Blazer Brakes
Old 10-09-2008, 09:52 PM   #1
GM is on crack
Ramin'S10's Avatar
Ramin'S10 is on a distinguished road
Blazer Brakes
I've read that 98+ Blazers have 2 pistion front calipers. Are they direct bolt ons? What do i need to get them to fit? And how much should I pay at a junkyard. Also, what about the rear discs? Can i just bolt em up?
Thanks
Old 10-10-2008, 04:09 PM   #2
V8 with bags
V8Blaze's Avatar
V8Blaze is on a distinguished road
Re: Blazer Brakes
For the front brakes you need the spindles and all hardware for the brakets like rotor and hug assembly. IF your currently running drop spindles you will need to purchase some for a 98+ blazer which are about 300 bucks. And ive heard people pick them up from junkyards for cheap and others for a few hundred. Try to find one with low miles so you wont have to worry about the hubs for a while as they are pricey too. The rear should all swap over, i know you have to do a little work on the axle flange on a first gen but it should bolt right up to a second gen
Old 10-10-2008, 04:21 PM   #3
GM is on crack
Ramin'S10's Avatar
Re: Blazer Brakes
sweet, thanks!
Old 10-11-2008, 03:26 PM   #4
imknotright's Avatar
imknotright is on a distinguished road
Re: Blazer Brakes
Am I correct in assuming this is for 4WD only? Or do 98+ 2WD Blazers have dual pistons as well?
Old 10-11-2008, 06:08 PM   #5
V8 with bags
V8Blaze's Avatar
Re: Blazer Brakes
98+ 2wds have dual pistons also
Old 10-12-2008, 12:05 AM   #6
Molon Labe
BudRacing's Avatar
BudRacing is on a distinguished road
Re: Blazer Brakes
If you can find the entire setup at a junk-yard, go for it.
To buy the parts individually would be much more expensive.
The Blazer drop spindles will run you ~$300, and the divorced hubs are ~$150(x2). The rest are the standard brake parts prices.
Old 10-12-2008, 05:59 PM   #7
dark side member
bbcc is on a distinguished road
Re: Blazer Brakes
Don't mean to hijack the thread, but do the blazer calipers have the same bolt pattern as the c5 vette callipers?
Old 10-12-2008, 06:00 PM   #8
i wouldnt undertsand
Wicked Mayhem's Avatar
Wicked Mayhem will become famous soon enough
Re: Blazer Brakes
nope.
Old 10-12-2008, 07:29 PM   #9
dark side member
Re: Blazer Brakes
Thanks.
Old 10-13-2008, 12:08 PM   #10
Build it Right!
philntx's Avatar
philntx is on a distinguished road
Re: Blazer Brakes
I installed dual piston front brakes from a 2000 2WD Blazer on my 97 2WD Blazer. Easy direct bolt on. Only piece necessary was a fitting for the brake line:
Old 10-13-2008, 01:24 PM   #11
bellcranks no more
greencactus3's Avatar
greencactus3 will become famous soon enoughgreencactus3 will become famous soon enough
Re: Blazer Brakes
unless you find a complete deal from a jyard or something, there are other options to consider with much more stopping power for not much more
Old 10-13-2008, 04:18 PM   #12
GM is on crack
Ramin'S10's Avatar
Re: Blazer Brakes
like what?
Old 10-13-2008, 06:44 PM   #13
Molon Labe
BudRacing's Avatar
Re: Blazer Brakes
C5
Old 10-13-2008, 07:07 PM   #14
V8 with bags
V8Blaze's Avatar
Re: Blazer Brakes
but there arent any good options for keeping them under stock size rims. thats what led me to the dual pistons. Ive got 15s and plan on keeping them possible forever. And for that brake fitting, to my knowledge you could have used your stock brake lines and not needed that fitting
Page generated in 0.13773 seconds with 11 queries
