#51 |
Srsly.
Location: Kalkaskama, MI 49646 User is: OffLine ![]() |
Re: brake caliper bracket bolt
Can you post up a list of everything you needed to swap to rear discs, and prices? I've got a spare rearend to work with, so I can take my time getting it all assembled before I swap it in. Is the junkyard or dealer the only place to get the backing plates?
#52 |
I needs paint!
Ill do my best to list the things, people can add to it as they see fit.
I bought the rearend from a junkyard. It was 2001 2wd blazer rearend with 3:42 gears, 7.625", limited slip, with disk brakes - $250 I bought the brake calipers and brackets to mount them from www.rockauto.com. They were $89/ea because of the core charge. I did not have cores to turn in. I bought the rotors and pads from autozone. I think it was like $135 total for both pairs The rearend came with backing plates / flange to mount the caliper bracket to. I had to buy 2 brake lines. 1 for each side that connected from the hardline on one side and to the caliper on the other - $30 I had to buy 2 banjo bolts - these connect the brake line to the caliper itself. - $8 I needed two 10mm x 35 bolts (grade 8) and USE LOCTITE!!! to mount the caliper bracket to the backing plate / flange - $5 I did NOT buy dust shields and I took the ones off that were on there. 2 qts of fluid go into the rear. cant remember off the top of my head why kind it takes, but it tells you in the manual. I bought the chrome diff cover from summit. It was a Mr. Gasket brand - about $30 and came with a new gasket seal. I had to put a different yoke on because my driveshaft connection was different. I had to buy a crush sleeve seal and I let a shop do it. My mechanic. took him like 5 minutes. If you overtighten it, you have to do it all over again. Note: I removed the emergency brake like because im auto and lay it on the frame so it wont roll anywhere. Some pictures from putting this bitch together: ![]() ![]() ![]() ![]() ![]() ![]() ![]() bolts to mount the bracket to the backing plate - these are wrong though. they are not grade 8! ![]() Wrong connection to hook up to my driveshaft: ![]() my driveshaft connection: ![]() ![]() ![]() ![]() ![]() ![]() one last one for good measure... hehe ![]() Last edited by kovz34 : 07-02-2008 at 08:41 PM. |
#53 |
bellcranks no more
NEVER cheap out or be lazy on ANY brake components.
brakes are the strongest system in any vehicle. Last edited by greencactus3 : 07-02-2008 at 08:46 PM. |
#54 |
Srsly.
So, your rearend already had the setup for disc brakes. Hm, I'm gonna have to do some serious searching to find those. Fvck a junkyard around here, they'll rape me.
Unless I can find someone with a toasted ring and pinion, etc.. ![]() |
#55 |
I needs paint!
#56 |
I needs paint!
edit: n/m they dont have them! damn! Last edited by kovz34 : 07-02-2008 at 08:47 PM. |
#57 |
Srsly.
Yeah, rockauto is awesome... I was searching under 2000 s-10, but still didn't see anything show up.
#58 |
bellcranks no more
#59 |
I needs paint!
not that i have found. as you can see from this thread, it was hard enough for me to even find the size. I had to call a couple dealerships and one of them was nice enough to give me the size!
#60 |
bellcranks no more
yea.... good thing i have a LOT of time to do research + piece together everything before i make a brake swap
#61 |
damn, so you say the yoke on the blazer rear wont connect with our s10 d/s? i am about to put mine in since i am swapping the t56/lt1 in my truck. I want to have all the parts needed. SO was it just the second gens or is it all the s10s taht need a different yoke connection?
#62 |
I needs paint!
no idea... i think it varied from 94-97, and 98+, etc.
You will be able to use the one that is on your truck right now if you need to. just swap them. But I would have someone that knows what they are doing so they tighten it the proper amount. It's not a torque setting. It's like a "feel" to know when the crush sleeve seals in the yoke. |
#63 |
oh....well te guy doing the swap for me seems to know a lot so i will ask him on saturday when igo over adn start my picture taking for my project thread, ![]() |
#64 |
rusty bumper member
no chance that you happen to look on the backing plates for the part #?
#65 |
I needs paint!
