#101 |
Re: Corvette Rims Thread
What size spacer for a 4x4 with the C6, 19x10 on the back?
#102 |
falcon powered.
4x4s dont need spacer i think
#103 |
is gettin there...
i dont believe they do either, and at the most a 1" just to make them stick out if you want
#104 |
Need LSx swap.....
#105 |
Need LSx swap.....
#106 |
I guess I'll post my question here as well. 93 Sonoma 2wd.I just picked up a set of stock 1984 corvette wheels 16inch 8.5 inches wide I think the offset is 32mm . Here's a link: http://www.finishlinewheels.com/prodimg/ALY01347L.jpg
The car is getting a 3/4 drop with spindles and 1 inch drop springs leafs and blocks in the back. What do I need to make these fit on my truck? |
#107 |
falcon powered.
im painting mine today i will post up a finished picture once my garage warms up
#108 |
Help Please! Last edited by FF7 : 12-02-2008 at 04:12 PM. |
#109 |
where do you purchase the sparcers?
#110 |
Slap my meat on your pita
Ebay, I got mine from ezaccessory. Im pretty sure that was his name.
#111 |
falcon powered.
#112 |
Starting from scratch...
#113 |
holla@me
Ok so on my 95 Sonoma. I found a set of those chrome C5's with the staggered 17's and 18's.
I don't know how the truck was lowered and its a 2wd. Im assuming spindles in the front, its really low. I will need at least a 2.25 spacer? Im going to check ebay now but am I sounding correct? |
#114 |
At least a 2.25 yes. What are the widths?
#115 |
holla@me
#116 |
Need LSx swap.....
you are going to need spacers with any C5/6 wheel on a 2wd. |
#117 |
Got s10?
I have... 17x9.5 all around. 275/40/17 rubber 2.75 spacers in the front (rolled fender. No rubbing.) 2.50 spacers in the rear. Pics. ![]() ![]() ![]() Whoring... No spacers required on this one ![]() ![]() ![]() |
#118 |
slow and low
I got a little excited to put the wheels on so i did it early. 2" in the front and 1-3/4" in the rear and no issues. 17x9.5 all the way around with 275/40 tires. I'll get more pics up when i get the truck all put back together.
#119 |
got cones?
2" spacers let a 17x9 with 265/40's clear the tie-rods on the front of mine but it didn't look like I'd be able to turn the wheel much. I hit the frame with a 2" spacer and 16x8's, 245/50's.
A 2" in the rear isn't enough with an 18x10.5, 295/35 either. They look like they clear when the truck is just sitting there but a member on S10planet tried it and was scuffing the sidewall on the inside with normal driving. I would think a 1.75" with 275's would be the same. Have you tried driving with it yet? The LSx is probably going to move things around alot more in the rear than a 4.3 so I'd make sure you have lots of clearance. Nice truck BTW! |
#120 |
falcon powered.
#121 |
Cleanest truck in school
I think Sonomanator is just posting any pics he has of his rims...
#122 |
falcon powered.
no i posted one in primer one almost done and then the final one.
#123 |
#124 |
#125 |
Ran C5 "Wagon Wheels" on my 01 Blazer Extreme. These are 17x8.5 front and 18x9.5 on the Vette. 2.5" Spacers all around. 255/40 in front, 275/40 in rear. I 2/2 drop on it. I absolutely despised how small the front rims looked.
Original: ![]() ![]() I had the idea to run the larger 18 x 9.5 all around. 275/40 Sumitomos all around. Looked ALOT better. But still not my bag. Later ![]() ![]() ![]() ![]() ![]() Went with these SSR Competition Forged 2 piece 19 x 10s all around with a 1.25 spacer. 285/35 rear 255/40 front. ![]() ![]() ![]() ![]() ![]() SOOO much better. They really fill out the wheel well right. In the end, Vette wheels are cheap, but spacers arent. And even then they just dont really fit the wheel wells that great. I never had any issues with tie rod contact though. |
#126 |
holla@me
Ugh, I want one of those blazers you have. : (
#127 |
Where are you guys find the spacers in such odd sizes? I've found 2" and 2.5" and 3". I see some of you are running 2.75, 2.25 and others.
#128 |
Need LSx swap.....
#129 |
Look for ezaccessory, I think, is his name on Ebay. Thats where I got mine. |
#130 |
94 S10 355 Tremec
some renderings of both sets of wheels I have
the C5's will be powder coated Black Chrome. ![]() ![]() and My Project.. I love the Vette wheels. ![]() ![]() |
#131 |
#132 |
Thank! I don't have many pics with the wheels and grille done. As soon as there's not a bunch of snow I'll take a few.
#133 |
For sure man that thing is nice. I just screwed my c5 rims and want Z06 motorsport rims now. I think I want staggered though, what drop do you have again?
#134 |
My truck was a 4X4 so it's lowered a lot. It's over a foot lower than it was.
#135 |
#136 |
Damn get some picks up man!
#137 |
This is a great thread! Looking at purchasing from Lakeshore Wheel and Tire in Holland, MI. Does anyone have any experience dealing with them?
#138 |
Former S10 enthusiast
Anyone know if an 8.5" wide wheel will be able to turn without rubbing with a 5/6? Or does anyone know a company that makes a less wide C6 wheel?
#139 |
#140 |
slow and low
Here is a few more:
#141 |
Wow those look great on there with the truck all painted.
#142 |
Need LSx swap.....
#143 |
in the works
so vince921 those z06 wheels fit nice. could i fit those on a stock suspension truck? cause i would love to be able to just get them and not have to worry about spacing issues. im lookin at these
#144 |
They will fit fine under stock suspension assuming you have an s10. 4wd don't require spacer but 2wd will require them. I think 2.25-2.5 are the most commonly used spacer for vette rims.
#145 |
Road Racing Blazer
The main reason I got my vette wheels is cuz you don't have to spend $200 on spacers when you're 4X4, I just got the 1" in the back and it evens it out pretty much perfectly, although I think like a 1/8" to 1/4" shorter spacer would allow for better rear clearance when you run 295s. 4WD 2nd Gen blazers even stock have a wicked stagger, not sure, maybe for turning circle or something, but even stock I think the wheels could use a 3/4" spacer in the rear. You need to stuff some bigger brakes under there, the 19s make the stockers look like drums |
#146 |
they should yes im running Inch and 3/4 spacers in the front and 2s in the rear... and 4x4 dont need spacers in the rear seeing how the rear end is 4 inches wider i believe... but i do think you still need em in the front |
#147 |
in the works
ya its a stock 97 s10
#148 |
Need LSx swap.....
#149 |
Molon Labe
They chose the rear wheels to be the narrower of the two for handling and turning radius reduction purposes. |
#150 |
