c5 brakes - S-10 Forum
post #1 of 19 Old 06-19-2009, 10:48 PM Thread Starter
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
c5 brakes
i know, i know..... my questions are a little different tho. so many companies say that the regular truck 2wd spindle is not strong enough for the c5 conversion, so they want me to get blazer spindles to modify. who has them on truck spindles, and have you had problems? also, any tips/ advice? where did you get ur parts from, and what did you get specifically?
2004 Commemorative Edition Corvette
2014 Lexus IS350 F-Sport
post #2 of 19 Old 06-20-2009, 02:20 AM
FUCK YOU
Wicked Mayhem's Avatar
Re: c5 brakes
bad 94 is the only person that comes to mind.. theres several threads on here bout people doing the conversion. dont know how many have driven on them.. but i dont see why they wouldnt be strong enough.
Wicked Mayhem is offline
post #3 of 19 Old 06-20-2009, 09:49 AM Thread Starter
Local Tech
Re: c5 brakes
thats basically what i thought, but ive spoken to 2 companies offering a kit, but both told me they wont make one for the spindle with single piston calipers
post #4 of 19 Old 06-20-2009, 10:28 AM
brakes hate me
1BadElky's Avatar
User is: 1BadElky is offline
Re: c5 brakes
flynbye.com
Project Thread
Originally Posted by 2Lo4aFatHoe View Post
i wish someone would dip a bat in originality and hit you across the mouth with it.
1BadElky is offline
post #5 of 19 Old 06-20-2009, 10:34 AM
brakes hate me
1BadElky's Avatar
Re: c5 brakes
but i am stronglt opposed to using truck spindles and machining a hub when blazer spindles are readily available. the machined down rotor can crack (mine are craked). and truck spindles will widen the track width. you could use the billet hubs from kore3. but at that price, you might as well use blazer spindles.
bottom line: Blazer spindles are more expensive... but these are brakes we're talking about. how important is your life?
Project Thread
1BadElky is offline
post #6 of 19 Old 06-20-2009, 10:48 AM Thread Starter
Local Tech
Re: c5 brakes
ive gone to flynbye .com, but there descriptions are vague.... thats why i wanted to see who bought what from where
post #7 of 19 Old 06-20-2009, 03:49 PM
FUCK YOU
Re: c5 brakes
personally i wouldnt ever do a brake upgrade on s10 spindles.. i love sealed hubs, easier to deal with IMO
post #8 of 19 Old 06-21-2009, 02:15 AM
'01 Noma
shift220's Avatar
User is: shift220 is offline
Re: c5 brakes
Machining down 1 piece hubs/rotors is not unique to us s10 guys (the few that have). Do you have pictures of your cracked hubs 1BadElky? Were they stock rotors to begin with?
Not making a kit because the stock spindle uses a single piston caliper is a poor excuse for not doing the math. If I recall correctly, the area of the piston is actually not much less the dual piston caliper used on Blazers.
shift220 is offline
post #9 of 19 Old 06-21-2009, 02:17 AM
'01 Noma
shift220's Avatar
Re: c5 brakes
Easier sure but quite a bit more expensive and not serviceable. Seems like they don't last as long either?
shift220 is offline
post #10 of 19 Old 06-21-2009, 02:23 AM
FUCK YOU
Re: c5 brakes
dunno.. i would rather not mess with the bearings. id rather shell out the money for a new hub then pack em n shit.. im lazy.
gotta pay to play.
post #11 of 19 Old 06-21-2009, 12:39 PM
brakes hate me
1BadElky's Avatar
Re: c5 brakes
It's not unique to us I know. there are alot of camaro and Chevelle guys doing it too. But those guys don't have sealed hub spindles available to just bolt on like S-series and G-body guys do.
if you were to use the billet hubs offered by kore3.com, I don't think cracking would be an issue, but if you can afford those, you can afford to use blazer spindles(and maintian your track width, which may be important if you have bags). yes, mine were machined down rotors though. I'll upload a pic tonight.
kore3 hubs: http://www.kore3.com/proddetail.php?prod=10075
Project Thread
1BadElky is offline
post #12 of 19 Old 06-21-2009, 03:28 PM
Customz
C-DUB's Avatar
User is: C-DUB is offline
Send a message via MSN to C-DUB
Re: c5 brakes
Unless my machined rotors are different then everybody elses, I don't see how mine will ever crack.
Mine still have a lip around the edge, that is probably 1/8" - 3/16" thick and about 1.25" deep.
C-DUB is offline
post #13 of 19 Old 06-21-2009, 06:22 PM
'01 Noma
shift220's Avatar
Re: c5 brakes
Here is how I did mine. I wanted all the extra weight off the hub. I can't see these cracking either. Looks like the small amount of material as the Kore3 Hubs and those are aluminum.
shift220 is offline
post #14 of 19 Old 06-21-2009, 06:23 PM
'01 Noma
shift220's Avatar
Re: c5 brakes
shift220 is offline
post #15 of 19 Old 06-22-2009, 12:34 PM
User is: afraidof7 is offline
Send a message via AIM to afraidof7
Re: c5 brakes
I have the rotor turned down setup with modified spindles
http://www.s10forum.com/forum/f14/c5...-setup-385015/
I modeled all this stuff up in solidworks and I work at a place that designs and manufactures suspension testing machines. There I had an engineer at run a FEA on it. Just to make sure it worked and nothing would break.
ls1s10onair pm me if you have ne questions!
post #16 of 19 Old 06-22-2009, 05:47 PM Thread Starter
Local Tech
Re: c5 brakes
thanks, man! that was really helpful... hopefully i can get this done soon, but im probably opening my new shop in the next month, so money is tight
post #17 of 19 Old 06-24-2009, 12:37 AM
brakes hate me
1BadElky's Avatar
Re: c5 brakes
here's the crack in mine. never used.
Project Thread
1BadElky is offline
post #18 of 19 Old 06-24-2009, 05:20 PM
Re: c5 brakes
the knurled part of the stud must have been bigger than the factory ones. I also left the flange on the outer edge of the hub for more strength. I believe I also had to drill out the holes in the hub like 8 thousanths
post #19 of 19 Old 06-28-2009, 03:09 AM
'01 Noma
shift220's Avatar
Re: c5 brakes
Looks like you machined your hubs down a little closer to the studs. I would guess so that they fit into the C5 rotor?
shift220 is offline
