S10 is on a distinguished road
I know the site says 4 inch of bs on a 7 inch wide rim. Will 4 1/2 work on the front?
Old 12-01-2004, 09:00 AM   #54
Tucker is mah name
-Tucker-'s Avatar
thanks 98layinframe. I even had minor rubbing with my old 17" Eagle 203's with 255/40R17's on them. As of now, I figure anything is better than the stocker 15's i have on now with 235/70R15 on them... every dip in the road causes my tires to hit the top of the fenderwell because of the drop I got now...
Another thing is, the rubbing I have is against the anti-sway bar and the inner fender wall.
Old 12-08-2004, 03:05 AM   #55
350 powered longbed
82s10durango
will 20x8.5 with a +10 or +15 offset fit on a 91 2wd
Old 12-08-2004, 09:47 AM   #56
Draggin Moderator
yeah sure it will.
Old 12-08-2004, 09:50 AM   #57
Draggin Moderator
yes they will. My wheels are 20 x 8.5 with a +15mm offset on them, they fit fine, but i ended up running a spacer on them to keep them a little farther away from the brake booster when im laid out. So i would suggest the +10mm ones for you, that way you dont need the spacer.
Old 12-09-2004, 02:20 AM   #58
350 powered longbed
82s10durango
right on thanks alot for the help 98
Old 12-09-2004, 09:15 PM   #59
A little at a time
acftgrunt's Avatar
acftgrunt
Im trying to understand all this. Can some one tell me what is a good back spacing for a 18" wheel witha 2"/ 3" Drop?
Old 12-10-2004, 01:58 PM   #60
Draggin Moderator
all depends on the width of the wheel itself. Normally a 10mm offset fits our trucks pretty nice depending on rim width again.
Old 01-02-2005, 01:14 AM   #61
notahondanemore
sprocketxtreme's Avatar
sprocketxtreme
okay, i think i have got this down pretty good, but i want to check this one last time before i get my rims. i have a 99 xtreme, with static 2/3 drop. im looking at 20x8.5rims (5 x 120.65)with an offset of +14mm. now from what i gather here, i should be cool, correct? i just wanted to make sure one last time before i throw down all this cash.
Old 01-02-2005, 01:46 AM   #62
I hate you
acrofobia's Avatar
acrofobia is on a distinguished road
You should be fine, if you have any rubbing issues you should look into getting a 1/2" spacer.
Old 01-06-2005, 05:14 AM   #63
RIP Sean Taylor
2Xtreme's Avatar
2Xtreme will become famous soon enough
I've been trying to read up on thilink a lil, but I need to ask if im getting 18x8.5 rims with 0mm offset and 4.75 backspace fit my 03 xtreme good.
thanks
Old 01-06-2005, 11:58 AM   #64
Draggin Moderator
yes
Old 01-07-2005, 07:48 AM   #65
CHANGE YOUR EMAIL ADDRESS
awdgsx92's Avatar
awdgsx92
20x8.5 with +14mm will fit correct??
Old 01-07-2005, 09:26 AM   #66
Draggin Moderator
yes they will
0 offest has 4.75" backspace
+14mm offset has about 5 1/4" backspacing
both will work fine, just the +14mm wheels may rub a little at full lock on the sway bar or the frame.
Old 01-07-2005, 05:03 PM   #67
I'm a huge ass
4.3Xtreme's Avatar
4.3Xtreme is on a distinguished road
alright i have an 01 x cab xtreme im planning on a 2/3 drop on top of the Xtreme drop and i want to get the boss 304 18x9's i would like to try to keep the rim tire combo about the same as stock so i dont have to reset my spedo but i would like as little rub as possible so what size tire would you recommend?
Old 01-07-2005, 10:32 PM   #68
Read with your eyes -->
dime_blazer's Avatar
dime_blazer is on a distinguished road
trying to figure out if this will clear inside fender.
20 x 9
10mm offset
5.39" Bs
I calculate ~4.6" from hub to outer lip
how much clearance is needed
245/35/20
Old 01-08-2005, 10:56 AM   #69
Draggin Moderator
well actually since your dropped so low you would be better going with someting close to a 265 35 18, or a 245 40 18 See you can go wiider with the 35 series tires and get the same height. You are going to want to stay around a 25" tall tire so you dont rub so bad.
20 x 9
10mm offset
5.39" Bs
245/35/20
you are gona want to go with a 255 35 20, since you wheels are so wide. That backspacing about the normal for that wide of a rim, and it will fit on the trucks, but.... You ARE going to have rubbing, no way around it. The tire will rub the sway bar or frame, and possibley the inner fenders when the wheels are turned hard.
Old 01-08-2005, 08:37 PM   #70
I'm a huge ass
4.3Xtreme's Avatar
thanks man but if i decide against the 2/3 drop on top of the zq8 what size tires on the boss 304 18x9 would keep me at the same height as stock?
thx
x faktr
Old 01-10-2005, 03:03 PM   #71
I'm a huge ass
4.3Xtreme's Avatar
bump
Old 01-10-2005, 04:19 PM   #72
Draggin Moderator
no need to bump a sticky thread, it doesnt move.
but anyway, a 255 40 18 is pretty close to a stock Xtreme tire.
Old 01-11-2005, 09:13 PM   #73
I'm a huge ass
4.3Xtreme's Avatar
thx man haha my bad forgot about it being sticky
Old 01-24-2005, 10:20 PM   #74
my97sdime's Avatar
my97sdime is on a distinguished road
ok a buddy of mine has some rims from his beemer for sale. this is all he told me, they are 18" x 8.5" and a 38 offset and the bolt pattern is 5 on 120. will these fit and tuck on my bagged 97 2wd?
thanks in advance!!!
tom
Old 01-31-2005, 09:30 AM   #75
Draggin Moderator
those bmw wheels will fit, but your still going to need to run a 1" spacer/adaptor inorder to achieve the correct backspacing. S10s need a offset of around 0 - +15mm of offset, so those wheels would stick into the wheel wells pretty far with out and adaptor. SO yes they would tuck very easily, but you couldnt turn very well cause they would fit the sway bar or the the frame when you tried to turn hard at all.
Old 01-31-2005, 01:06 PM   #76
Subsonic Kustomz!
adamaarsvold's Avatar
adamaarsvold is on a distinguished road
Quote: Originally Posted by 98layinframe
EDIT! I was looking at my original post, and now realized why it is confusing some people, the offset desired will change for the width of the rim. I posted a 0-4mm offest... I should of posted this
7" --- 0 - 4mm
8" --- 4 - 10mm
8.5" --- 5 - 15mm
now these are just approximations, the wheels you chose can vary from these measurements a little and still work.
so we need a positive offset? the first pic showed negative and i got that in my head...but then we had a pic with positive posted.
Old 01-31-2005, 01:14 PM   #77
Subsonic Kustomz!
i found this...
http://www.rsracing.com/tech-wheel.html#wheeltrm
all the info you could want about a wheel. but it says that an 8" wide wheel with 5.4 BS should have 0 offset...the guy on page 1 said it should have 4-10...
Old 02-01-2005, 03:39 PM   #78
Getting Layed
RKs95BlackSS's Avatar
RKs95BlackSS is on a distinguished road
so i went to order my rims today and said i want 17x8 212's with a 4.5 backspacing. i did so and when he was on the fone with the people he gets the wheels from he said 4.5 offset instead of saying backspacing. ....? at eagle wheels they say their 17x8 with 4.5 bs has a +2mm offset. so if he just said 4.5in offset i'm assuming it should be fine. idk.
Old 02-19-2005, 04:15 AM   #79
Rollin` Proud on 15's
Eight433's Avatar
Eight433 is on a distinguished road
Ok, this sticky has me REALLY confused.... let me see if we can clarify this... Is it the smaller the backspacing, the more "dish" you will have on the outside of the rim, or do i have it backwards... ???
Old 02-19-2005, 10:03 AM   #80
S - I - C
DROPTSBLAZE's Avatar
DROPTSBLAZE is on a distinguished road
Quote: Originally Posted by Eight433
Ok, this sticky has me REALLY confused.... let me see if we can clarify this... Is it the smaller the backspacing, the more "dish" you will have on the outside of the rim...???
yes
Old 02-23-2005, 12:35 PM   #81
Draggin Moderator
Quote: Originally Posted by adamaarsvold
i found this...
thats impossible sorry...
when you measure offset your measuring from the center of the wheel out. So a wheel with a backspacing of 5.4" would be somewhere more around an offset of 18 - 21mm. Dont feel like doing the math right now..
Old 02-23-2005, 12:38 PM   #82
Draggin Moderator
