Corvette rims on s10? - S-10 Forum
post #1 of 26 Old 07-18-2007, 02:42 AM Thread Starter
LilBlueBeast's Avatar
User is: LilBlueBeast is offline
Question Corvette rims on s10?
i was wondering if the C6 Motorsport Wheels from the corvette would fit on my s10 or not? if any 1 has any info please post on here so i can figure this out. Thsnk you very much!!!
lilbluebeast
post #2 of 26 Old 07-18-2007, 03:28 PM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
Re: Corvette rims on s10?
The bolt pattern is correct but the backspacing is not, typically people use 2 or 2.5" spacers to run vette wheels on a 2wd.
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #3 of 26 Old 07-18-2007, 03:30 PM
I Have A S-10 Addiction
One Mean S10's Avatar
User is: One Mean S10 is offline
Send a message via Yahoo to One Mean S10
here ya are...
Quote: Originally Posted by 79Cutlas And "Definate potential" means Its a POS that with enough money and blind faith could be made into a decent looking truck, however I Ferrari might be a better investment for the money you'd have to spend.
My Whips
'91 s10 ( 4.3 )
'83 s10 ( 383 )
post #4 of 26 Old 07-18-2007, 03:33 PM
dillon_b12's Avatar
User is: dillon_b12 is offline
Send a message via AIM to dillon_b12 Send a message via MSN to dillon_b12
Originally Posted by One Mean S10 View Post
here ya are...
Hey that's me! If you have a 2wd you will need spacers, if 4x4 then you won't.
1994 S-10 4x4 - Black, 4.3 TBI, Lowered 4/5, 98 S-10 Frontend, Zexel-Torsen Differential, Velm Sunroof, Flowmaster 40 Series, Sony CDX-MP70, Pioneer 4x6s, Pioneer REV Series 6.5s, Pioneer 4x10s, Adire Audio Brahma 12", Hifonics BX1000D, and Corvette C6 18x8.5s with 235/55/18 Michelins.
post #5 of 26 Old 07-18-2007, 05:39 PM
Starting from scratch...
02_Black_XBlazer's Avatar
User is: 02_Black_XBlazer is offline
I run '00 C5 rims, 2.25" spacers. No probs. One thing to keep in mind with spacers this thick is that they need to be bolted to the wheels when the tires are balanced. They should be treated as one piece, or else you'll get a nasty wobble. All the spacers weighed within +/- 2 grams, but it was still enough to have a wicked shimmy at highway speeds.
Pipefitter's Local 597, Chicago, IL
'97 S-10 SS (gone) ( pics- http://www.s10forum.com/forum/f3/a-l...ing-up-367228/ )
'02 Blazer Xtreme
post #6 of 26 Old 07-18-2007, 09:57 PM Thread Starter
sweet thank guys i greatly appreciate it!!!!
post #7 of 26 Old 07-20-2007, 12:06 PM
lets get hammered
s10sixteynine's Avatar
User is: s10sixteynine is offline
Send a message via AIM to s10sixteynine
if u only run 2.25 on the rear u will be screwed i just go it my 2.5 and when bolted up it is extremely close to the frame im and usein 2.5 front and 3 rear
Originally Posted by candyreddime View Post
icy hot on balls=hell on ice
post #8 of 26 Old 07-21-2007, 11:42 PM
How wide are your rear rims/tires? I'm running a 275/40/18 on 2.25" spacers, and I've got a good innh from the inside sidewall to the frame...
'02 Blazer Xtreme
post #9 of 26 Old 07-21-2007, 11:51 PM
Ridin' on Twankies
colbye32's Avatar
User is: colbye32 is offline
Send a message via AIM to colbye32 Send a message via Yahoo to colbye32
i got some c6 wheels on mine. the 18/19s with a 295- 35- 19 on the rear, and a 225-40-18 on the front. i run a 3 inch spacer on the rear, and a 2 1/2 on the front, with a 3/4 drop. i scrub a little when i turn super sharp, but nothing major... my tires hit the frame on the rear with a 2 1/2 spacer. so i run 3's now... no shaking or nothing... just putting my 2 cents in.
colbye32 is offline
post #10 of 26 Old 07-23-2007, 03:04 PM
lets get hammered
post #11 of 26 Old 07-23-2007, 03:06 PM
lets get hammered
u have c5 not c6 the c6 is 19x 10 on rear
post #12 of 26 Old 07-24-2007, 06:27 PM
Now i have my real truck!
rockinguitar876's Avatar
User is: rockinguitar876 is offline
Send a message via AIM to rockinguitar876
hey what is the backspacing on the corvette rims because i put a 4x4 blazer rearend up under my 2wd s10 and as ya'll probably know it sticks out about 2 in. on each side, and someone told me that corvette wheels would work because of the offset, and just put spacers up front are ya'll putting spacers in the rear too???? so whats the backspacing on them???
post #13 of 26 Old 07-24-2007, 06:48 PM
dillon_b12's Avatar
On the 18s they are 8.5" wide with +56MM offset so backspacing would be 6.45.
post #14 of 26 Old 07-24-2007, 06:52 PM
hey u sound like ur good at calculating backspacing, what would it be if the rims were 8in. wide???
post #15 of 26 Old 07-24-2007, 06:52 PM
and 7 in. also
post #16 of 26 Old 07-25-2007, 03:43 AM
dillon_b12's Avatar
How about I teach you so you can pass the knowledge on(providing that I am doing it right lol)
You start by assuming the wheel is 0MM offset. This means on an 8.5" wheel you start out with 4.25" backspacing. Then according to whether or not the offset is positive or negative you add or subtract that number accordingly.
BUT You have to convert MM to inches before doing so.
MM to IN. conversion unit=.03937
56MM x .03937=2.204"
4.25+2.204= 6.454" backspacing
post #17 of 26 Old 07-25-2007, 12:49 PM
ok i got that so how do u figure out what backspacing to start out with, with a different size wheel like a 8 in. wheel or something
post #18 of 26 Old 07-25-2007, 03:31 PM
dillon_b12's Avatar
Half of whatever the wheel width is. Hence 8.5" wheel starting a 0 offset is 4.25" backspacing. 8" wheel would be 4" and so on and so forth.
post #19 of 26 Old 07-25-2007, 03:34 PM
User is: Criticalbeatdown95s is offline
Yea i decided to go with 18'' zo6, black with a polished lip. Damn 4wd, well, was....
**** you.
post #20 of 26 Old 07-25-2007, 03:45 PM
dillon_b12's Avatar
At least you didn't get plain C6s. I like to keep some originality lol, even though our trucks look nothing alike.
post #21 of 26 Old 07-26-2007, 12:28 PM
Im Gonna Eat Yo COWNBREAD
sippiwhiteboy's Avatar
User is: sippiwhiteboy is offline
Send a message via Yahoo to sippiwhiteboy
Does anyone have any pics of the C6 wheels on a first gen?
post #22 of 26 Old 07-26-2007, 12:45 PM
ooo so thats how they do it thanks for all the info man
post #23 of 26 Old 07-28-2007, 11:39 AM
i tried some out i think im going to get soem if i can get the corvette emblem off the center cap
those are 18" x 8.5 with a 245/40/18 tire
post #24 of 26 Old 07-28-2007, 12:36 PM
lets get hammered
if it is painted on like the silver ones i have u can wet sand them off and buff the shine back but be carefull the factory clear is really thin and i went through on 2 and had to repaint them if it is chrome with like a sticker on it go to a good boddy shop they will have a tool (i forget what its called my buddy calls it an ereaser) they use it to get pin stripe and glue off of the cars it will take it off also
post #25 of 26 Old 07-28-2007, 09:25 PM
yep my dad has one at his shop
post #26 of 26 Old 07-29-2007, 12:55 AM
93-s10's Avatar
User is: 93-s10 is offline
Hey dude iam in your excat position iam dropped 3/4 and have c6 rims iam having troubles finding tires cheaper than 200$ for fronts and 300$ for rear and there not run flats or z rated or anything what are you running? and can you pm me some pics plz
93-s10 is offline
