STPSYDR
C5 Z06 Vette Brakes
I finally have my front brakes done, they work really well
STPSYDR
Re: C5 Z06 Vette Brakes
And I want to give a big thanks to Bad94 for providing the brackets, Tobin Knighton from Kore3 for the custom SS brake hoses, GeorgesBlazah for the Hawk Brake pads and Dennis Aker for the mock up parts in the early stages of the project
wow! they look great, I'm in the works of building my set up right now, i'll be doing all four wheels, where did you get your calipers from?
bellcranks no more
looks good
which spindle is that? |
STPSYDR
calipers were found on ebay, but there are lots of places that sell them, including Kore3, expect to pay around $100 each Last edited by BLACKZQ8stepside : 06-29-2008 at 03:25 PM. |
STPSYDR
Will work for turbo parts
Would he be interested in selling the brackets?
STPSYDR
[quote=BLACKZQ8stepside;5372841]I finally have my front brakes done, they work really well
![]() ![]() ![]() ![]() ![]() ![]() ![]() [/qu are they selling kits for a first gen? |
bellcranks no more
i can mill brackets easy if you give me dimensions of what you need. |
STPSYDR
[quote=dhernandez123;5373658]
sawzall's are cool
are your rotors installed backwards in the pic with out the wheel they look right but the others they look backwards
[quote=BLACKZQ8stepside;5373714]
Hi-Tech Redneck
what prop valve and MC will you be running after the rear swap?
STPSYDR
[quote=dhernandez123;5373732]
STPSYDR
bellcranks no more
STPSYDR
Canyon Carver
They look great. Do you know what coating is on the rotors? They're shiney.
STPSYDR
Wanna see some magic?
Gorgeous!
Along with the brackets for the caliper coversion, doesn't Bad94 also make the hubs that will work with drop spindles? I've tried getting ahold of him and I also tried emailing Ed Miller and I didn't get anything back ![]() Those are the 14" rotors correct? |
STPSYDR
#24 |
Aha, thank you. I've heard that it will work with 2" drop S10 spindles, and that it won't. I'll try getting in contact with him again. I'll be doing the C5 calipers with 12" discs to fit the ZQ8 wheels.
#25 |
sawzall's are cool
Which direction should the discs rotate?
It is a popular misconception that the slots or drillings in a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation. There are three vane types in use: * Straight * Pillar vane (comprised of many small posts) * Curved vane The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. Please see figure. Orienting the disc in the manner creates a centrifugal pump. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc's ability to dissipate heat. Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure. thats from the brembo site after i saw it i did some reasearch |
#26 |
#27 |
If you check out some Corvette forums guys have them for sale for like $80 a piece.
#28 |
#29 |
#30 |
bellcranks no more
im just saying i have the capabilities of making the bracket. |
#31 |
Static> Bags
Glad to see you got ur set up on.
I have done C5 set up on reg s-10 2" spindle and 98 up blazer 2" drop spindle. Im working on stock spindle C5 set up, and C6 ZO6 set ups. Also as for rotor, i have been told that the pic with out the wheel is right and the others are wrong. |
#32 |
STPSYDR
