Corvette Rims Thread
Old 09-23-2008, 08:59 PM   #51
Half-Bagged for now
leroyme's Avatar
Re: Corvette Rims Thread
Those are definitely aftermarket rims, so they could be made for a freakin Honda with no problems! They look good on your truck, though! They're not true Vette rims, though.
Old 09-23-2008, 08:59 PM   #52
Half-Bagged for now
leroyme's Avatar
Quote: Originally Posted by philntx
Are these C5 Z06 motorsport replicas?
Jais. Dat's true.
Old 09-24-2008, 12:19 AM   #53
HILROD's Avatar
They are C5 Z06 Offsets. They are Factory Reproductions. I tried 17 on the front, but they hit the tie rods. The 18 clear by a lot.
Old 09-24-2008, 08:19 AM   #54
manual>automatic
Driveway Kustoms's Avatar
they look good man
Old 09-24-2008, 11:53 PM   #55
\x/
LowNoma01's Avatar
What kind of spacers would you need for 18x9.5 front and back. I have a 3-5 drop now,how much lower could I go also? Thanx
Old 10-21-2008, 02:57 PM   #56
c6 zo6 18x8.5 front, 19x10 rear. 2.25 spacers front, zr2 8.5 rearend no spacers needed. 3.5/5 drop, bad pick sits lower in front and higher in back now.
Old 10-21-2008, 05:29 PM   #57
Slap my meat on your pita
GeorgesBlazah's Avatar
Ill have mine on this weekend. woo
Old 10-22-2008, 03:43 AM   #58
Call me Mario, Princess
AceHaag's Avatar
ZR1 replicas 17x 9.5 front 17x 11 rear no spacers on a 4x4
Old 10-25-2008, 08:20 PM   #59
Small teaser for now.
Old 10-26-2008, 09:28 AM   #60
manual>automatic
omg thats gonna look sick
Old 10-26-2008, 03:40 PM   #61
Old 10-26-2008, 03:40 PM   #62
Forgot to add.
18x8.5 all around
2.25 adapters
255/40 front
275/35 rear
Old 10-26-2008, 04:58 PM   #63
manual>automatic
sick
Old 10-26-2008, 09:50 PM   #64
Insert witty title here.
bwhitfield24's Avatar
Need bigger brakes..... Other than that it looks great George!
Old 11-07-2008, 08:34 PM   #65
Daily Driver
sparky2613's Avatar
bump
Old 11-11-2008, 09:27 PM   #66
I turn.
rentedmule's Avatar
'03 ZO6 wheels with stock vette rubber - 265/40-17 front, 295/35-18 rear.
Test fitting with some 2" spacers I already had (Z85 leafs, 3" blocks)
They clear but it's tight, I'll probably go with a 2.5" spacer
Front clears tie-rods fine (stock spindles, ZQ8 coils) but they'll probably rub the frame on tight turns. 245/50's on 16" trans am wheels rubbed a bit with the same spacer. Snow is down so I haven't test driven them yet.
Old 11-11-2008, 09:34 PM   #67
Jesus Palamino
The Griff's Avatar
C5 17/18 combo 1.5" spacers
Old 11-12-2008, 02:58 AM   #68
tikals10's Avatar
my tierods clear with drop spindles and 2.25" adapters
Old 11-12-2008, 03:06 AM   #69
tikals10's Avatar
this was 4" static drop (spindles & coils)with the 2.25" adapters tierods cleared
Old 11-18-2008, 12:55 AM   #70
ARE YOU F*CKING HIGH?
CouJoe56's Avatar
ok so my 97 can be dropped more than 3 inches in the front with 97 real C5's? I'm gonna run 2.5" spacers all around, 17x8.5 i do believe. 245/45/17 tire. with 2 inch spindles and my 3 inch ground force they should clear riiiiiight?
Old 11-18-2008, 01:05 AM   #71
fuck potholes.
colbye32's Avatar
mines now bagged on c5 wheels, 18x10 out back with 2.5" spacer, and 245/40/18 tires, front is a 17x9, or 17x9.5 cant remember, its got 2.5" spacer too, i also have drop spindles, and tubular control arms, and lay flat out and no scrubs or rubs on anything. front tires are 235/40/17 now. these pics show some 225/45's squeezed on the front..
Old 11-18-2008, 01:36 AM   #72
tikals10's Avatar
tierods should clear tire might be to tall
this was a 4/5 drop w/ 245/45/17 rubber up front 285/35/18 rear
Old 11-18-2008, 02:25 PM   #73
CouJoe56's Avatar
is there any spindles that have a more "tucked in" tie rod hole? and heres what im workin with. were gonna try to go 5 inches in the front. with 245/45/17's right now now ground force 3 inch coils are not lookin like 3 inch coild ill have to investigate this weekend.
Old 11-18-2008, 02:31 PM   #74
CouJoe56's Avatar
c=
do you squeak any? mine was cut from the factory when i put in my coils.
Old 11-18-2008, 02:34 PM   #75
Mine dont touch and im running a 2.25 adapter.
Old 11-18-2008, 06:46 PM   #76
WWW.CAROLINATRUCKSCENE.
FarEastDime's Avatar
so ill try here also. i have an 88 s10 im gonna be doing a 3/3 drop here soon, prolly after xmas (and i plan on going lower). i just picked up C4 wheels (sawblades) that are 17X9.5, 275/40/17 & 315/45/17 the tires that are on them will be fine for now. will be getting new ones come summer. what size spacers will i need. i was reading through everyone, and im thinking 2.5F 2.75R. suggestions.
Old 11-19-2008, 09:56 AM   #77
CouJoe56's Avatar
according to what everyone on here is saying, if the sawblades have the same backspacing as the c5's, im not sure if they do tho, that 2.25 will work but will sit under the fender so 2.5 is more of a preferred choice, at least thats what im understanding from this whooole looong post
Old 11-19-2008, 10:22 AM   #78
well i did a mock up with the rear. and if i keep the same sized tire for the rear i think i would need a 2.5. i could do the 2.25 but i think it would be close. but ive also determined i will be getting new tires all the way around, come sum,mer and i dont think im gonna put them on till then....
Old 11-19-2008, 11:09 AM   #79
C130 Maintenance in Japan
nate98blazer's Avatar
here is my 98 blazer 4dr 2wd, i have 2.5" spacers all around front are 245/45/17, rear are 275/40/18, 3/3 drop right now, plan on going lower, possibly 4/5, i guess i might have to get a smaller spacer for at least the fronts.
the front side of the back wheels
the back side of the back wheel
Old 11-19-2008, 01:52 PM   #80
OK, more dumb questions. I pulled the rims off my Vette when I sold it. Would like to throw them on my Sonoma. All 4 are 18x9 with 6.5" BS. I'm lowered 4/5 on spindles and springs. So many differing opinions on spacer size. Any thoughts?
Old 11-19-2008, 03:21 PM   #81
Need LSx swap.....
Kampz69's Avatar
Quote: Originally Posted by GeorgesBlazah
very sweet man, looks awesome
Old 11-19-2008, 10:28 PM   #82
SoFlaGMC's Avatar
I just got a set of true C6's (18 in front, 19 in back)for dirt cheap. I'll post pics when I get the spacers in a couple of weeks.
Old 11-20-2008, 08:25 AM   #83
the rear mock up.....
i think ill be going with 2.5 in the back with rolled fenders.
Old 11-21-2008, 05:48 PM   #84
By Vin# only I Guess
STILL4WD's Avatar
ok i have a set of z06 wheels. 17 front and 18 back. i want to run the same 18x10.5 in the front...what kind of spacer is needed...ohh its a 4x4? and what kind of spacer in the back to make them look even. thanks!
Old 11-22-2008, 09:05 AM   #85
Need LSx swap.....
Kampz69's Avatar
18x10.5 in front will be tough, but i think some have used them before. 18x9.5 +56 would be better. i think you need a 1-inch spacer to level out the rears with the fronts.
Old 11-23-2008, 12:37 PM   #86
STILL4WD's Avatar
thanks. what do guys with typhoons or syclones use?
Old 11-23-2008, 06:50 PM   #87
Need LSx swap.....
Kampz69's Avatar
same, usually 18x9.5 in the front at most. since they are AWD they would run 18x9.5 at all four corners with the same tire sizes, or at least have the same tire diameter if they were to run something staggered. there wa a guy on syty.net running a 18x9.5 in front and 18x12 in the rear....i think it was a 335/30/18 rear tire, pretty small
Old 11-23-2008, 07:47 PM   #88
When in doubt..Lay it out
Mini-89s10's Avatar
thats so damn clean... love it
Old 11-24-2008, 04:52 AM   #89
STILL4WD's Avatar
i guess i have just have to mount the 18 up front and see how much it sticks out. i rather just buy 2 more wheels then buy a whole new set of 18x9.5
Old 11-24-2008, 09:46 AM   #90
Those are fk'n hot, look very nice. Those gotta be some of the best lookin all-black's I've seen on that series dime. Very nice. (But yeah, the brakes actually do look small now, lol). Still very nice.
Old 11-24-2008, 10:06 AM   #91
Any help with this guys? I really don't trust "eyeballing" this as much as spacers cost. TIA
BTW, Those black Vette wheels are the sickest. Maybe I should just sell my Boyds and hook up on those!
Old 11-24-2008, 10:30 AM   #92
Need LSx swap.....
Kampz69's Avatar
they should be flush, but definitely post up fitment pics
Old 11-25-2008, 10:06 AM   #93
STILL4WD's Avatar
no prob
Old 11-25-2008, 11:17 AM   #94
SMOKINGACHICKEN
smokingachicken's Avatar
so i just came up on a set of true, chrome c5's for $150. 17 front and 18 back, ill post picks when i get spacers, tires, and paint them, a dark gray should look good on the indigo blue...
Old 11-28-2008, 01:40 PM   #95
STILL4WD's Avatar
well i bolted up the 10.5 in the front and here are some pics. there will be some rubbing and it does stick out a bit and i will need a spacer to get the cap on due to the axle.
Old 11-28-2008, 02:04 PM   #96
falcon powered.
sonomanator's Avatar
mine
Old 11-28-2008, 03:09 PM   #97
falcon powered.
i decided im going to get mine painted now
Old 11-28-2008, 03:11 PM   #98
manual>automatic
wow those are sickkkk
Old 11-29-2008, 12:42 AM   #99
falcon powered.
the whole truck is sick
Old 11-29-2008, 08:54 PM   #100
Need LSx swap.....
Kampz69's Avatar
yea those style C5's look way better in black IMO.
