brakes are pulsating whats wrong?
Old 11-09-2009, 12:05 AM   #1
92 Iron Duke
Panzer's Avatar
I bought the truck with new brake lines, shoes and rear cylinders and its been vibrating like crazy the day after I bought it. Today I put 15's on the back with a bigger tire and the front has 14's and stopping down a hill the ABS light flickered. It didnt come on completly. Its getting worse so I need someone to point me in the right direction
Old 11-09-2009, 01:42 AM   #2
keepin it freshhh
Nitemare's Avatar
Re: brakes are pulsating whats wrong?
have you looked at the brakes at all? is the pulsation coming from the front or rear?
Old 11-09-2009, 11:35 AM   #3
fatphatboy88's Avatar
warped rotor?
Old 11-09-2009, 01:55 PM   #4
Moderator
What?'s Avatar
Sounds like warped rotor, time for a fresh one with new pads as well.
Old 11-09-2009, 01:59 PM   #5
nukem1st's Avatar
Yep, I would say a severely warped rotor(s) One way to find out,is to have them turned, you'll find out real quick if they are warped or not
Old 11-09-2009, 02:02 PM   #6
Moderator
What?'s Avatar
Good time to get new bearing and seals while you are it.
Old 11-09-2009, 02:02 PM   #7
CatDaddy52's Avatar
Not sure if it has 4 wheel ABS.....could be sensing the different tire sizes (front to rear).
Old 11-09-2009, 04:09 PM   #8
92 Iron Duke
Panzer's Avatar
its the front doin it because if i let go of the wheel when i hit the brakes it moves the steering wheel alot. Ill check the rotors when I get better. I got the flu. Not the swine flu thankfully.
Old 11-18-2009, 11:22 PM   #9
The abs light flickering is most likely because you have different size tires front to rear. Your abs counts wheel revolutions, and if you have 2 different size tires, the count is off.
The vibration is either a wheel bearing or warped rotor. Most likely a warped rotor. Get 'em turned, throw on a new set of pads, and you should be good to go. Good luck.
Old 11-19-2009, 06:09 PM   #10
And the new project is...
-Havok-'s Avatar
I know this is a pointless post, but me and my gf just got over swine flu a couple weeks ago. Sucks being sick for 3-4 weeks. She was in and out of the hospital, but I toughed it out. Neither of us got the shot and I work at Wal Mart, so I'm assuming that's how we got it. Haha
And as for the brakes, I'm pretty sure it's warped rotors too cuz my friend's car was doing the same thing and that's what it ended up being.
