For those that dont understand backspacing and offset
LinkBack (1) Thread Tools
Old 03-11-2008, 06:30 PM   #451
On Your Sh*t List!
s_dimenickel's Avatar
s_dimenickel is on a distinguished road
Re: For those that dont understand backspacing and offset
ok im still confused by all this shit
i have a set of wheels that are 18x7
backspacing im told is +42mm which figures out to be 1.65 inches
bolt pattern is 5x110
im having an adapter made, what size adapter will i need to still keep the wheels behind the fenders.
Old 03-22-2008, 09:35 PM   #452
FloridaTruckScene.com
96 Dime's Avatar
96 Dime is on a distinguished road
Would a 20x8.5 with +25mm offset work on an s10/blazer?
Old 03-22-2008, 10:17 PM   #453
Registered Minitrucker
hac327's Avatar
hac327 is on a distinguished road
ok well i am just like anyone else who has posted asking if this fits and here it goes...
i got a set of ADR 18"s front are 8.5" wide with 15 offset,...the rears are 9.5 wide with the same 15 offset....
i did a dry fit and cam up with some interesting measurments,
the fronts will rub a little cause i had the truck in the air and did a full left to right test, i am sure i will rub a little on the sway bar and upper a arm if i turn the wheel just about to its max.....
the rear dry fit leaves the rim about 3/4" away from the leafspring. and i am going to have to relocate the ebrake line a little, depending on what information i can gather from a couple of posts.
should i space them out 5/16? or more? now i dont want them to stick out past the fender wells though either i need to find a happy medium i guess....
thoughts?
Old 03-28-2008, 12:25 AM   #454
hac327's Avatar
so with my rear being 9.5 wide i have 6.5" backspacing?
and my fronts being 8.5 wide i have 6" backapacing?
Old 03-28-2008, 01:33 AM   #455
hac327's Avatar
edit to my last post,...
rears are indefinetly 18/9.5 with 6" backspacing
fronts are 18/8.5 with 5 1/4" back spacing
and i am looking for the tires that will not stick out past the over all width of the rim past 1/2" please
Old 04-03-2008, 12:19 PM   #456
dekeyser is on a distinguished road
Looking at putting 17x8's on with a +15 offset. Will these work?
Thanks for any help.
Old 04-05-2008, 10:04 PM   #457
cameront150 is on a distinguished road
I have a 2001 s10..... and i want to get the iroc replica's in "20's for it this summer and i was wondering what would be a good offset to get....i found rims on a website and the offset is 0. I dont want the rims to stick out past the fender...but i dont want them tucked in either.... any help is appreciated....thanks
Old 04-07-2008, 09:46 PM   #458
ugacowboy55's Avatar
ugacowboy55 is on a distinguished road
i have a stock 2001 s10 i am replacing my wheels with 15x7 with a 4.5 bs i know the bolt patterns are correct and everything so i know that checks out. i plan on having 225/75/r15 toyo open countrys on the new wheels. will all of this have proper clearance and minimal rto no rub?
Old 04-16-2008, 11:49 AM   #459
Turbocharged Pimp
jimhrabe's Avatar
jimhrabe is on a distinguished road
I'm planning to run 20x8.5 rims in the rear will a 0 offset rim fit and completely tuck into the bed?I'm planning on ordering my new rims and this is the only thing holding me up
Old 04-20-2008, 12:29 AM   #460
boricua4_life's Avatar
boricua4_life is on a distinguished road
how about this?
VELOCITYNumber of Bolts:10Material:-- Width:8.5JBolt Pattern:5X114.3/5X4.75Structure:One Piece Diameter:24 inchesOffset:30
Old 05-06-2008, 10:22 AM   #461
yz85608's Avatar
yz85608 is on a distinguished road
Ok im lookin to gettin some z06 wheels, will 19x10 fit in the back or will i need spacers?
Old 06-08-2008, 03:57 PM   #462
TwizTid's Avatar
TwizTid is on a distinguished road
im a little confused on this backspace/offset. Im looking to get some 18 inch wheels with these specs:
18x8.5" with a 5x4.75 bolt pattern +18mm offset and 5.5" backspacing
I have a 5/6 drop on my truck and id be using 245/40/18 tires. Would this setup be ok? Any help would be appreciated . thanks
Old 06-09-2008, 01:57 PM   #463
slammed3drsdime's Avatar
slammed3drsdime is on a distinguished road
i am gonna order the kmc novas 20x8.5 0mm offset 4.75 backspacing what problems will i have and will they work fine i have no inners and im bout to tub the front
Old 07-23-2008, 08:51 PM   #464
kickflipking_04's Avatar
kickflipking_04 is on a distinguished road
So when the chart on the first page says:
7" --- 0 - 4mm
8" --- 4 - 10mm
8.5" --- 5 - 15mm
Does that mean for example on the rims that are 8inchs wide +4 throw +10 ??
Old 08-10-2008, 01:37 PM   #465
KILLBOY POWERHEAD's Avatar
KILLBOY POWERHEAD
http://www.americanracing.com/appgui...sp?section=app
will these work , says they fit my truck , and im keeping a larger tire , 245/50/17
im hiding tire now and these are the same height
thanks jim
Old 08-16-2008, 12:01 AM   #466
2 Tone
RuLayd's Avatar
RuLayd is on a distinguished road
whats the deal with fwd offset?
The specs are 22" rims-
Fitment: 5lug FWD offset (5x120/5x114.3+35m)
would these work for my first gen? Turning problems? Will they stick out, do i need spacers?
DISCLAIMER: (3.5" lip on 22x7.5/22X8 and 6"+ lip on 22x9.5 and 24x10)
Thank you!
Old 08-21-2008, 12:39 PM   #467
yz85608's Avatar
So a 19X12with a offset of 59mm would have a bs of 8.11"
which would require a 2.61" spacer?
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f14/for-those-that-dont-understand-backspacing-and-offset-107156/
Posted By For Type Date
took the blazer dragging over the weekend - ERMCA.com This thread Refback 06-17-2007 03:45 PM
Page generated in 0.14271 seconds with 12 queries
